Question about Sharp R-1514 Microwave Oven
Removal sharp r-1514 microwave - Sharp R-1514 Microwave Oven
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave does not turn off
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can get Sharp parts from Tritronics at http://www.wehaveparts.com
Posted on Nov 05, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: sharp r-1514 microwave
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food / grease debris in the switch.
MicrowaveSvc
  • 9086 Answers
SOURCE: sharp carousel microwave R-1514 F
What usually breaks is the door open lever.
On an over-the-range model, only the control panel needs to be removed in most cases.
Please unplug the oven first.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
We have 2 service manuals that are very close to this model have uploaded it them our site here to help you. You will need the free Acrobat Reader to view or print them.
http://www.microwavedisplay.com/r1500_r1501_r1505_r1506_sm.pdf
http://www.microwavedisplay.com/r1512_sm.pdf
(Note: do not rely on the part numbers shown in the manual. Verify them at the Tritronics site mentioned below)
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) to open the door.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Posted on Oct 13, 2008
  • 25 Answers
SOURCE: interior Microwave doesnt come on..Burned out?
If it doesn't have a door you have to remove the cover. Its likely a special microwave bulb and the socket will have to be replaced with the bulb. the bulb is built onto the socket.
Posted on Jan 14, 2009
  • 1214 Answers
SOURCE: I have a sharp microwave
It looks like you need to remove the unit from the wall, remove the outer cabinet sheet metal, then remove about 6 screws from the backside of the control panel.
You should be able to tell as you get in there what needs to be removed.
But it doesn't look like you can access to replace without taking the outer cabinet off.
Posted on Jan 24, 2009
Turn off sound
you must test the speaker with VOM continuity 2) reset the microwaves disconnect the power cord by 40 seconds and try again. 3). Defective/damaged touchpad.
God bless you
Jul 29, 2013 | Sharp R-1514 Microwave Oven
Display panel r-1514
Possible that the control pad or the main board or the processor is faulty. You can remove the top cover after disconnecting and remove the front panel, check for insects within that have nested , if so clean the board and reset the panel connection. If not you can call for help to Sharp support at your place.
Check website : Sharp
Jan 31, 2013 | Sharp R-1514 Microwave Oven
How do I remove this microwave from my under the counter cabinet, i am trying to put in a new one
The installation instructions show you how to install it, so you simply work backwards.
I have uploaded them to our site here.
NOTE: I would be very interested in buying your control panel assembly from that oven.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly about this: William E. Miller prototech@usa.net
Dec 02, 2010 | Sharp R-1514 Microwave Oven
THE LIGHTED DISPLAY IS NOT READABLE THE DIGITAL READOUT IS OUT
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Jan 26, 2010 | Sharp R-1514 Microwave Oven
Sharp R1514 - handle is stuck "in"
The mechanism has failed. simply replacing this handle(push) mech will fix this issue.
Jun 03, 2009 | Sharp R-1514 Microwave Oven
I have a sharp microwave oven R 1514. there are 4 buttons on the front and one is broken, will not pop back out. I bought new springs and need help with the installation
Jan 24, 2009 | Sharp R-1514 Microwave Oven
Interior Microwave doesnt come on..Burned out?
Jan 14, 2009 | Sharp R-1514 Microwave Oven
Sharp microwave R-1514
The control / display unit is Sharp part # CPWBFB076MRU0. Retails for $76.99 plus shipping.
You can order from Martin Microwave Inc. - toll free 1-877-894-0035
You can check the website (www.martinmicrowave.com), but they don't have the boards available online.
Oct 20, 2008 | Microwave Ovens
Oct 23, 2007 | Sharp R-1500 Microwave Oven
Sharp R-1514 Microwave Oven Logo
63 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
