Question about Zanussi 23 in. ZDT6252 Built-in Dishwasher
Food still visisble on some dishes
Recently the dishwasher is not capapable of cleaning the food from certain items.
The machine runs through its programme, emptys and dries, no problem.
When certain dishes are removed it seems as if the spary arms are not working to capacity, but both are free to rotate and not obstructed prior to the wash.
  • kleinster Dec 04, 2008
    Everything with my dishwasher seems to be working properly but when I go to empty the dishwasher some dishes have horrible stains on them and they just won't get clean no matter how many times I wash it!
Firstly check the spray-arms .If the machine is finishing the cycle it is most likely the top arm is full of bits food or pips peppercorns etc .
Good Luck !
Maurice .
Posted on Feb 23, 2009
My LG LDF6920St has not been cleaning very well recently and there was an odor and grease left in the bottom after a wash. I pulled it out and found the Float Assembly pretty clogged and dirty, which I...
1 Scrape and rinse dishes before putting them in your appliance. Small food particles, grease, sauces and bones clog up the system, keeping the dishwasher from properly rinsing your dishes. You don't need to prewash the dishes but be sure to rinse off any solids.
2 Use a toothbrush to clean around the dishwasher door.
Clean around the seal and hinges of the dishwasher. This area often is forgotten and holds a good deal of bacteria and food splash. A tooth- or bottlebrush is the best way to get into the crevices.
3 Clean chunks of food out of the screen and drain at the bottom of your dishwasher, recommended The Family Handyman. If the drain is plugged, the dirty water can't be washed away and ends up back on your dishes. Nut, bean and seafood shells, bits of plastic and small dishes can lodge against the drain, keeping it from doing its job.
4 Unclog the holes in the sprayer arms. If the holes are blocked by food or soap, water cannot freely spray inside the dishwasher to thoroughly clean the dishes. Leftover food on the dishes can make the dishwasher smell.
5 Keep space around your dishes. Overloading a dishwasher keeps it from running efficiently, allowing gunk to build up around the drain and the spray arms.
6 Run your dishwasher as hot as possible to break down food and grease. The recommended temperature is 120 F.
7 Run the dishwasher with vinegar added to neutralize odor. Empty the dishwasher, place a dishwasher-safe cup filled with white vinegar on the top rack, and run a cycle at the hottest setting. If you prefer, use unsweetened lemonade powder or baking soda in place of vinegar.
Jun 21, 2011 | LG LDF6920ST Stainless Steel 24 in....
I have a Maytag Dishwasher MDB4100aww that is not cleaning dishes effectively. There are small particles of food left on the dishes and some of the tougher food items to clean are staying on the dishes....
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Nov 13, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
Dishwasher is throwing food bits back on dishes during wash. How do I clean out dishwasher?
While loading into the machine always remove the food particles from the dishes. The wash machine will clean the sticky oil grease only.
Check the drain filter in the machine and clean. Refer user manual.
May 17, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Dishes are rinsed before going into machine but when the cycle is finished they are spotted and have bits of food sticking. I have cleaned the filter - do you know what dishwasher cleaner I can use. I...
Make certain that the spray arms are not clogged and are actually turning during the wash cycle. Try using Jet Dry in the rinse dispenser. Make certain that the dishes, etc. all facing the center of the tub and not nesting (behind are in front of other dishes, etc.) that would prevent thorough cleaning and exposure to the detergent and water. Make certain that the water temperature is at least at 140 degrees.
Feb 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher leaves food particles on dishes
You are not getting enough water in the machine. The inlet valve is probably plugged with sand or something of the sort. You will need to replace the inlet valve.
Jan 02, 2010 | GE Dishwashers
My dishes come out with cloudy film on them.
From Whirlpool:
*Film is due to either etching or silica film. Silica film is a milky, rainbow-colored deposit and etching is a cloudy film. Sometimes there is a water/chemical reaction with certain types of glassware.
o Silica film and etching are permanent and cannot be removed. Both can occur in any automatic dish washing machine and result from a water/chemical reaction with certain types of glassware. They are caused by some combination of:
+Soft or softened water.
+Alkaline washing solution.
+Insufficient rinsing.
+Dishwasher overloading.
+Heat of drying.
+Long/hot cycles.
To slow the down this process:
*Use a minimum amount of detergent but not less than 1 tablespoon per load.
*Use a liquid rinse aid.
*Under load the dishwasher to allow thorough rinsing.
*Do not use heated drying.
*Wash glasses by hand.
Do the following:
1. do you use a rinse agent
2. clean out the drain.
3. if you have a food disposal, run hot water through it and turn it on to clear it out before you turn on the dishwasher. The dishwasher drains into that sink. If you notice food or dirty water backing up into you sink when the dishwasher is draining, then the sink could have a minor clog and is backing up and being re-sprayed onto your dishes.
Source(s):
Use SANIVAC to clean lime deposits and extend the life of your dishwasher. If you have heavy water.
Run your dishwasher empty and pour in a cup of bleach and a cup of white vinegar to get the residue out.....run a regular cycle.......How hot is your hot water tank set on? The hotter the water the better a dishwasher washes and rinses, be careful it's not to hot as your shower and other sinks also will get this hot water......cut your dish soap down and make sure to use a Jet Rinse Aid. Again, be sure to use a liquid soap, and rinse agent, powders will cause a caustic reaction. Hope this helps. Let me know if there is anything else I can help you with.
JimmyC
Sep 30, 2009 | Bosch Dishwashers
Food particles left on dishes. Whirlpool quiet partner 1
You do not have to take it apart to clean it. You can run it a couple of times with dishwasher tablet and it will self clean. In general I recommend rinsing the food off of the dishes and silverware before placing items into the dishwasher. Also, run the hot water in the sink until it gets hot and then turn on the dishwasher. good luck with it.
Jan 27, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher is leaving food particles everywhere
Clean the filter screen at the bottom of the washer basin.
Apr 14, 2017 | Dishwashers
Food Deposits left on dishes
I had an old machine with a similiar problem & I found that food had somehow entered into the arm that spins & sprays out water. The food blocked somewhat the holes which of course means less cleaning.
Mar 05, 2008 | Maytag 24 in. MDB5601AWS Stainless Steel...
Food debris on dishes
Try running the dish washer a couple of times with out any dishes and see what happens.
Nov 08, 2007 | Neff 24 in. S5543X2 Built-in Dishwasher
Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
145 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
