Question about Apple iMac G5 Desktop
About 6 months ago there were 2 colored vertical lines on my desktop screen. I've been getting more lines every 2 or 3 weeks and now have a total of 18. The nearest Apple store said they can fix it no charge, but what will it do to data on my hard drive?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
It should not affect the data on the hard drive but with all repairs such as this it always worth making sure you have your hard drive backed up. I had a similar problem with a imac a couple of years ago and the hard drive was fine when it came back. Hope this helps.
Posted on Nov 14, 2010
Hello, I bought an LG 47LH50 HDTV exactly 1 1/2 years ago. Black horizontal lines suddenly appeared one night after getting home from work. Over the past two weeks I've seen it go from 3 lines, to 4...
Hi, I purchased the same model in November 2009. About 2 weeks ago a single horizontal line appeared. Each day another appeared until today when the video went out. Now it displays bands of vertical colored lines like a pastel colored rainbow. Did you find a solution to the problem?
Jun 04, 2011 | LG 47LH50 47 in. HDTV LCD
Vertical lines on my lcd laptop screen
It's the connector problems.
If you know what to do, I can guide you:
First, remove the screw all over the LCD case, then you can see the connector, and flexible cables.
Second, remove the keyboard unit(by removing all screw on the unit), after removed, find the edge of the LCD cables, then you can see the connector.
The solution:
1.Try clean this two connector with soft brushes ( paint brush is good ), by removing the cable first,then clean the flexible connector using wet tissue ( use the alcohol ).
2. If still exist, you need to replace the flexible with new ones.
Feb 26, 2010 | Dell Inspiron 6400 Notebook
My Ibm Laptop r51 has a vertical lines on the screen
The lines appearing on your LCD means it has a defect on the screen.
There are 3 types of pixel defect
1) dead pixel - pixel is always off
2) stuck pixel - pixel is always on
3) hot pixel - pixel is on but in red, green, blue or yellow, can also be a light black color
You can try to fix stuck or hot pixels but dead is dead.
1st method, flashing different colors rapidly:
JSScreenfix.com has a great tool. This is their free java applet or you can download it below.
2nd method, applying pressure to pixel:
Damp paper towel, Small stylus or dull pencil.
3rd method, tapping the pixel:
Pen with cover on or another small, blunt object.
If your laptop is still under warranty, get it replaced. If not you are looking at the most expensive part in a laptop to get replaced. (LCD screens on laptop is roughly equivalent to 40-60% of the total laptop cost
Please rate this if it this helps.
Jun 02, 2009 | IBM ThinkPad R51 Notebook
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Vertical lines in screen
Are the Lines Symetrical in distance and space? Makes a diferernce..
Jan 21, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
Gt4010
Get a new  Motherboard. See if that works, seems like you've checked everything else.  Good Luck!
Oct 14, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Apple iMac G5 Desktop Logo
183 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
