I have a logitech keyboard (model S10) and some how I switched it on to it's french keyboard setting. How do I cahnce it back to the english keyboard setting. Thanks!
  • 558 Answers
Delete the French from the keyboard setup section in windows, to cycle between them there should be a little box on the task bar if it is not locked this will, if clicked, offer selection of languages you have installed to use on the computer.En will be English and Fr is French etc etc.
Posted on Jun 19, 2008
How do I switch from English to French. There has to be a way of doing this from the keyboard. thanks brian
Hi, a French keyboard is very different to the English keyboard, so for writing in French I use goodle translate and copy and paste into i.e word. The alternative is to plug a french keyboard in place of the English one. Come back to me if this isn't helpful
Jun 24, 2010 | Computers & Internet
When I type, sometimes a key types a french letter with an accent. How do I get it back to the english version? Also, my number pad to the right of the main keyboard doesn't work. Any suggestions? Thanks.
Make sure the NUM LOCK key is on. Your number key pad won't work if it's not on. As far as the French letters with accents, when the Enable indicator on taskbar check box is selected, and you have two or more languages installed, an indicator that represents the default language appears on the Windows taskbar. To switch between languages quickly, click the indicator, and then click the language you want to use. You can also use shortcut keys to switch between languages while you type. Select one of the switch languages options on the Language tab to set the shortcut keys.
Jun 18, 2010 | Logitech Wave Cordless Desktop
The slash key under the ? shows up as a e with an accent why?
To the right of the "space-bar" on the keyboard, hold down the ALT GR ("alternate graphic") key, press the "slash" key, and release the ALT GR key.
Or, in "Regional Settings" within "Control Panel", change your "input method" to "US-English" keyboard, rather than some French or French-Canadian input method.
Jan 25, 2010 | Logitech 967437-0403 Keyboard
My Dell keyboard is typing french symbols,how do I change it back to english
if you have windows XP follow these steps :-right click on Taskbar-Toolsbar-here check the language bar(should apear in your case french) -right click on the Fr(that apear)-settings -here you will see French keyboard-click Add and select EN-english -than OK and your keyboard should type english letters/
Dec 09, 2009 | Dell 0Y3740 Keyboard
My keyboard is typing an è instead of an apostrophy
Microsoft Windows has support for "foreign" keyboards, e.g., French, Swedish.
You've managed to hit left-ALT-SHIFT to switch the "input language" from English to French.
Use "Regional Settings" within "Control Panel" to set it back to English.
Oct 21, 2009 | Microsoft Windows XP Home Edition
Chose Canadin French instead of Canadian English by accident
Yes you are right: it is a one time option. You can however install other languages. You will switch from the Canadian French keyboard to the US or English Canadian keyboard by pressing Shift Alt. You will console yourself if I told you that I type mainly in French, but the physical keyboard is US and I cannot even use the Alt + Ascii code to put the accents where due, because the laptop does not have numeric pad.
Hope it helps.
Sep 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 7530, keyboard language switches
go to control panel
Then regional language option
then set english united states. then apply and ok.
If you not ablwe to read french then just set english it is upperr from current selection 5 or 6 check it.
Aug 20, 2009 | Computers & Internet
Hi Sam,
Sorry your problem got left in the que for a while, but Lee apparently wasn't familiar with that keyboard. You do have an extra key near the start button that activates the Tags and other coloured symbols while in french or multi language mode. Simply use it like a shift key.
If you're not using the HP to type in french and don't require the accents you can change the setting in windows to tell the computer that your keyboard is a US english keyboard which will reassign all the keycodes to the "normal" locations by english speaking standards.
To do so, open your control panel, click on the classic mode link if it's not already in classic mode(20+ icons). Then click on the regional settings icon. Depending on wether you have Vista or XP the panel varies slightly XP has a keyboards tab, Vista has a Input Devices tab. Either way go to that tab and click the button to adjust input devices, on the page that pops up you will see a list of available, installed keyboards. If US english isn't listed click the ADD button find it in the list and add it.
If you only type in english, remove all other keyboards. If you use french as well, remove all but the canadian french/canadian multilingual depending which you have(if you don't know follow instructions below to find out). Then OK out of the window. OK the regional settings window and close the control panel. If you only select US english you're done, if you left French as an option you will see a small blue icon to the left of the clock, you can click on it at any time to switch between your installed keyboard modes.
Hope this Helps FixYa!
Model info for your product can be found at click Support & Drivers, then select the Knowledgebase button on the next screen and type in your full model number or allow the automated link to check your model online. When it launches your product page select Product Specifications from the long list in the middle and if it brings up a second list select the same.
You can now scroll down the specs and your keyboard will be listed as either Canadian English/French/Multiligual, all three have some variation of the keys you described.
Apr 11, 2009 | HP Computers & Internet
Logitech cordless desktop mx 3200 laser keyboard - french characters
Its not the keyboard fault but your operating system. I'm going to assume you live in Canada and when you had setup the computer for the first time you had selected Canada has country you live in instead of the United States (default) If you notice on your desktop or taskbar there will be a keyboard logo. Click it and select US 101 keyboard (United states). You get the french symbols because microsoft thinks because you live in Canada you must be french canadian.... stupid eh! They have it selected to mulitlingual Canadian. Select the US English as default and you shouldn't get those french symbols when you really want the shift or question mark key.
I live in Canada and I see looks of people who ask me the same question all the time.
Hope this helps!
Aug 20, 2008 | Logitech Computers & Internet
Normally the keys on a keypad are standardised in designe. Please go through the cataloge you may find the english version of the keys equivalent if you dont find the details then consult the shop from where you picked up the equipment for obtaining details through the customer support.
Sep 06, 2007 | IBM PS/2 Enhanced Keyboard/Mouse 71G5791
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
