Question about ACP Cavalry (CAUE37500) 500 GB USB 2.0 Hard Drive
It's important - ACP Cavalry (CAUE37500) 500 GB USB 2.0 Hard Drive
  • 4,472 Answers
Http://www.crashed-hard-drive.com/data-recovery-services/external-hard-drives/cavalry-data-recovery.htm
your best bet is to go through a place like this unless you want to rip out the hard drive and try and put it in another computer but that will still not get you your data as you believe you deleted a bad file. These people are usually very good at what they do.
Let me know. If it's possible and you find any of this helpful I hope you will re-rate our chat session as such.
Keep me posted,
Lee
Posted on Jun 18, 2008
  • Lee A.
    Lee A. Jun 19, 2008
    I'm sorry I don't understand why the rating? Was there something more you needed? I am happy to assist you further.
    Thanks,
    lee
How do you import CDs into iTunes?
Copy music from a CD to iTunes by following these steps:
  1. Insert a music CD into your computer. Notice that iTunes opens automatically.
  2. In the list that appears, use the checkboxes to select or deselect the songs you want to import. Songs that are selected will be imported.
  3. After you've selected the songs you want to import, click the Import button. iTunes will begin copying the music from your CD to your iTunes music library.
  4. After the songs are imported, click the Eject Disk button.
  5. Select Library in the Source list to view all the music in your iTunes library, including the songs you just imported.
Of course, if you want to import CD to iPhone, you can also read this guide. How to Import CD to iPhone
Oct 08, 2015 | Audio Players & Recorders
How to set timing for 97 chevy 7.4 454ss vin j ?
yuo need to look at the passenger side firewall and look for a black cover box against the forewall with 3 black long lug nuts looking things there plastic as well remove them and you will find wire connector if not remove the negative battery cable from the post on the battery and do it this way now to do this properly here are my steps ! My Name is Bobby im A Vo-Tec tech mechanic from NewYork . I have great news for you so please listen up just incase you still can not fire up your engine i will give you these simple instruction that no one will give to you out there ok . First reset your timing with number one piston all the way up at top dead center on the compression stroke by taking out the number one spark plug and take a 1/4 inch peace of stick with a plastic bag over it and wrapped real tight and stick it into the plug hole where its snuged fit in to the spark plug hole now using your ignition key to click the engine over little by little until you hear a blast pop sound that will be the stick with the plastic popping out of the # 1 cyclinder spark plug hole now your engine is at top dead center on the compression stroke now look down at your harmonic balancer the crank damper with the groved straight line back the engine crank counter clock wise till that line faces #0 on the timing marks plate above it leave it at 0 degrees now take your distributor cap off and see to make sure the the rotor is facing # 1 cyclinder if not take the negative by CutThePrice" style="font-size: 13px; color: rgb(22, 122, 198); left: auto; opacity: 1; top: auto; font-family: Roboto, arial, sans-serif; line-height: 17px; margin: 0px 0px 0px 3px !important; padding: 0px !important; border: 0px !important; box-sizing: border-box !important; bottom: auto !important; clear: none !important; display: inline-block !important; float: none !important; height: auto !important; max-height: none !important; max-width: none !important; min-height: 0px !important; min-width: 0px !important; overflow: visible !important; position: static !important; right: auto !important; text-transform: uppercase !important; -webkit-transform: none !important; transform: none !important; vertical-align: baseline !important; visibility: visible !important; width: auto !important; word-wrap: break-word !important; zoom: 1 !important; z-index: auto !important; font-weight: 700 !important; background-image: initial !important; background-attachment: initial !important; background-size: initial !important; background-origin: initial !important; background-clip: initial !important; background-position: 0px 0px !important; background-repeat: initial !important;">BATTERY CABLE off the battery and unplug the grey and white wire located on the firewall under the plastic cover it will be a single grey and black or white striped wire unplug that connector take distrubtor completely out of engine and reset it in so the thumb button rotor is facing # 1 cylinder ok now put your bolt back in and tight it just snugged for now until later on as you will have to rotated later now put your cap back on and look at the cap where you tighten the 2 screws down the screw in the front looking at that and at the top of the cap where the plug wires go count 4 plug inputs counter clock wise and start # 1 spark plug wire from there going clock wise fireing order now thats it now before hooking the negative battery cable back up make sure your number one spark plug is back in place with the wire on it ok now turn your head light switch on and off 5 - 7 times and now hook up negative battery cable back on it post and hook up the advance grey and black or white striped wire and now fire up your engine still no start turn the distributor clock wise till it starts and now your set have a nice day and dont forget to tighten the distributor down once you have it set to its right idle ok have a nice day !
Aug 25, 2014 | 1995-1997 Chevy 3500 Truck Ignition...
I have a back up of my emails from outlook 2010 in a hard drive. I shows its file format as .pst. I need to import these emails in mail.app. How to import pst files in mail.app? Using import function...
Making IMAP Account
Well creating an imap account can help you.
You have to simply make imap accounts on both the email clients you use and then you can upload you emails from outlook and then download on the other hand in apple mail.
Other alternative
You can also use the software approach to solve your problem.
Various softwares/applications/third party tools are available online.
One I am aware of is Pst Converter pro.
Hope this helps
thank you
Oct 16, 2013 | Microsoft Outlook 2010 for PC...
What is causing an HP LaserJet 8150 Error 82.0180?
It's from your jet direct card. Turn off the by weDownload Manager Pro" style="background-color: transparent !important; border: none !important; display: inline-block !important; float: none !important; font-style: normal !important; font-variant: normal !important; font-weight: normal !important; font-family: Arial, Helvetica, Verdana, Tahoma, sans-serif !important; height: auto !important; margin: 0px !important; min-height: 0px !important; min-width: 0px !important; padding: 0px !important; vertical-align: baseline !important; width: auto !important; text-decoration: underline !important; background-position: initial initial !important; background-repeat: initial initial !important;">printer andarrow-10x10.png pull out the network card. Turn the printer on and verify it goes to ready. Turn off and reseat the card and see if the printer comes to ready.
If yes - upgrade the jetdirect firmware and by weDownload Manager Pro" style="background-color: transparent !important; border: none !important; display: inline-block !important; float: none !important; font-style: normal !important; font-variant: normal !important; font-weight: normal !important; font-family: Arial, Helvetica, Verdana, Tahoma, sans-serif !important; height: auto !important; margin: 0px !important; min-height: 0px !important; min-width: 0px !important; padding: 0px !important; vertical-align: baseline !important; width: auto !important; text-decoration: underline !important; background-position: initial initial !important; background-repeat: initial initial !important;">the printerarrow-10x10.png firmware
If no, try the other EIO by weDownload Manager Pro" style="background-color: transparent !important; border: none !important; display: inline-block !important; float: none !important; font-style: normal !important; font-variant: normal !important; font-weight: normal !important; font-family: Arial, Helvetica, Verdana, Tahoma, sans-serif !important; height: auto !important; margin: 0px !important; min-height: 0px !important; min-width: 0px !important; padding: 0px !important; vertical-align: baseline !important; width: auto !important; text-decoration: underline !important; background-position: initial initial !important; background-repeat: initial initial !important;">slotarrow-10x10.png.
If that still doesn't work, try a cold reset with the card installed (hold down the green button as you power on, in 5-10 seconds the display will flash cold reset and you can let go and see if the printer comes to ready) Good luck! :)
May 25, 2012 | HP LaserJet 8150 Printer
Properties in importing excel table to an access table
This article explains how to import a Microsoft Excel file into Microsoft Access version 2.0 or 7.0. Microsoft Access can import files from Microsoft Excel version 2.0 through version 7.0. However, Microsoft Access cannot import Microsoft Excel 4.0 workbooks (.xlw). This article assumes that the Microsoft Excel file is using standard database formatting. That is:
To import a Microsoft Excel file in Microsoft Access 2.0 loadTOCNode(2, 'moreinformation');
  1. Save the file in Microsoft Excel using standard database formatting listed above. Close the file.
  2. Start Microsoft Access 2.0 and open the database you want to import the Microsoft Excel information into.
  3. On the File menu, click Import. From the Import dialog box, choose the appropriate version of Microsoft Excel that you are importing and click the OK button. Microsoft Excel 7.0 files are not on this list. If you are importing a version 7.0 file, choose the Microsoft Excel 5.0 option.
At this point options such as whether to append to an existing table or create a new table may be selected.
To import a Microsoft Excel file in Microsoft Access 7.0 loadTOCNode(2, 'moreinformation');
  2. Start Microsoft Access 7.0 and open the database you want to import the Microsoft Excel information into.
  3. On the File menu, click Get External Data and then click Import.
  4. From the import dialog box, choose Microsoft Excel (*.xls) for the Files Of Type option.
    This will display only the Microsoft Excel files.
  5. Find the desired file and click the Import button.
The Import Spreadsheet Wizard appears and allows you to choose options specific to the file.
or you just use the link for any problem where you can get details of the importing
http://www.techrepublic.com/article/techniques-for-successfully-importing-excel-data-into-access/5276622
May 05, 2011 | Computers & Internet
About java swing..
Hi, if you have a specific query about java Swing, I can try to help you. Please find a small java code with using swing as example.
import java.awt.BorderLayout;
import java.awt.Font;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.event.WindowAdapter;
import java.awt.event.WindowEvent;
import java.awt.event.WindowListener;
import javax.swing.AbstractAction;
import javax.swing.Action;
import javax.swing.ButtonGroup;
import javax.swing.ImageIcon;
import javax.swing.JButton;
import javax.swing.JCheckBoxMenuItem;
import javax.swing.JFrame;
import javax.swing.JMenu;
import javax.swing.JMenuBar;
import javax.swing.JMenuItem;
import javax.swing.JRadioButtonMenuItem;
import javax.swing.JToolBar;
public class ToolbarDemo extends JFrame {
public static final String FontNames[] = { "Serif", "SansSerif", "Courier" };
protected Font fonts[];
protected JMenuItem[] fontMenus;
protected JToolBar toolBar;
public ToolbarDemo() {
super("Toolbars & actions");
setSize(450, 350);
JMenuBar menuBar = createMenuBar();
setJMenuBar(menuBar);
setVisible(true);
protected JMenuBar createMenuBar() {
final JMenuBar menuBar = new JMenuBar();
JMenu mFile = new JMenu("File");
ImageIcon iconNew = new ImageIcon("file_new.gif");
Action actionNew = new AbstractAction("New", iconNew) {
public void actionPerformed(ActionEvent e) {
System.out.println("new action");
JMenuItem item = mFile.add(actionNew);
mFile.add(item);
menuBar.add(mFile);
toolBar = new JToolBar();
JButton saveButton = new JButton("Save");
toolBar.add(saveButton);
getContentPane().add(toolBar, BorderLayout.NORTH);
return menuBar;
public static void main(String argv[]) {
new ToolbarDemo();
Thanks and Regards,
Supa.
Mar 10, 2009 | Microsoft Internet Explorer 7
ACP Cavalry (CAUE37500) 500 GB USB 2.0 Hard Drive Logo
115 people viewed this question
Top ACP Computers & Internet Experts
David Payne
David Payne
Are you an ACP Computer and Internet Expert? Answer questions, earn points and help others
