Question about Stiebel Eltron Heating & Cooling
Need wiring schematic for heater model ETS 508 240 V heater unit
need wiring schematic for heater - img_0613-uk3nsfrbjmmgqc2tsboqpvuj-4-2.jpg Heres a wiring diagram which can be found on the inside of the heater. What i would like to find is the system wiring diagram referenced at the bottom of that diagram.
Posted on Feb 02, 2018
3 Suggested Answers
  • 10 Answers
SOURCE: 240 or 120
240V used 1/2 the power of 120v It shoudl be wired on a dedicated circuit.
Posted on Mar 16, 2009
  • 4 Answers
SOURCE: i have 240 volt baseboard heater need to wire 4 wire theromostat
i have the answer, did you solved it yet???
Posted on Nov 07, 2010
I need the wiring diagram for model #gu100-3
Google! the company and as long as you have the "serial number" and "model number" of the unit you should be able to download the schematic;)
Nov 21, 2014 | Heating & Cooling
Need a schematic for a true freezer model gdm43f door heater circuits
Most all true units have digrams on the unit. May have to pull covers to find them
Apr 15, 2014 | True Freezers
I need to know where 3 wires connect on a goodman pc036-1b rev e package unit air condtioner and central heat system.
Contact Goodman directly to request a wiring diagram for model pc036-1b, rev. e. It is important to specify rev. e.
Nov 01, 2017 | Heating & Cooling
Why is our ETS heater streaking the walls and ceiling black?
Electric heaters should not give off anything to make the paint go black , paint will change colour from the heat over time . I would say make sure there is nothing behind the heaters causing this to go black .
Ask where you buy your paint they can advise on paint that will not change with the heat .
Mar 17, 2012 | Heating & Cooling
9@how to fix dtc p1178 and p1118 on a 2002 hyundai xg350
I live in Australia & have a Hyundai Grandeur XG 3LT V6 2002 model (US equivalent is Hyundai XG300).
Fault codes are P1118 (ETS motor fault) & P1178 (ETS motor battery voltage open). An intermittent fault.
The first code denotes general area of the fault & the second code denotes the specific fault.
So the specific fault is that the ETS-PCM computer is not receiving 12V on pin 2 with ignition on.
'Check engine' light remains on & car is in 'limp home mode' with very little power & poor performance.
I had purchased the Hyundai service manual online (ebook about $8) for the US model. Could not find any
manual for the Australian model. On page FLA-52 found the block diagram for the whole ETS system.
I am a retired electrical engineer so now it became easier for me to find the fault.
There are 2 computers behind the center console. PCM & ETS-PCM.
Pin 2 of the ETS-PCM should have 12V present when ignition is on.
In fault mode 12V was not present. This 12V is supplied from ETS 15A fuse (fuse box under dashboard)
via a relay (i will call this relay the ETS relay). The 15A fuse was OK but the 12V was only
intermittently being passed through the relay points. Relay is located near ignition switch on a
sub panel which has about 6 relays on it. ETS relay was at right bottom corner of sub panel.
Yellow wire feeds the 12V (which is always present even with ign. switch off) to the relay points.
White wire is the output wire from the relay points which feeds 12V to pin 2 of the ETS-PCM computer.
Measure if 12V is present at white wire when ign. switch is turned on (no need to start engine)
I only had the 12V present intermittently. So pulled out the ETS relay - tested contacts with
ohmmeter & found to be only making contact intermittently when relay lever depressed
- removed relay case by grinding away one corner of the case - cleaned the relay points with fine sandpaper.
replaced the relay case & taped with black insulating tape to keep out dust. Tested relay with ohmmeter & points
now OK. Fault is now cleared & car is operating normally.
Also had previously purchased on Ebay a Can OBD11 scanner for $15 which read the fault codes OK.
Hope this helps other people with similar problem.
Mar 15, 2011 | Hyundai Motor 2003 XG350
Need a schematic diagram on a trane furnace model blu080k0942b0
Have you checked on the inside of both front panels?
Mar 05, 2009 | Heating & Cooling
Need to verify wiring on hatco 3sc9 sink heater/rethermalizer
hi my name is mark, leave your e-mail address and i will send a pdf file
Jan 29, 2009 | Kitchen Appliances - Others
TempStar 10 AC
visit www.gotempstar.com for the schematic on this unit. Coincidentally, your air handler unit should not draw 15.6 amps with an additional 40 for the heater.
Jan 07, 2008 | Dishwashers
Heating & Cooling Logo
229 people viewed this question
Top Stiebel Eltron Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Stiebel Eltron Heating and Cooling Expert? Answer questions, earn points and help others
