HI Have a cello 22"
  • 4 more comments
  • shaun dolman Nov 15, 2010
    I Have checked power in and out and I have 12 volts coming out. The screen just flickers on and off very fast and eventually stops flickering and does nothing. I then switch the mains off and back on and the screnn flickers again. Pretty sure its not the power supply as this is ok. It seems to me like a starter etc on the screen thats not letting it come on.
    Hi, Please can you advise which is the mai board and which is the lcd board. I have a supply power board and the main large board in the centre. Do you mean disconnect the screen board or another one. Thanks Shaun.
  • shaun dolman Nov 16, 2010
    Hi, I have 12volts coming out of the power supply to the board. If i disconnect the screen then the flashing stops and the stanby light goes to green for a few seconds
    Hi, I have disconnected the lead from the main board to the middle of the screen at the top.
    After doing this the stanby light goes green for a short time and the flickering stops and the screen is black. Does this just not take all the power from the screen etc. After putting the connector back to the board on top of the screen it then starts to flicker again and the standby light flickers fast orange.
    Does this mean I need a new lcd screen and if so is it worth it.
    Many thanks Shaun.
  • shaun dolman Nov 17, 2010
    HI, Nothing seems to be on when I disconnect the board on the screen.
    The screen is just blank as I removed the screen connector. Does this not remove all power to the screen.
    Also is the lcd board part of the screen as it is fixed along the top of it and looks like I will have to buy the complete screen and board together.
    Thanks for your help.
    The inverter board looks fine. No burning etc and no loose wires to the lamp.
    Screen just flickers all the time until I disconnect the screen from the main board and then its all black with nothing at all.
    Thanks Shaun.
    President:
  • 1,961 Answers
The problem of your TV probably on the inverter board and on the cathode lamp itself.A deffective inverter board can cause the flickering of the screen same with the cathode lamp.Because the inverter board is a high voltage board,it affects the power supply because the inverterboard gets it's 24v supply from the power supply and gives an output of 120vac to the cathode lamps.to check this components you need to open the back cover of your TV to get into the parts.The inverter board is a board with small transformer on it this connects to the lamp which is situated at the top and bottom of the screen .
Try to resolder first the connectors of the inverter board also tighten the connectors of the lamp and the inverter.Have a visual inspection first on the board to see if there loose solder and burned parts replace if you found one...Pls post back if you need further trouble shooting guide or click the thumbs up button if this helps you good luck!
Posted on Nov 17, 2010
  • Danilo Baraquiel
    Danilo Baraquiel Nov 18, 2010
    If that's the case sir the problem will be on the lamp itself .It is a cold cathode lamp it is about to be busted.The lamp is available on line at shopjimmy.com
    Genius:
  • 1,112 Answers
Hi:
Thia may be due to low voltage from the power supply, usually leaky capacitor on the power supply will cause these symptoms. also check the inverter boards for puffy capacitor tops, mose caps are flat on their tips replace and you find with same value and voltage ratings.
Posted on Nov 16, 2010
  • 335 Answers
Disconnect the LCD board from the main board and see if the back lights stay on with no flickering. If they stay on with no flickering then the LCD board is faulty and needs to be replaced or repaired. If the back lights still flicker with the LCD board disconnected from the main board then the inverter board AC output is faulty. If so, then its most likely one of the inverter boards 'step-up transformers' that has opened or developed an internal short. This will cause the back-lights not to work at all or will cause a strobing affect (flickering)
http://tvtechwork.webs.com/
Posted on Nov 15, 2010
  • Circuit World
    Circuit World Nov 16, 2010
    Ok, first re-connect all the wires and cables back the way they were originally. Make sure all the boards are firmly connected to their wire connectors. Ok, now turn the TV on to verify that the back lights are still flickering which indicates the original fault condition. That tells us everything is hooked back up correctly. So now, look at the small board on top middle of the LCD panel, that is the LCD board. Simply disconnect the LVDS cable from it then leave it alone. Now turn on the power and see if the back lights still flicker. If they stopped flickering then its the LCD board thats faulty. From this point let me know what you see...
  • Circuit World
    Circuit World Nov 17, 2010
    Ok great,
    If the flashing stops meaning that the back lights are steadily on then that means you need to replace the LCD board.
  • 12,061 Answers
This is a fairly classic switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed.
Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Cello, in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
Hi, well I applaud you for wanting to have a go, but you must make sure that you are starting in the right place, That is The Power Supply, as, if, that isn't right nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. That's it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then that's a prime cause of failure. Resistors, hardly ever go faulty, and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be able to say.. "Oh that's the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish, a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. The Tools you will need are A SERVICE MANUAL a Good Multimeter, a Signal generator, a Signal Tracer, pref an Oscilloscope, Soldering Iron, De-soldering iron, Probably, too, A SMT Hot Air desolderer (for the Surface Mount IC's), Compressed Air, An Anti-Static Wrist Strap, (MOST IMPORTANT, to prevent ESD), Cutters, Screwdrivers, sometimes, Torx, drivers too. Tweezers, are real handy, a magnifying glass, or eyepiece, a good strong white Light. OH, and you MUST have the original remote control too, (Sometimes one must obtain, purchase, a special "Servicing remote") as one needs this to "Program" the Computer in the TV, after, and during servicing, and to be able to put the TV, into "Service Mode" too.
Need fix how do i make it stop flickering
Coby lcd tv keeps flickering Flat Panel Televisions ... - Fixya
www.fixya.com > ... > lcd tv keeps flickering > Flat Panel Televisions
Coby flat panel televisions lcd tv keeps flickering related questions and answers. Ask your Coby ... Why does my Coby 40 TFTV4028 LCD TV keeps flickering.
Coby adjust air fuel mixture Flat Panel Televisions ... - Fixya
www.fixya.com > ... > adjust air fuel mixture > Flat Panel Televisions
Coby flat panel televisions adjust air fuel mixture related questions and answers. Ask your Coby ... Coby 32 in tv ... to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels. ... Ad. Question about 40 TFTV4028 LCD TV. 1 Answer ... Flickering can be adjusted.
Won't turn. on red standby light changes to on but then
Jan 04, 2016 | Coby 40 TFTV4028 LCD TV
Lc32le10m showing only standby ligth no ligth on the screen
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 22, 2015 | Televison & Video
Tv is stuck on standby. The standby light (red) is steady and when I press the STANDBY button, nothing happens. no response or flashing light.
- Flickering screen
- Dim screen
- Slow start
May 11, 2015 | Televison & Video
Luxor 40 914 tvb
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Televison & Video
Coby 22' TFTV 2224.Bought approx 2 yrs (or less) ago. In taking it to another room (just around the door frame and it was still plugged in and on) i may have pressed a couple of buttons together. Shortly...
Honestly your best bet is to sell it for parts and on ebay/craigslist and just purchase a replacement 22" tv. For the amount it would cost to fix you could basically have a new tv with a warranty for the same amount of money.
Thank you,
Lee
May 03, 2011 | Coby TFTV2224 22 in. LCD TV
I have a cello 19" lcd tv that won't switch on and
Hi Dolly,
My cello is doing this as well.....have you had any luck?
LJ
Nov 10, 2010 | Televison & Video
Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Hisense TL1700 17 in. LCD Television
LG Flatron W2234S 22 purple tint problem
your LCD monitor has bad ccfl lamps or inverter circut..
May 08, 2010 | LG 22" FLATRON LCD Monitor
Cello Tp-1907
Hi Gary.
I didnt get anywhere with fixing this set & ended up scrapping it.
Sorry.
Chris..
Mar 12, 2008 | Televison & Video
Televison & Video Logo
215 people viewed this question
Top Televison & Video Experts
Electro Med Services...
