Question about Toshiba Satellite P105-S6177 Notebook
My laptop is not responding in any manner when attempting to turn on. I replaced the battery and still no response of any type when pushing the on button
  • 6,831 Answers
Hello
OK, firstly you will need to try to power the laptop on using the power adapter.
If you still get no response whatsoever, you will need to consider the fact that your power supply might be done.
Try to power on the unit using the AC power adapter, if it still doesn't work, let me know, so that we can look into some further scenarios.
Let em know.
Kind regards
Andrea
Posted on Nov 14, 2010
Vehicle acts like dead battery but it is not.
It is a type of security system. Like you said all functions are turned off until you push button because battery is disconnected from system.
Apr 28, 2016 | Cars & Trucks
Why will my vhf radio not respond to on/off switch
Odds are you have a dirty contact. Soft!!!! Touch switches are exactly that. The switchs in a tv remote, microwave oven, calculator or office equipment have this type of swithch. If you find your pushing them harder to activate them, they need cleaned or batteries need replaced. When I worked on copiers (27years) I noticed that only the the slower copiers had keyboard switch problems. I called this the elevator syndrome. You know the more times you push the button the faster the elevator goes? Ultimately this damaged the button resulting in a cracked solider joint . Possibility #2. I have a set of the radios your discribing odds are it's option #2. They force you to hold swithch down until it "boots up" end result cracked solider joint goog luck , brethall610@icloud.com
Sep 28, 2014 | Radio Communications
How do you work 2006 street glide push button key fob
1 long push on the remote turns it on and 2 quick clicks turn it off.
Disarming function may require practice. The key fob button must be pressed twice within 1.5 seconds to send the disarm command. The action is very similar to double-clicking a computer mouse. Light quick taps work best; very hard or very slow taps are less likely to work. The key fob sends a RF signal to activate all remote TSSM functions. The left front turn signal switch wire serves as the vehicle's antenna. If the TSSM does not respond (no confirmation at arming/disarming system) or responds weakly (limited range, won't consistently arm/disarm or synchronize),
Verify key fob battery voltage is at least 2.9 volts. Replace the key fob battery every 2 years.
Interference from physical surroundings may affect RF transmission. Place the fob next to left hand grip and disarm with two clicks or move the motorcycle to a new location and try again.
Check for damage to antenna wire. Does left turn signal work?
After a battery disconnect, the TSSM will not enter the configuration mode on the first attempt. All attempts to assign a fob or enter the configuration mode will require at least two attempts.
The TSSM system uses batteries in the key fob and siren. These are the only parts requiring periodic maintenance.
Battery Replacement
Open the key fob case, place a thin blade between the 2 halves of the case, slowly twist the blade remove and replace battery positive + side down, use a Panasonic 2032 or equivalent, align the case and circuit board, snap the case halves together, while standing next to the motorcycle, press and hold the key fob button for 10 to15 seconds until the security system responds with two turn signal flashes/siren chirps.
May 04, 2014 | Harley Davidson Motorcycles
My meep tablet is not responding it keeps telling me system ui is not responding I have tried to push the reset button and turning it off and on but it is not working please help
The first answer does not apply as the Meep is not a laptop and does not have a removeable battery. The second response gives a contact number for another tablet.
If the reset button and rebooting are not resolving the problem, then it is considered a hardware issue. You should contact your nearest Oregon Scientific call center. If you are in the USA, that is 800-853-8883 or customerservice@oscientific.com.
Apr 24, 2014 | Tablets & eReaders
Power Button doesn't work
I have a Dell Studio laptop and sometimes some buttons become not responsive, including the power button. As for power button, I noticed that if you hold it for a few seconds, the laptop will turn on (at least in my case). The fix that works for me is as follows:
1. Turn the laptop off;
2. Disconnect the charger and take out the battery;
3. Wait for a few seconds;
4. Open the laptop lid (as you probably closed it while taking out the battery), push the power button and hold it for a few seconds. Nothing will happen as the laptop won't have any power, but it clears some sort of electrostatic load or whatever it's called;
5. Put the battery back in and turn on the laptop.
I used this for a few times, so perhaps it'll help in your case as well.
Feb 05, 2013 | Dell Vostro 1700 Laptop Computer (Intel...
I attempted to shut the computer down via the startup menu but closed the laptop prior to it shutting down. When I reopened and turned on it asked for password to log into windows but the hour glass...
Try pressing and holding the power button until the computer shuts down.
Also note that when removing the battery, you also need to unplug the power cord in order to shut down the computer in that manner.
Dec 29, 2010 | Computers & Internet
Starting / Cranking is a problem: With key ignition, turn; there's a slient buzz noise. Head lights and dash board lights come on, however it doesn't respond to crank. Weak response is battery sometimes...
This could be a battery thats bad and doesnt have enough voltage or the starter is bad, easy to figure out, have the battery tested if its bad then replace it but if it tests good then i would replace the starter and also have the charging system checked to make sure the alternater is charging the battery up. hope this is helpful.
Nov 08, 2010 | 1997 Saturn SL
Keyboard keys not responding, you cannot type anything no response!
Hello if you have the unit turned on and still no responds from the keyboard , then you have a major defect. My suggest is to take it back to the place U bought it right away to get a replace or refund. Good luck
Mar 07, 2010 | Toshiba Satellite L300D-ST3501 Notebook
Laptop will not respond..please help.
It is new and under warranty. Anything you do inside this laptop will void the warranty. Take it back to where you got it, and get it repaired under warranty.
Jan 14, 2008 | Computers & Internet
Toshiba Satellite P105-S6177 Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
