Question about Mr. Heater Natural Gas Garage Heater - 45,000 BTU
How big of a breaker do i need to install for a 45000ng mr heater big maxx?
  • 308 Answers
It looks like a 15 amp breaker would be fine, here is the spec sheet
http://shopfnc.com/pdffiles/mhu45spec.pdf
As you can see the unit only pulls 3 amps.
Hope this helps
Posted on Nov 17, 2010
Mr. heater big maxx keeps blowing fuses, Replaced everything in it and still does it. sometimes it will run for a while
Maybe its the wire or the outlet. Does the wire get hot? Try a different outlet that is on a larger amp breaker.
Dec 07, 2016 | Mr. Heater Heating & Cooling
Mr heater big maxx constantly blowing its 3 amp fuse.
Check 24 volt wiring That would be wiring from your thermostat to heater
Nov 21, 2016 | Heating & Cooling
No spark. My HSU75NG MR. Heater (Big Maxx) will not start on its own. It purges fine ,calls for heat fine, gas flows fine; BUT there is no spark from the Electrode Igniter. Which I have replaced. The
The capacitor in that unit is for starting the motor that drives the blower fan. It has no impact on the ignition of the gas burner. On the control board, there is a light that should be flashing, can you tell us how many times it is flashing?
Feb 18, 2014 | Mr. Heater Natural Gas Garage Heater -...
I have a mr. heater big maxx. It is a 75000 btu natural gas. The preasure switch failed closed/open. How do I reset it? Or do I have to replace it?
the vent pressure switch will have a rubber type hose off it to the combustion fan housing. pull the hose off and poke the conector with a paper cilp or wire to make sure it is not plugged at the housing. make sure the vent fan is running and jumper the switch if it comes on replace the switch if not look else where for your problem.a volt meter is a great tool . voltage across a switch means it is open and no voltage means its colsed. i should say to also check your venting as it maybe blocked. there is no reset
Feb 01, 2011 | Mr. Heater Natural Gas Garage Heater -...
Open Questions:
See all Mr. Heater Natural Gas Garage Heater - 45,000 BTU Questions
Mr. Heater Natural Gas Garage Heater - 45,000 BTU Logo
223 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
