Question about White Sewing 1409 Mechanical Sewing Machine
How do i thread my machine - White Sewing 1409 Mechanical Sewing Machine
  • 340 Answers
Do you have a manual?
you can download a manual from the SInger site.
http://www.singerco.com/accessories/manuals.html
Just type in w1409 and click on search.
Choose the free download option that corresponds to your machine.
The manual will show you how to thread the machine.
Hope this helps!
Posted on Nov 15, 2010
Serger machine not braiding
Remove all the threads from the machine.
Be sure, when you thread the machine, you ALWAYS RAISE the presser foot. Also when threading from the thread tree down through the tension disk, give each thread an extra little tug to make sure it is seated.
Always thread each thread in the order specified. Threading out of order will guarantee failure. If a thread breaks, start over with no thread in the machine.
Jul 27, 2017 | Sewing Machines
After threading the machine, start to sew and the thread breaks it seems that it gets caught in step 4 in Threading The Machine in the manual.
Not knowing the make & model of the machine limits out ability to help. What is Step 4? When threading the top thread, ALWAYS RAISE the presser foot. Verify that the thread path is correct--mis-threading is a frequent cause of broken thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Mar 16, 2017 | Sewing Machines
Why does my machine break the thread a lot? A juki cp 130
tension too tight or incorrect threading, or bad thread.
Mar 13, 2017 | Juki Sewing Machines
The thread continues to break
Install a brand new needle--one that matches the type of thread and fabric you are sewing. If the thread is shredding at the needle, then the needle's eye may be too small for the thread.
All About Needles
Avoid using old or bargain bin thread. Try a different type of thread.
Check that the thread is threaded correctly in the machine and that it is not wrapped around the thread spool or a thread guide. Also, set the upper tension to the midway point, ie the tension could be too tight.
Why Does My Top Thread Keep Breaking Sewing Machine
Oct 17, 2016 | Sewing Machines
I need to know how to thread a empisal purdy 444 sewing machine
Most machines thread basically the same.
Thread spool
Thread guide
Thread guide
Tension
Take up lever
Thread guide
Thread guide
Needle.
There may be an extra or one less of the guides but for the most part I've been able to thread any machine.
Good luck and god bless
Angela
Sep 11, 2016 | Sewing Machines
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
NMSU Checklist of Common Machine Troubles
Why Does My Thread Keep Breaking While Sew
Aug 27, 2016 | Brother ES2000 Computerized Sewing Machine
Bought machine at a garage sale. It works but no Manuel of instructions. Need to know how to thread it.
If you can't download the manual, try putting the thread on the spool holder with the thread coming off the spool toward the back of the machine. Be sure your fly wheel is turned toward you until the need is in its highest position. With the end of the thread, work your way across the top of the machine to the left, staying toward the back of the machine, threading through any thread guides as you go. There may only be one. Bring the thread toward the front of the machine and through the thread guide at the top front of the machine, then down on the right side of the tension knob and back up to the needle carrier. Then pull the thread down through any thread guides until you get to the needle. Thread the needle and pull the tail of thread to the back of your machine. Load your bobbin into the bobbin case, insert the case into the machine until you hear a click (you may need to rotate the case slightly to get it into the machine.) turn your fly wheel toward you while holding that top thread toward the back of the machine until the bobbin thread comes up. Pull the bobbin thread up and to the back of the machine an you are ready to go! Good luck!
Jul 22, 2014 | Sewing Machines
How to thread the machine
Hello
Place spool of thread on the spool pin, found inside the carrying handle on the top right side of the machine facing the back.
Lead thread through the upper thread guide, located just beyond the machine's handle.
Lead thread through the second upper thread guide, found a few spaces to the left of the first upper thread guide mentioned in Step 2.
Bring thread around the second upper thread guide down into the thread guide.
Lead thread toward you down through the tension discs.
Continue to pull thread down through the ****. Forming a "U" shape, bring thread back up the left side of the guide, catching the check spring as the thread moves back up through the guide on the left side.
Bring thread up to the take-up lever and insert thread through the eye of the lever in a right-to-left motion.
Lead thread downwards, slipping it down through the horizontal thread guide.
Guide thread through the wire thread guide that is attached to the needle clamp.
Insert thread through needle from front to back, pulling thread four to six inches to create a thread extension. The machine is now threaded.
Aug 01, 2011 | Euro-Pro Shark Mini Mechanical Sewing...
How do i thread this machine
thread this machine by taking a strain of thread from the spool pull it to the thread guide on top left side of machine criss cross the thread when you wrap it around the thread guide pull thread down and loop it under the needle thread tension control dial bring thread up and loop it on the thread take up lever, continue down to the needle looping it first around the metal piece above it then through the needle it self pull thread to back of sewing manchine with the bobbin thread
Feb 12, 2009 | Brother LS-1217 Mechanical Sewing Machine
White Sewing 1409 Mechanical Sewing Machine Logo
107 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
