Question about Bosch Nexxt WTMC 3300 Electric Dryer
Lint light wont go out and dryer wont run . - Bosch Nexxt WTMC 3300 Electric Dryer
  • Bosch Master
  • 2,605 Answers
Hello, Welcome to FixYa.
There are a couple of scenarios which may prevent the dryer from starting with Bosch.
To save time and back and forth dialog, I`ll mention the most likely and what to do about it.
**Unplug the dryer before attempting any repair tips suggested here please...safety first**
There is an auto shut off or emergency kill switch next to the motor which will prevent it to start in the event it was tripped for whatever reason.
This is the most likely scenario in my opinion as it often happens to even trained techs when the unit is re-assembled. there is also a hi-limit overtemp. cut-out ( safety limit switch )...
lint light wont go out and dryer wont run . - macmarkus_58.jpg ...but we'll address that next. This will require you to remove the back panel again though. Once you've remove the rear panel, It will look like this image below and all you need to do is push it to the right ( from the back )... macmarkus_57.jpg Below is an illustration from a Bosch service manual...
Either Scenario I alluded to will require the removal of that panel so let me know if you require further assistance to do this.
The other would be resetting the hi-limit cut out I alluded to, it can be seen through the back vent opening when the vent is removed and then by pushinlint light wont go out and dryer wont run . - 923283f.jpgutton in...shown below.
i.e.
Keep me posted how you make out or if anything is not clear.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Nov 14, 2010
My dryer was running now it wont restart and the light next to filter is flashing
Most likely a buildup of lint. If you haven't already cleaned the lint filter, do that first. If you have, then remove it and look in the slot that it goes into to see if there is a buildup of lint that has gotten past the filter screen. Use a vacuum with crevice tool to try to clean out this area, or a small brush (even an old toothbrush) to get any lint that may be blocking the sensor and causing the dryer to not work. Unplugging the dryer, waiting 30 seconds and then reconnecting, should re-set this error.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jan_ed8272c8c2968d14
Jan 05, 2015 | Dryers
Electric dryer wont run
what's the model number,first thing to check is the door switch,if the switch is bad or broke some have a paddle on them that can snap off if door is closed to hard or dryer hasn't been cleaned out and one of the thermostats or thermal fuse is popped because the lint is blocking the air movement and dryer got to hot and as a safety the t-stat or fuse pops.
Jan 07, 2014 | Kenmore Dryers
Check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Dec 23, 2009 | LG Dryers
My dryer check lint screen light continues to blink and the dryer wont work even after cleaning lint screen
Airflow through the dryer vent is restricted. Blow through the filter opening with a reversed vaccum cleaned. Set it BLOW instead of **** usually by putting the hose on the exhaust end.
Dec 14, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer wont run, Lint Filter Light comes on. Lint Filter is clean
your vent could be pluged going out side
Dec 06, 2009 | Dryers
Dryer wont start
Push on the door switch and make sure the light goes out. When the light goes out, a contact should be made to allow the motor to run. If you can get to the timer, spray a good electronic contact cleaner inside while rotating the dial. While you have the unit open, vacuum out all the lint, and check for loose wires, especially to the door switch.
Apr 14, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer wont run
Remove the rear cover and replace the skinny white fuse mounted on the blower housing after you have cleaned out the lint from the dryer. (unless you like to keep buying and replacing them)
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 27, 2009 | Kenmore 62602 Electric Dryer
Hotpoint dryer
Completely disassemble your vent from the dryer to where it exits the building. Clean out all lint. Disconnect the dryer from the electrical service and check for lint build up inside the machine. This lint build up usually makes the motor shut down on it thermal overload. Check the motor also to see if the air vents on it are blocked with lint. If no lint is present, the motor or the start relay need to be replaced.
Oct 24, 2008 | Hotpoint NBXR463EBWW Electric Dryer
Front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Nov 21, 2007 | LG DLG2524 Gas Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
339 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
