Question about Hanns.G Corporation HU-196DP LCD Monitor
I have a Hanns-G Model HG281DJBUF101 monitor. When I first power it up, it works just fine, but after a few minutes, I start to see flickering, especially in the blue tones. If I simply turn off my monitor for a few seconds, then back on, it comes back okay, but then starts to flicker again. Sometimes the screen even goes blank (not from a screen-saver). I'm guessing something's getting too hot. I took off the back cover, expecting the circuitry to stay cooler, but still had the same problem. I am handy with a soldering iron, and could do basic repairs (like replacing caps, etc.), but I don't know where to start. Thanks!
  • 11,361 Answers
Please read my guide and look real close at the caps and voltages.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Nov 14, 2010
Hanns G HW191D flickering. Monitor works fine but flickers.
Go into your monitor properties and change the refresh rate to a lower setting.
Jan 14, 2010 | Hannspree HW191D LCD Monitor
A couple of weeks ago the monitor would come on but when the computer started the light would start flashing but monitor would come on after a few minutes,then it slowly started to take longer and...
This failure is caused by a semiconductor (perhaps a IC or Power transistor), as the part is getting worse, the display will taken longer to work. Unfortunately, today displays are getting cheaper and repairs on this kind of issue is not recomended. You may need to consider to get a new one.
Oct 09, 2009 | Hanns.G Corporation Computers & Internet
Hanns.g hx191d only green led flickering but no display graphics
Hello Joe,
Your monitor has a power supply that is going out. if you can solder you should be able to do the repair yourself, it involves replacing a few parts but its not that hard to do. Go to our web site at: www.ccl-la.com/badcaps.htm and look at the pictures and repair guides. Open your monitor and replace any capacitors that look like the ones in the pictures and you should be back going. We have a repair guide for the HW173 monitor that should be very close to your model.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 12, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
Samsung SyncMaster 226bw 22inch flickers/blinks on startup
Solution = Sledgehammer. My 226BW has been taking ages to warm up for a while and now it is a permanent dull flicker.
Aug 26, 2009 | Computers & Internet
Hanns-G HG216D is flickering to black screen
Started working after I d/l the driver
http://cms.hannsg.net/onweb.jsp?prod_no=3333333617&webno=33333333:0
Jul 31, 2009 | Computers & Internet
My Hanns-G HC194D LCD Monitor Takes Forever to come on
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 16, 2009 | Samsung SyncMaster 203B LCD Monitor
HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
when u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Jan 05, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Hanns g 19 inch monitor
No direct experience of this specific monitor, but LCD monitors in general seem to be susceptible to power supply failure due to the relatively cheap capacitors they use and the high working temperatures.
Turn it off, leave it for an hour or two, then take off the cover and look for bulged or leaking cap's on the power supply board. If the tops are not flat, they're probably duff, and need replacing with equivalent spec ones. Probably 105'C high temp - I got 105'C 470uF 35V ones for my monitor from Ebay at about a fiver for a pack of ten.
Aug 27, 2008 | Hanns.G Corporation HX191DP LCD Monitor
Hanns.G Corporation HU-196DP LCD Monitor Logo
701 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
kj henriksen
kj henriksen
Matthew Spark
Matthew Spark
 Grubhead
Grubhead
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
