Question about Avanti 310SST Compact Refrigerator
Need instructions to reverse the door on an Avanti BCA5003ps refrigerator
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Reverse door
Good morning friend, I appreciate your post!
I see you are trying to reverse the door for your Frigidaire top mount refrigerator, FFHT2117PS. I have successfully located your manual and it provides step by step instructions on how to reverse your doors. Hope this helps. -Matt
Frigidaire Manual Search Results
Jul 23, 2014 | Frigidaire FFHT2117PS 21 Cu. Ft. Top...
Reverse hang door
Contact Avanti, they will have a kit with reverse hinges etc.
Nov 22, 2013 | Avanti WCR5403SS Compact Wine Cooler
Makes ice but will not dump the ice,
Hi,If you have a steady blinking light when you open the door then the sensor is working. In these cases the problem is usually in a bad motor or thermostat in the icemaker.
The solution is to replace these parts, If you need I can give you instructions on how to change these parts.
Thanks and Good luck
Jun 24, 2010 | Avanti (WDE79BSS)
My Avanti WC 601 is not cooling. The compressor is not on, however I was able to knock it and it did go on for a few minutes.
replace the rtc overload contactor located on the compressors body the relay is weak and not holding anymore,remove the spring wire that holds the overload and capacitor unplug the overload from the compressor and reverse procedure to install
Jan 16, 2010 | Avanti WC601CL Wine Cooler
Not getting very cold
thermoelectric needs a good heat dissipation. Give the unit a good ventilation to dissipate the heat, you will cool the unit. The cooler the ambient, the cooler the box. Remember not to reverse the switch, you will get a heated box instead.
May 24, 2009 | Avanti Compact Thermoelectric Refrigerator
Will not keep cooling shuts off
Sounds like a your problem may be in the thermostat. Reason I say that is because when you leave the door open it continues to run and freeze and frost is seen on the freezer walls. I just think maybe the thermostat has become less sensitive to temperature change. To test this unplug the freezer and connect the 2 wires to the temp control together. Then the refrigerator will run continuous until unplugged. Let me know, Sea Breeze
May 21, 2009 | Avanti Compact Thermoelectric Refrigerator
Have an avanti refrigerator model #FF82. and the door to the chiller room, which is under the freezer, needs to be replaced. How do I go about replacing this door?
Hi, I have an Avanti refrigerator model FF82 and there are no shelves inside. Are there spare parts available. There is only a chiller room and 1 bin on the bottom. Thanks
Apr 26, 2008 | Refrigerators
Avanti 310SST Compact Refrigerator Logo
23 people viewed this question
Top Avanti Refrigerators Experts
John Tripp
John Tripp
john h
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
