Question about Samsung SMH9187 Microwave Oven
Microwave SMH9187ST - No apparent power,(plug outlet is hot). Unit has worked great for 6 months, Is there an inline fuse? Also need web addr for repair/service manual. thanks ray
  • Samsung Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Nov 15, 2010
Microwave oven
An internal fuse may have opened
Aug 18, 2016 | GE JVM1490 Convection/Microwave Oven
My Panasonic genius sensor 1250W microwave has stop working, now is their fuses i need to check,or is their a way i can, check the heating element to see if i us out.
Kevin,
There is a fuse in a microwave. One way you can tell for sure if the fuse has blown is that there will be no lights or any activity when you push buttons. The screen will not light up either. If that is your case, then you can be fairly certain that your fuse has blown. I would suggest before working on it that you plug something else into the same outlet and see if it works okay so that you can eliminate that you lost power in your outlet. If all of that is okay, then turn your microwave around so that you are looking at the back and take out the screws that hold the cover on. Remove the cover and look at where the power cord goes into the back of the unit. Find the black wire from the power cord and follow it to either an inline fuse holder, or a fuse block, or a circuit board. Depending on your model, you should have one of these three options. Make sure that you replace your fuse with the same amperage fuse that you take out. Look on the metal rings at each end of the fuse and that will tell you what amp fuse you need. Hope tis helps!
Feb 26, 2015 | Panasonic Microwave Ovens
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
My microwave stopped working just went dead. I have changed the fuses (20A) 250 volt and that didnt work. What should I try next. Thanks, Sam :)
We have a Samsung SMH9187ST that just shuts off. no power at all. this is the 2nd time it happened, this time my husband was home to witness. First time I somehow got it to start working again , this time no luck. it was manufactured Dec 2009
Apr 13, 2011 | Samsung SMH9187ST Microwave Oven
Purchased an MCO165UB microwave 7 months ago. Ran great for 6 1/2 months and then there was no power. No fan, no light, no cooking. It was like the cord was unplugged but the electrical outlet has...
I would have your house hold supply checked on the socket that it is plugged into. One appliance fail but not two.
I hope you find your fault.
Jan 25, 2011 | GE Microwave Ovens
No power to the oven.. outlet that it is plugged into is ok. is there an inline fuse or could the power supply be bad?
There are two fuses inside the unit, a high voltage fuse as well as a slow blow fuse, you may need to replace these, but as well as that you may need to check the high voltage capacitor as well as the transformer if replacing the fuse's dont solve the problem. Good luck.
Nov 04, 2009 | Maytag MMV1153A Microwave Oven
Why did my maytag microwave oven power go out completely?
1 your inline fuse blew
2your magnetron t-stat poped
3 bad voltage from outlet
test the outlet with a lamp, if that works it can only be the other two
open the door, take the screww off the control panel
and the vent cover, two screws on top
behind the control and vent you will see the mag t-stat, it should read continuity, and the inline fuse should be right above it a small glass tube fuse like a car
Oct 16, 2009 | Whirlpool MH3184XP Microwave Oven
Microwave won't Work
sounds like a fuse for starters, remove outer cover there will be a white cartridge appx 1"longX1/8"dia this is a ceramic fuse avail at most hardware stores in 15 or 20 amp configurations, if this blows again after repl suspect a faulty H.V. Diode/H.V. Capacitor, or the magnetron tube unless while inside unit you see something obviously wrong 2 fuses are under $5.00
Sep 27, 2009 | Magic Chef MCB780W Microwave Oven
Whirlpool microwavewave hood comination mh3184xp
My Whirlpool MH3184xps is shooting a spark when in use with the rack. When the rack is removed the oven works fine. I am guessing that some of the coating on the rack has cracked and peeled and is exposing some aluminum. Has anyone else had this problem?
Feb 04, 2008 | Whirlpool MH3184XP Microwave Oven
Microwave stopped working
Yes, there should be a ceramic (tubular) fuse under the cover on the top side where the power comes into the microwave.
Dec 11, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung SMH9187 Microwave Oven Logo
663 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
