Question about Sony XM-2165GTX Car Audio Amplifier
Amp works when it wants to
Power light comes on when you cut the car on and goes right back off... also the amp cuts on and off whenever it wants to....
Of course, the silly things should be checked, like that power is continuous, and your 12V Main and ground are secure. Also may want to check the remote wire to be sure that voltage is constant and at the proper voltage. If that's not the case, check your fuses, both on the amplifier and off the battery to be sure those connections are good.
Posted on Jun 24, 2008
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
My subwoofer doesn't receive power, all amp fuses are fine, amp powers on, remote wire and rca wires are connected and intact. Before it stopped working all together the woofer would cut out and after...
If you are getting power to the amp, try this....Find a small speaker, unhook your sub and wire speaker to amp. Turn on your system at a low volume....If the other speaker is playing through amp, then your sub is shot.....If the small speaker doesnt work, then its either your channel is gone on the amp or the rcas have quit off off your head unit.
Oct 07, 2010 | Kenwood eXcelon X1200M Car Amp
The lights are on in amp and it goes on but cuts out and fuses are still good
Check your ground wire to the amp. Make sure at the least you are using a 4 guage wire. Whenever i install a system I never hook to an existing ground. Best thing to do is drill a hole, sand down to ensure a good solid connection and screw that ****** down
May 21, 2010 | Car Audio & Video
Car Audio problems
If your voice cuts off when you use too much power i.e. operating power windows you are taking power away from your amp. An amp operates in stages; therefore you must increase the available (battery) power in your vehicle; possibly you can run two batteries (do not connect them in series)
May 14, 2009 | Car Audio & Video
Amp keeps cutting off
Do you have heavy enough gauge wire supplying B+ to amp.Big amps draw a lot of current and require very heavy gauge wire. The longer the run the heavier the gauge needed.
Apr 20, 2009 | AudioBahn A8000T Car Audio Amplifier
My PG Xenon 600 watt amp will not power my subwoofers
hello it sounds like your problem may be in the remote/power wire that goes from the back of your radio deck to the amplifier. the amp should have a wire connection that says remote,p.con, or antenna. and its usually the smallest wire connector located by the power and ground wire. this wire goes to the solid blue wire coming out of the deck. you can conect the wires together any way you want. i usualy shave off a little pice of the wire cover and wrap the wire coming from the amp around the bare wire then cover it in electical tape or cut the blue wire from the deck at a fit length and use a wire nut and put the two cut ends in and also the wire coming from the amp. also make sure the amplifire dose not have power to it just to be safe. wouldent want to fry anything.
There is also the left and right wires(ususaly red and white) that go on the back of the deck to the amp.
also chek the volume on the amplifire
Apr 12, 2009 | Phoenix Gold XENON 600.1 600 Watt...
Sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Power light doesn't stay on...
Caps are NEVER a solution to ANYTHING in a car audio system. If your car is lacking in power, you need a high output alt. All caps do is mask the problem until eventually your car's charging system is toast. Check this out: http://www.techlore.com/article/14696/
Aug 09, 2006 | Lanzar VIBE266 Car Audio Amplifier
Sony XM-2165GTX Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
