Question about KitchenAid Dishwashers
Works fine. model #KUDI220T4 was in when we bought the house. We have no idea how old it is. We have lived in the house for 12 years. Could you provide age of dishwasher. We are remodeling and need to decide if we should replace it. serial # FAD503917
  • 1462 Answers
SOURCE: Leaking door (Running Water)
being in the uk i dont know this appliance, but the fault is probably that it is overfilling caused by crap in the airchamber or the hose leading to the pressure stat blocked or a split in this hose
Posted on Apr 15, 2007
SOURCE: Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Posted on Feb 20, 2009
whytfang
  • 170 Answers
SOURCE: I have a ge nautilus built in dishwasher and do
You can find them on a label on the tub wall just inside the door. However 99% of all DW are a standard size and the difference is made up by adjustments of the threaded leveling /adjustment legs.
Standard size is 24" x 32-36"...you can take a tape measure and measure from the floor to the bottom of the countertop it is to be installed under...and then measure across the front of the DW. you should find my measurements to be within this range unless it is a custom unit.
Hope this helps. ...good luck and good day...The Fang
Posted on Mar 28, 2009
SOURCE: Fisher&Paykel dishwasher does not clean dishes
We have one too and it cleans the dishes really nicely. However, you have to be sure you look after the filter screen. Hard water could also be a problem if the detergent you use does not have an additive in it and you should always use a rinse agent (pour it into the reservoir in the front).
In order most likely and easiest first: 1) Be sure nothing you put in the racks goes below the level of the rack. If it does it will block the spray arm from turning and you will get semi-cleaned dishes and soap streaks as you describe. My sister had the same problem and swore nothing interfered with the arm, but the way she loaded some things permitted them to move during the first few revolutions of the rm and stopped it. Check to see if the arm rotates freely for about two rotations after a load is finished and the conditions you describe appear. 2) Check the filter screen located in the bottom of each drawer under the silverware holder. You have to lift the hinged portion of the rack to get to it. Clean it well and reinstall it. It should be checked every three loads, or once a week at least. 3) Then check the holes in the spray arm to be sure they are open. If plugged clean them out carefully. 4) Then if that does not work, dissamble the arm, and motor (covered in the instructions or available on line, and be sure nothing is plugged in those areas. 5) Cll a repair man who really knows the unit - not all do and they can do more harm than good.
The unit will clean very well. Good luck!
Posted on Apr 25, 2009
jsrock516
  • 5911 Answers
SOURCE: I require a manual for a Maytag jet clean
Your dishwasher was manufactured in November of 1986. Uh...its actually 23 years old, which could be why I had a hard time locating a manual for you. I was able to find a manual at the following link:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MDB6000AWW&siteCd=MT_EN_US#owners_manuals
There's an Owner's Manual and Installation guide listed.
If you need further assistance, please let me know. I hope this helps you.
Posted on Oct 15, 2009
Testimonial: "Thank you for the quick response. Much appreciated."
Is the internet article about the 60 year old pristene house true. It says it wasnt lived in for 60 years and yet still has pristine appliances. What happened to rust?
If you mean the kitchen with the pink exterior, you might want to ask the person that bought the house in 2010 directly. He's still selling the unused appliances.
Feb 24, 2015 | Cars & Trucks
How old is the Whirlpool washing maching model # LSQ9549PWO...ser CR3028092?
July 19, 2004. go here and you can tell how old any appliance is by putting in the model,serial numbers and brand name.http://www.appliance411.com/service/date-code.php
Jan 24, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a amana ssd21sw and it just quit working. it was in the house when i bought it and i have no idea how old it is. i was just wondering if it is worth fixing or not
did noah live in the house before you?(bad joke)
replacing is probably the best bet as a modern unit is much more efficient and effectively cheaper than replacing parts/call out costs...
Jul 16, 2010 | Amana Refrigerators
Vulcan C-X Gas Furnace Model 902
If you bought the house, did your hire a house inspector to check everything out? You can go back to him and have him double check his evaluation. I even got my inspector to pay for half of a repair when something broke right away after we moved in. If you are renting the place, ask the landlord to send a furnace repairman to do an annual inspection and cleaning on it. Just a few ideas for you to consider for peace of mind.
May 16, 2010 | Heating & Cooling
Age of dryer
the production date is on a tag on the back of the dryer, this model has been around about 12 years
Apr 07, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Need user manual for Temco Model ADL36-2 Vent Free Gas Fireplace
need a fireplace log for temco fireplace, serial number 10807, model number adl 36-2. middle log is missing.
Dec 21, 2009 | Computers & Internet
No Power at all
If it came installed in the house, it may have its own breaker switch. I'd check the breaker. Have any outlets in the kitchen gone out as well? This would support the breaker switch idea.
Hope this helps.
Jan 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Apr 15, 2007 | GE 24 in. GSD4630Z Built-in Dishwasher
Dishwashers Logo
70 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
