Question about Hotpoint Washing Machines
Please can you help me? I switched my Hotpoint Ultima WMD940 washing machine off at the wall just before the end of the cycle at "pump out" cycle. Now its not draining or spining properly. Is there anything I can do to fix it? Thanks Debbie.
  • Hotpoint Master
  • 3,463 Answers
If it has reset button, then depress and hold it in for at least for 3 seconds, this could be the start button, or the pause button, check your handbook, it should give you some in formation.
Posted on Nov 14, 2010
In my hotpoint ultima WMD942P washing machine's softner compartment i always find water at the end of the cycle. its a new machine.
This is completely normal, the machine puts water into this chamber during the rinse cycle to wash the softener into the machine.
Mar 05, 2012 | Hotpoint Washing Machines
Hotpoint ultima WDD960, My washer dryer has stopped mid wash cycle annd is displayinh F:o5
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • The best thing is to see if it is filling and draining properly
Oct 28, 2011 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ultima washing machine wt965 and the display is flashing f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also resetting the machine sometimes solves the problem switch off at plug for 5 mins then switch back on and try again. hop this helped
Sep 26, 2010 | Hotpoint Ultima WF865 Front Load Washer
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WMD940 F-03 showing on display
The error code F03 indicates a problem with the pump out of the washer or a failure of the pressure switch that controls the water fill. This is a problem that you should have a technician diagnose and repair.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Hotpoint Washing Machines
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Aug 27, 2008 | Washing Machines
Hotpoint ultima 840
hold child lock button down for 2 seconds you will then hear a beep done.
Jun 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
183 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
