Question about Lands Phones
I have a PacTel Meridian phone system with a star talk mini since 1995 We had a power outage and 2 of my 4 lines do not ring on the phone you cannot use the touch pad when your calling a company when requesting push 1 or 2 . The rest of the system is working can pick up calls, caller iD only comes through when it rings at ext and as stated when you use line 3 or 4 the line does not pickup. If a call comes in on those lines it just rings on intercom. Please help as I cannot find anyone that services in the Stockton, CA area. Steve Spurgeon 209-474-8134 x 23
  • 2460 Answers
SOURCE: Incoming Call not Ringing
Either call line 3 first, or make your phone ring :-)
What might be the easiest is to swap modular plugs in the back room between 2 and 5. That way, you get your old extension back and everything will work as it did.
If you can't do that, then you're going to have to do some system programming to turn on the ringing on your phone. If you have a TA series system, you should be able to do it from either the PC or a phone connected to jack $1. If you have another model, you should have a system manual on how do make programming changes.
Posted on Sep 04, 2008
  • 32 Answers
SOURCE: My Nortel Meridian M2008 phone will not ring
it may be turned down to the program key and use the scroll bar below the keypad to find your option...hopes this helps
Posted on Dec 20, 2008
SOURCE: Stop ringing at main phones when outside calls come in.
Here is a link to program line ringing.
It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
From any display phone, press Feature 11
then enter your extension number 2 times. So if you are extension 20, do this:
see if that does it.
Posted on May 28, 2009
SOURCE: nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Posted on Jun 27, 2009
  • 860 Answers
SOURCE: How do you program so that when the phone rings
Sets that are programmed to ring should automatically have ringing line preference.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS.
The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
press the heading key (top left arrow) til the screen says terminals&sets again
Prime line assignment is also programmed at the terminals&sets prompt.
press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the prime line on.
The display should say Line Access
The display should say Line Assignment
Press the next key (bottom right arrow) .
The display should say Line Pool Access.
Press the next key (top right arrow)
The display should say Prime Line
Press the Chng soft key till you get to the desired line or pool to pick up on
Press the release key when finished
Posted on Oct 19, 2009
How can I get line 1 to ring? My Line 2 and 3 will ring but not line 1.
This has to be done in programming. Have your system administrator make the change on your extension.
Oct 31, 2013 | NorStar Meridian M7310 Phone
Meridian M8X24-DS System Problem - All handsets are blinking on all lines
Sounds like a defective software cartridge
try a swap and see if flashing stops
Nov 26, 2007 | NorStar Meridian M7310 Phone
My store had a huge power outage where the lines were sparking. Anyway since the power has come back on I have no ring & can not dial an extention after i dial a phone number. I have looked in the...
So you're saying you can dial a phone number, but when the voicemail system answers you can't dial an extension number ? If that's the case, that means your phone system reset. Generally that means all phones will have access to only line 1 and 2, and that they'll be ringing on all phones. The date would usually change to Jan. 1st 1980, but caller-ID might override that. All line programming would be set to pulse, which would be the cause of you not being able to dial an extension number a voicemail system answers. It would also mean that when you do dial a phone number it takes a while before you hear it ringing. (Because the phone system is dialing in pulse instead of tone, if you stand next to the phone system you'll probably hear it go)
... Long story short, your entire phone system needs to be reprogrammed. I suggest only doing a partial reprogramming, then unplugging the power for a few minutes and check to see if the programming stuck. If not, the battery in your system also needs to be changed.
May 20, 2011 | Nortel Meridian M7208 Corded Phone
We had a power outage, main system box making sound like a rotary phone when I dial.
The battery in your phone system is dead. This will happen every time you have a power failure. Everything resets. Date becomes Jan 1st 1980 (but might update if you have callerID), all phones will have access to only line 1 and line 2, both those lines will ring on all calls, and the line settings are set back to pulse ...
Ideally you either have the battery replaced (it's soldered on the board of the system), or you get a new phone system. Otherwise you'll have to reprogram everything when you have a power failure.
Jason the phone guy
May 10, 2011 | Nortel Meridian M7208 Corded Phone
Power outage now you have to select a line manually instead of just picking up phone and it's taking awhile before it starts ringing
What usually happens after a power outage is the system defaults because the backup battery in the memory card is dead. That means 2 lines only on every phone, pulse dialing, and all phones ring. If your system looks like that, it's time to call the Nortel repair tech. He can replace the battery or software module with a new one and reprogram the system.
Aug 17, 2010 | NorStar M7324 Corded Phone
Since power outage phone lines do not ring - only to receptionist
Your system lost its programming. It will need to be reprogrammed completely. The lines are ringing on the extensions where I voicemail is, unplug voicemail and at least lines will ring in correctly.
Jun 15, 2009 | Avaya Lands Phones
Our office has 13 phones all the same. Some of the phones do not ring. I would like to get one of the phones to ring. It is a Norstar Meridian M7310
You will have to go into system programming, under sets, line appearances. You will need to set the lines on the phones to appear and ring, not just appear.
Dec 08, 2008 | NorStar Meridian M7310 Phone
No ring and appear on my Norstar M7310
This should work on M7310, M7324 & T7316
Feature ** 266344 - password 266344 - configuration - line data - line access - show ext (yours) - line assignment ( which lines you have, usually 1 & 2) - show line - appear only/ring/apprear and ring
Hope this helps
Oct 02, 2008 | NorStar Meridian M7310 Phone
Help Request
Do you have any programming experience on your system ? Is seems like the line has to be asigned to the phone it is ringing on but you will have to do that in system programming.
Jul 28, 2008 | Lands Phones
Meridian M7310 phone system
We had a tech come in who has worked on the system a long time ago and he said because of the power surge it fried the Star Mini. He said they are hard to get and may have to search on Ebay. We only had a battery backup instead of a UPS.
So for now we are without voicemail.
Mar 17, 2008 | NorStar Meridian M7310 Phone
Lands Phones Logo
66 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
