Question about Manitowoc Air Cooled Undercounter Ice Cube Machine 53lb
Looking for icemaker valve invensys k76166-2, s-86, 236h07
I need a new solenoid valve for my ice-maker the valve is an invensys model K-74973-4 and there is also a sku number which is 197D2845G004
Why did you post that here?
Simply go on Amazon and order one.
Or go to the manufacturer's website and ask for a local, or online dealer.
Mar 11, 2014 | Refrigerators
Invensys s86
Most likely clogged or worn out diaphragm. Replace valve is only solution. Take your model number and go to your local appliance parts store or go to www.searspartsdirect.com
Sep 25, 2013 | Whirlpool Washing Machines
Have an Invensys N86 on my refrigerator, it is pumping water into the water dispenser, but is not getting any water to the icemaker. I imagine my installer may have made a mistake, but I do not know much...
if this is new install . it may be installer's problem but if not its a bad water valve . and needs to be replaced .. mm the valve is a dual valve one side for ice and the other for water . .. also the ice maker tube may be frozen and the water cannot get to the ice mker .. so ck the tube inside the freezer to the ice mker . it may need to be de iced .. mm hope this helped feed back pls ..
Feb 26, 2011 | Refrigerators
Hi i'm looking for user instructions for an old style switchmaster 950 heating and water timer system. Thanks
Try contacting them here:
Invensys Climate Controls Europe
Telephone: +44 (0) 845 130 5522
Facsimile: +44 (0) 845 130 0622
Technical Helpline: +44 (0) 845 130 7722
Website: www.climate-eu.invensys.com
Email: customerservices@invensys.com
Just a note... I did not find a SM 950 but did manage to locate a SM 980
The website above links straight to This link: http://www.draytoncontrols.co.uk/content.aspx?id=2649
Under documentation they have programming instructions for the SM1 and SM2 that mention the SM980 under SM1 mechanical time switch here:
http://www.draytoncontrols.co.uk/supportingdocuments.aspx?id=1504#
This may not be what your looking for. If not just don't rate the post please.
Kelly
Sep 27, 2010 | Heating & Cooling
Monogram zdis15 icemaker - leaking
That is the solenoid valve that controls water going into your icemaker. If it's leaking on the icemaker side, then that amount of water isn't making its way into the tray and the ice is "thin".
You'll find two hoses connected - one from the house water supply (that one would be leaking all the time) and one to the icemaker that leaks only when the valve opens during a fill cycle. Check that one to see if it may just be loose, or perhaps a crack has developed in the tubing. Tricky part is it will only leak when the valve is operating for a few seconds during a fill cycle. If you have some electrical know-how, you can power the valve manually to see if you can spot the leak. If not, and you can't find anything loose or broken you may need a service tech.
Mar 04, 2018 | GE Refrigerators
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
INVENSYS CONTROL FOR KENMORE ELITE SIDE BY SIDE
Hi, you can purchase replacement part on amazon, here: Amazon com KENMORE ELITE INVENSYS CONTROL I hope this was helpful. Cheers
Apr 27, 2009 | Kenmore Refrigerators
No spark
Replace your Invensys U-67204-8 0+4 Module: http://www.toolbox.invensyscontrols.com/appliance/linkedElements/ElectronicSparkIgnition_SparkReignition.pdfwith a Tytronics 4 Point Re-ignitor #RI 120E-4: http://www.tytronics.com.au/__files/f/2792/4 Point Re-Igniter.pdf which has replaced the older Invensys Module on BlueStar Ranges like the RNB304BV1 - 4 Burner Range (also used in some Viking Ranges): http://bluestar-store.mwrc.net/en/product.php?product_id=40478 Call Prizer-Painter 800-449-8691 for instructions if not sure how to do this. Also, may want to do some cleaning first overall on the Burners and the Igniters - BlueStar Part #741801: http://bluestar-store.mwrc.net/en/product.php?product_id=37702 or replace if broken: http://www.bluestarcooking.com/bluestar-service-videos.html#
Apr 18, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
BI-98 U-LINE ICEMAKER
THERE IS A SOLONIOD VALVE WHERE YOU CONNECT THE WATER SUPPLY. IN IT IS A FINE SCREEN THAT MAY BE STOPPED UP OR THE VALVE MAY BE BAD. ALSO TAKE THE COVER OFF THE ICEMAKER AND LOOK FOR A CAME WITH A SLOT IN IT. TAKE A SCREWDRIVER AND SLOWELY TURN TO THE RIGHT ( I THINK) AND SEE IF YOU HEAR THE VALVE COME ON AND WATER COMING INTO THE ICEMAKER.
Nov 09, 2008 | U-Line Icemaker
Manitowoc Air Cooled Undercounter Ice Cube Machine 53lb Logo
390 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
George Merkley
George Merkley
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
