Question about Sony SLV-R1000 S-VHS VCR
Part# for supply side loading arm gear - Sony SLV-R1000 S-VHS VCR
2 Suggested Answers
SOURCE: supply loading arm gear
tyvm BobbyR1234 !!
Sony Part Number: 3-736-147-01
Threading Gear, left side, supply side
http://www.partstore.com/Part/Sony/Sony/SLVR1000/Sony/Sony/373614701/New.aspx
Part applies to models:
Sony DECK-SON-M1 | Sony SLV-555UC | Sony SLV676UC | Sony SLV-770HF | Sony SLV353UC | Sony SLV559 | Sony SLV686HF | Sony SLV-771HF | Sony SLV373UC | Sony SL-V575UC | Sony SLV-696HF | Sony SLV900HF | Sony SLV393 | Sony SLV-579 | Sony SLV750 | Sony SLV920HF | Sony SLV39UC | Sony SLV585HF | Sony SLV750HF | Sony SLVR1000 | Sony SLV494HF | Sony SLV-595HF | Sony SLV757UC | Sony SLVR5UC
Posted on Oct 12, 2008
Why doesn't upper spray arm function properly?
A couple of scenarios could cause this problem but the simplest might be the way the dishwasher is loaded. The upper spray arm rotates when water is pumped through the vertical supply tube and into the arm. Make sure that you are not loading the lower rack with items that interfere with the rotation of the upper arm rotor. It might also be a good idea to verify that the feed tube that goes to the spray arm is securely connected to the vertical supply tube.
Dec 02, 2015 | Kenmore Dishwashers
I have morse controlls on my sea ray speed boat to get it just to rev without being in gear you need to pull the arm out to disengage gear and it should rev but i have tried to pull mine and it seams to be...
Humm, usually the ARM does not move at all, (in terms of in and out). Typically, you push a button at the pivot point, and that disengages the gear portion of the control. This system is spring loaded, to snap back in as you pass neutral.
Jul 07, 2011 | Teleflex Morse CA27090P NEUTRAL SAFETY...
Windshield wiper on passengers side stopped working.
The wiper arm is either loose or the gear has stripped out the arm socket itself. Try taking the arm off and turn the wipers on, if that gear still turns, then try tightening the arm back down. If it is stripped, you must replace the arm. Otherwise, if the gear still doesnt turn, the connecting rods under the cowl have been damaged and may need replaced.
Feb 06, 2011 | 2008 Ford Ranger
The drivers side windshield wiper arm stopped working although the passenger side wiper is still working. What would be the easiest way to fix it? Should I even bother checking the fuse before the...
65% sure it could the linkage and not a fuse promblem since the other passenger wiper is still working which would have to say the wiper motor is still working, 40 % could be that the linkage is intact and you have a worn out driver side wiper arm bearing..., what you want to check out before the linkage is the gear bearing that holds the wiper arms. You take the rubber thing that cover the bolt on the wiper arm and see if the bolt is loose and if not, unscrew the bolt and see if the tooth gears on the bolt and the wiper arm is worn/dull, if it is.... that can be the promblem.
Jan 13, 2011 | Nissan Altima Cars & Trucks
How to remove the crank set and install it
There are 3 bolts to remove on the left crank (side without the gears): 1 - the main large cap in the center of the arm (this requires a special round tool supplied by shimano with the cranks, or your local shop can sell you one), and 2 bolts holding the arm in place. Remove all three completely. If the arm still will not come off easily, then take a large screwdriver and work in between the bearings and the crank arm and gently pry off. The trick is too only move a little then go to another section and move another small amount. until the crank arm wants to loosen. Once you pull the left side arm off, the right side will pull out of the bottom bracket, Just pull straight out. the BB spindle is attached to the right side crank arm. To install reverse the instructions. Works the same on Shimano cranksets of this type.
Dec 08, 2010 | Shimano XTR Hollowtech II Mountain Bike...
How to replace the gear box on a 1997 k1500 4x4 chevy suburban
remove the p/s lines to the gear box, take the nut of the pitman arm and seperate the center link of the pitman arm, remove the front shield, remove three bolts from the side of the frame holding the gear box onto the frame, you will need a puller to remove the pitman arm off the gearbox, reverse procedure to install. add fluid.
Aug 10, 2010 | 1997 Chevrolet Suburban
Ice maker not working.....water is working....
This is techcrazy
the solution to the problem is as follows
Feb 02, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Load/Remove Paper Light Flashing
IF THE ROLLERS DON'T TURN AND MAYBE YOU HEAR A CLICKING NOISE FROM THE LEFT SIDE OF THE PRINTER, THERE IS A SPRING CLUTCH INSIDE THE GEAR AT THE END OF THE SHAFT GOING TO THE SWING ARM. I FOUND THAT SOMETIMES GREASE GETS INSIDE AND CAUSES THE SPRING TO SLIP INSTEAD OF GRIP LIKE IT SHOULD. IF YOU'RE VERY CAREFUL, YOU CAN TAKE OFF THE LEFT SIDE COVER AND LAY THE PRINTER ON ITS RIGHT SIDE (LEFT SIDE FACING UP). THEN REMOVE 3 OR 4 SCREWS AROUND THE GEAR ASSEMBLY AND LIFT THE ASSEMBLY STRAIGHT OFF THE PRINTER. TO GET TO THE SPRING CLUTCH, YOU'LL HAVE TO MOVE A COUPLE GEARS OUT OF THE WAY (REMEMBER HOW THEY GO BACK OR YOU'RE SCREWED - AND WATCH THE TONER ARM SPRING AS WELL). REMOVE THE PLASTIC C-CLIP ON THE END OF THE PICKUP SHAFT AND LIFT OFF THE CLUTCH GEAR. PULL THE GEAR APART AND WIPE OFF ANY GREASE FROM THE INNER SURFACES WHERE THE CLUTCH SPRING SITS. REVERSE YOUR STEPS TO PUT IT BACK TOGETHER.
--SORRY, MY CAPS LOCK DOESN"T WORK AND I DON'T FEEL LIKE HOLDING DOWN THE SHIFT KEY TO TYPE ALL DAY.
Aug 08, 2008 | Dell 1700n Laser Printer
Tapes keep getting stuck
If your tapes are getting stuck, then most likly it is not a cleaning issue, but a mechanical problem. It would be something in the take up supply reel mechanism. Like a bad clutch, take-up gear or idler, and /or a bad or broken belt.
Sep 28, 2006 | Samsung SV5000W VHS VCR
Sony SLV-R1000 S-VHS VCR Logo
99 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
