Trying to hook up wii to our insignia tv but no plugs to plug into...no where to plug the red, white and yellow plugs..help.
  • 35 Answers
SOURCE: hooking up wii
you can do it multiple ways. like putting the cords into the dvd then putting the dvd cords into the tv, or put it into the tv, or hook it up to satilitte and hooking up to the tv. your choice.
Posted on Dec 26, 2007
doctorul_doc
  • 4 Answers
SOURCE: dvd connection
What input did you chose?
Posted on Jan 13, 2008
TBlessed 1
  • 61 Answers
SOURCE: Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
Posted on Dec 01, 2008
SOURCE: Connecting Wii to Emerson 37 in LCD tv
Finally found the correct point of entry to tv and correct channel on my own.
Posted on Dec 26, 2008
SOURCE: TV connections- Wii, Direct Tv and DVD palyer
Hidden switch for output coonections on back panel of dvd player.
Posted on Dec 29, 2008
Hook up to the Wii
Alright so first of all, you should have gotten a cord with a big, grey power brick attached to it. Plug the end in that goes in a outlet, and the other end should hook up to one of the outlets on your Wii console. Then, there should be a cord with three branches. They should be colored red, orange/yellow, and white. On the back/front or on the cable box for your TV there should be plug-ins that are colored either red, white, green, blue, or orange/yellow. The specifications should be written under the outlets (visual, audio, etc...). Plug the white and red part of the cord in to the "audio" outlet (on your tv). The other cord (yellow/orange) should plug in to the outlet that is labeled "video" or "visual" or "screen" or something along the lines of that. The next step is pretty simple. Your Wii (should have) came with a sensor bar. It is thin, long, and black and has a very long, very thin cord attached to it. Plug one side of the cord into your Wii console, and the actual sensor bar goes on top of your TV. There are small, sticky rectangles that help with the sensor bar sticking to your TV. After you've done all that, your Wii is ready to go! Just push the power button and your ready to start playing!
Nov 28, 2013 | Nintendo Wii Console
Wii does not show up on the tv screen
This problem is likely due to a problem with your AV cable. Try the steps below to get your Wii up and running.
  • Make sure the Wii is turned on and all cables are plugged in.
  • Unplug the AV cable from the T.V. (The AV cable has a red plug, a yellow plug, and a white plug.)
  • Plug the AV cable back into the television making sure that the red plug goes into the red socket, the yellow plug goes into the yellow socket, and the white plug goes into the white socket.
If problems continue try replacing your AV cable with a new one.
Jun 16, 2011 | Nintendo Wii Console
I cant connect my wii to my tv. can you give me instructions how?
Most TVs have a yellow video and a white audio and red audio input. The Wii comes with a cable to connect to a TV with a yellow, white and red RCA cable. Plug in the large block end of this cable to the Wii (rectangle block) and the other end into the TV using the yellow plug to the yellow input jack and the white plug to the white input jack and red to red. Select on the TV using the TV remote, the input where the Wii is hooked up. This is the standard way.
Apr 10, 2011 | Mitsubishi Televison & Video
HOW TO PLAY MY DVDS, AND CONNECT A WII AND PLAYSTATION 2
If you have the Insignia NS-42L550A11 (inputs shown here - http://www.bestbuy.com/site/olspage.jsp?id=cat13506&type=page&h=387&skuId=9595066&productId=1218131141674&navigation=prev&count=3&chk=true - or something like it), you might have a hard time plugging all of your devices into the TV.
Your DVD player might have a Component Out - if so, plug it (all 5 plugs) into the "Component" section of the TV. If you don't have a Component video cable, you can simply use a couple of Red, White, and Yellow cables instead - just be sure you connect the proper ends so the colors from the DVD match the colors to the TV.
As for your Wii and Playstation - I believe they both have the simple Red, White, and Yellow output plugs (labeled "AV IN" on the back of your Insignia). Because your TV only has 1 input for "AV IN," you might need to purchase a switch of some kind that you can plug your Wii and Playstation into and the switch will have 1 set of Red, White, and Yellow plugs to hook into the TV. The other option is to simply plug and unplug your Wii or Playstation directly to/from the TV depending on what you're playing... not an ideal scenario (particularly if you don't have easy access to the back of your TV.
The following link is for a 2-way switch that would do what you're looking to do. You could even get a 3-way switch and plug all 3 devices into it if your DVD player doesn't have a Component Out.
http://www.amazon.com/RCA-DT902AV-2-Way-V-Switcher/dp/tech-data/B0014KOAD8
Feb 08, 2011 | Insignia 42" LCD Flat-Panel HDTV
How do you take the wii and hook it up to the tv?
You take the cord that came with the Wii, has a small plug one end and 3 plugs other end, rred,yellow and white. Plug th small side into back of Wii and the 3 color cords into the matching slots either on the front or back of your tv.
Nov 13, 2010 | Insignia Televison & Video
How do I hook up my Wii to my 32" Emerson lcd hd tv? I have my dishnetwork satellite hooked into the dvd player and it's hooked up to the TV. On my remote I don't see a "game" button like my older Emerson...
I found a better way and it works fine. I have a new 32 inch Emerson, with only one composit hood up ( which won't work with the wii) 2 HDMI's ( again does not hook up to the wii, the monitor hook up for PC, red and white ( yellow plus is not there it's for a stereo they told me), and the usb hook up ( which is more for pictures I was told by the company).The answer was to hook my RCA plus to the red and white under the composite, then hook the yellow into the green plug of the composite, and behold- my will now works fine.
May 04, 2010 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
How do I hook up my Wii Console to my new Emerson
Dec 22, 2009 | Nintendo Wii Console
Trouble hhoking up a Wii console
plug the yellow one in to the yellow hole. plug the red one into the red hole and plug the white one into the white hole. then make sure your tv is set to the proper audio/ video input
Nov 10, 2009 | Toshiba 42H82 42" Rear Projection...
Tv only has white and yellow inputs. tring to hook up wii that has green, blue, and red then red and white
Just plug the green Wii connector into the yellow TV input, and the white Wii connector in white TV input.
Hope this helps!
Sep 19, 2009 | Nintendo Wii Console
Polaroid tv Wii connection
Your LCD TV should have one of the following types of inputs:
  1. Composite. This is usually a yellow jack, along with red and white jacks for audio.
    If your TV has these, which it should, then the cable that comes with the Wii will plug directly into these jacks. Plug the yellow to the yellow jack, the red to the red jack, and the white to the white jack.
  2. S-Video. This is a flat black jack. There are four little holes, and one "flat" rectagular hole. There should also be a red and white jack that go along with this for audio.
    In order to connect to this input, you will need to purchase an S-Video output cable for the Wii. Most stores that sell Wiis will sell a third-party cable for this.
    This connection will give you a significantly better picture than Composite.
    S-Video does not carry audio, so you still need to plug the red plug into the red jack and the white plug into the white jack or you'll get only video and no audio!
  3. Component video. This is a triplet of Red, Green and Blue jacks. There is usually a set of red and white jacks along with them for audio again.
    This connection will give you the best picture, and you can set your Wii to EDTV (Progressive) mode.
    To connect to this input, you will need to get the Wii Component Video cable. Most stores that sell Wiis will either sell the official Nintendo one, or a third-party cable.
    Connect the red plug to the red jack, the green plug to the green jack, and the blue plug to the blue jack. Also connect the red audio plug to the red audio jack and the white audio plug to the white audio jack.
    Be careful not to get the red audio plug confused with the red video plug!
    If you see a picture, but the colors are wrong, then you either swapped the red and blue, or you connected the red audio plug instead of the red video plug.
Apr 01, 2008 | Nintendo Wii Console
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Electro Med Services...
