My computer screen is black after logging in and i cant do anything i have windows vista
    Genius:
  • 1,456 Answers
Hello
This usually occurs when your RAM is faulty and can actually happen to all computers running many different operating systems. Aside from installing a new operating system to test out the RAM, you can simply switch out your RAM.
Turn off your computer if it is on. If you are experiencing the black screen regularly, there is a good chance that it will not allow you to boot up your computer fully without shutting itself down. If this is the case, your computer is already more than likely off. Remove the power cord from the computer tower.
Remove the screws that hold the PC tower cover in place with a screwdriver. The tower cover usually only comes off on one side, so gently remove the side that is capable, and place it away from the tower. Users with laptops need to remove the RAM panel from the underside of the computer. This gives you access to the RAM for replacing.
Locate the RAM that is attached to the motherboard of your computer. You will see clasps that hold the RAM into place, and you may see more than one stick of RAM. Remove all of the RAM sticks by pushing the clasps away, unhooking the RAM from the motherboard. Click your new, replacement RAM into place, and cover the tower back up with the cover, or replace the laptop RAM panel.
Hook up the power cable or place the battery back in, and power on your computer. You now see that your computer is working without the black screen appearing. If you have more than one stick of RAM, turn the computer off, and remove the power cords and battery. Insert one old RAM stick, and cover the tower back up, replace the power cord or battery, and turn on your computer. Check to make sure it does not present you with the blue screen. One by one, reinsert the old RAM sticks into your computer, and test your computer for stability. Once you are presented with the black screen, remove the last old RAM stick that you inserted, and your screen problems are gone.
Posted on Nov 14, 2010
Tip
How to reset Windows Vista password?
The question about how to reset Windows Vista password is often seen on various forums and Q&A websites. It is a serious problem for you if you are not good at PC. But if you are familiar with computer, the answer to the question can be very simple. There are many fast and easy ways for you to reset the password. Here it introduce you a simple one - create a Windows Vista password reset disk and use it to help you perform Windows Vista password reset.
Method 1: Reset Windows Vista password through Vista operating system
Windows Vista allows you to create a password reset disk with a USB flash drive in a few seconds. It can help you reset Windows Vista password when you forget it.
Part 1: Create Windows Vista password reset disk
Step 1: Log on your Windows Vista computer.
Step 2: Insert a USB flash drive in computer.
Step 3: Click Start button to select Control Panel.
Step 4: Click User Accounts and Family Safety in the following screen.
Step 5: Click User Accounts when a new screen appears.
Step 6: Click Create a password reset disk in the left pane in the coming up screen.
Step 7: The Forgotten Password Wizard will open, and then click next.
Step 8: Select the portable media drive which you want to create a password reset disk on, and then click next.
Step 9: Enter your current password, and then click next.
Step 10: Click next when the progress indicator shows 100% complete.
Step 11: Click Finish in the next window.
Step 12: You can now remove the flash drive from your computer.
Now you have successfully created a Windows Vista password reset disk. And you'll find a Userkey.PSW file when you open USB flash drive. Keep the file or USB flash drive in a safe place. You'd better to mark the USB flash drive so that you can distinguish it from other USB drives. When you forget password on Windows Vista and cannot log on your PC, you can use the USB password reset disk to reset Windows Vista password. You could follow the below steps.
Part 2: Reset Windows Vista password
Step 1: Start your computer and get to the Windows Vista logon screen.
Step 2: Type a wrong password, and then press Enter.
Step 3: Click OK when the error message that the user name or password is incorrect. And the Reset password link will appear on the Vista logon screen.
Step 4: Click Reset password to open Password Reset Wizard screen.
Step 5: Insert your USB password reset disk in computer.
Step 6: Click Next on the Password Reset Wizard screen.
Step 7: Select your USB password reset disk, click Next.
Step 8: Type and confirm a new Vista password.
Step 9: Input password hint, click Next.
Step 10: Click Finish when you've successfully reset Windows Vista password. You'll return to Windows Vista Logon screen.
Step 11: Enter your new Windows Vista password to log on your Vista machine.
Please Note: You must create the Windows Vista password reset disk before losing your password.
Method 2: Reset Windows Vista password with Windows Login Recovery
If you are locked out of Vista PC without a Windows Vista password reset disk, you'll need Windows Login Recovery to create one. This Windows password recovery software allows you to use a USB flash drive or blank CD/DVD to create a bootable Windows password reset disk. With it, you'll never to be worried when you need to perform Windows Vista password reset. It is also easy for you. Follow the below steps.
Step 1: Download Windows Login Recovery and install it on a computer that you could log on.
Step 2: Burn a bootable CD/DVD or USB flash drive password reset disk.
Step 3: Reset Windows Vista password to be empty.
Step 4: Log on Windows Vista without password.
on Oct 28, 2010 | Computers & Internet
I have Vista for Business on a computer. Suddenly the log on picture shows on the screen, but the computer says the user information is unavailable and won't let me log in!
This sounds like a failed update. Restart the computer and hit either F2 or F8 or possibly Tab or Delete once the splash screen comes up. This should give you a windows startup option for safe mode. Click Safe Mode with Networking and let the computer startup. This will bypass all current startup items and possible problematic services. Login and start up Task Manager. View startup items and look to see if anything is starting up that says "Windows Update" or if anything else stands out that shouldn't be there. Names that are random garbled letters, etc. Disable these for normal startup. Now click on control panel under start menu and go to windows update and see if any updates failed to install. If they did, disable install automatically in windows update.
After this go to "run" and type in msconfig. Click normal startup, hit apply, when the message that says "restart computer" pops up click yes and let it restart the computer normally.
Sep 09, 2014 | Microsoft Windows Vista Business Edition...
My dad put a parental control on my laptop and i cant get it off. it wont let me do half the stuff i want and i cant fix stuff
Alright well if in windows xp vista or windows7 go on youtube and type in how to run in safe mode one you do this youle ebter a black screen and you can take off passwords for account and parrental control and its safe i did this on my friends computer for a joke so he could log on till i told him the passowrd
Apr 02, 2010 | Dell Inspiron E1505 Notebook
Forgot password, need to reset
You can reset any user password by logging in using the Administrator account through Safe Mode. In Windows XP Home you cannot log into the Administrator account in normal mode.
When your computer is starting up, hold down the F8 key. This will bring you to a black screen with white text. Use the arrow keys to highlight "Safe Mode" and then hit enter. This will boot the computer into Safe Mode, which will look normal except the resolution will be very low. Log in as the Administrator (should have a blank password). Once logged in, open the Control Panel, then User accounts, then reset the password or whatever user you want. Reboot the machine to get back into normal mode.
Jan 20, 2010 | Dell Microsoft Windows XP Home Edition
Windows vista tm home basic key is invalid for activation. after logging on the screen is black with 3 suggestions, to purchace a new key or go to mirosoft for help. cant seem to fix this
OK NO PROBLEM TRY THIS KEY (YFKBB-PQJJV-G996G-VWGXY-2V3X8) IF THIS DO NOT WORKS YOU DOWNLOAD MAGICAL JELLY BEAM KEYFINDER IF YHE BOTH DO NOT WORKS YOU HAVE TO PURCHASE A NEW KEY.
Jan 08, 2010 | Microsoft Windows Vista Home Premium with...
Vista x64 Screen goes black after Logoff or Switch User
I'm not sure this is pertinent, but examine this article and see. Also similar post here, search links here, and FAQ link here.
I'd suggest you post in one of the MS forums, either here or here.or at this link, and you'll be asking in the midst of more vista experts.
Have you gone to the event viewer to see what kind of errors may be logged in connection with this behavior? See here, here, here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 17, 2009 | Microsoft Windows Vista Home Premium with...
I Need help with my sons laptop
when starting pc hold f8 button in menu move to last known good configuration enter,if that not helps reply with comment will go further
Jun 13, 2009 | HP Compaq Presario CQ60Z Notebook
Cant login to computer
That is a windows issue. If You have different names on the login screen try one of those. Try to get in then do a system restore.
May 25, 2009 | Medion M3 Director 5100 PC Desktop
Changed log on password
Yesterday morning, I forgot the Windows logon passwords. At last, my workmate Wayne advise Windows Password Seeker. This helpful product successfully help me get back into Windows. You can Google windows password seeker or just go to their official site: http://www.passwordseeker.com
Dec 06, 2008 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
