Question about Hifonics Brutus BXi 1206D Car Audio Amplifier
Brutus 1206D I got 4 4ohm 12inch 1000 watt pioneer subs what levels do i set the brutus at as far as gain, bass eq, low pass, phase, and subsonic.
  • 4 Answers
U need at least another amp and set em at 2 ohm and then just take it to a shop aand ask thee guy to equalize it he shouldnt charge u or at least 10 bucks
Posted on Aug 14, 2008
How do i get the most power out of it?
Get a 1.2F, 13.8V and above Capacitor to make your power stable and prevent your lights from blinking together with the music.
Jun 20, 2010 | Hifonics Brutus BXi 1206D Car Audio...
Legacy Amp 2600 watt HELP
Hello e_cody_e,
The settings you have will not break anything and may sound OK.
But they may not be optimum for getting the best bass from your system. The SubSonic setting filters out frequencies below the threshold of hearing allowing the amp to put more power into the frequencies that can be heard. So, it should be set to about the same frequency that your enclosure is tuned for or just a little lower. If your enclosure is tuned for 35Hz, then the subsonic should be close to maximum.
Similarily, the low pass sends all frequencies below the setting to the subs, (other than those blocked by the subsonic filter) and is commonly referred to as the "crossover" frequency. Typical crossover frequencies for subwoofers are 60Hz, 80Hz and 100Hz. For a ported enclosure, lower is probably better.
The phase shift should be set to the position that best synchronizes the bass with the music. Because of the additional wiring required for the subs, the signal to them is sometimes slightly delayed causing the bass to be "out-of-sync" with the rest of the music. The thump of the bass comes just a little sooner or later than expected. If the bass sounds out of phase, turn the phase shift on, otherwise leave it off.
The "gain" or level control allows you to match the amps input to your head units subwoofer output. The best setting is usually as high as possible without distortion. Set it by turning up the head unit volume to about 3/4 maximum and then advance the amp gain until your subs just begin to distort. Then back it off slightly.
These settings should allow your amp to put the most power into the frequencies that your subwoofers are designed for and hence produce the loudest and lowest bass.
Hope this helps.
Jun 28, 2009 | Legacy Car Audio & Video
I am ordering 2 pioneer TSW307D4 or D2 is a 2400 watts amp good?
ok theres a amp called slugger they came out about 7-10 years ago its small but very very powerfull i was picking up my 2 15 inch l7 kickers i drove from my house to vegas with no problem about 4 and a half hrs and didnt turn off ,on the other hand i had my fosgate wich i love t1000 wich turned off on me a couple times
Mar 15, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Brutus 1206D
set the lp filter to about 100 to 125 (or lower if want seep boomy only) , put the bass eq no more than 75% but i would recommend no more than 50%, gain is to match the sound not to adjust power with so it is a user preference start all the way down and slowly go up till u hear distortion then turn it back down by about 10 - 15 %, phase shoild typically be at 0 degrees, subsonic depends on if you r using sealed or ported ported turn it all the way down then adjust as needed to get rid of the lower sounds you dont want (muddy sloppy sounding bass) if sealed turn it all the way up to at least 35 hz.
Jun 18, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Brutus 1206D
yes it can only at 2 ohms never 1 ohm good luck
May 25, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Setting low pass and bass eq
the only thing that might damage equiptment other than playing it too loud would be running at 1 ohm if not supported by the amplifier.
as far as the eq and crossover settings, that is dependent on personal preference, and the acoustics of the paticular vheicle installed
May 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Hello, i have a hifonics brutus also, in the manual it states to set the eq at half way, so that there is no clipping or at least to prevent clipping , the eq will make the bass punchier, if you do go pass half way, i would recommend to readjust your gain settings, also check your head unit settings and make sure everything is flat, bass, mid bass etc. example i had my eq past half but i had my gain at mid way, it was hitting hard, then i tried turning the eq all the way down and the turning up the gain and the bass was smoother so it depends where you set it, and what settings you have on your head unit tone control (bass, treble etc)
The phase is used to match the phase of the sub, highs amps. If you don't know how to determine if there's a phasing problem between the two amps and you can hear no difference, leave it set to 0.
Many people use the subsonic to prevent over driving speakers in a ported enclosure. If you're using a sealed enclosure, leave it set to the lowest frequency. If you have a ported enclosure, set it just below the resonant frequency of the port in your enclosure.
Apr 07, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics Brutus BXi 1206D Car Audio Amplifier Logo
125 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
