What is the pin placement on a WinFast 760M02--6LS motherboard power button, HDD led, and reset button?
    Guru:
  • 302 Answers
This is solve
Posted on Sep 13, 2011
  • DarkYastreb Sep 13, 2011
    Sory, image download fail :(
Motherboard
The front of your computer is the Front Panel
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
What you are asking for is a Front Panel header pinout.
I do not have the exact Front Panel header pinout, for your motherboard.
Tell you what I do have though..........
Looking at the Front Panel header on the Ebay link, for the Winfast 760m02-GX-6LRS; the Front Panel header looks to be below the CMOS battery, and close to the Bottom edge of the motherboard.
(Motherboard installed in computer case)
Black rectangular strip of plastic, with contact pins sticking up.
Also looks to be a GENERAL set-up for all Winfast motherboards.
(COULD be wrong here)
This is what I am referencing off of,
http://www.devhardware.com/c/a/Motherboards/Foxconn-Winfast-NF4SK8AA8EKRS-Motherboard-Review/3/
Go to the third photo down. Here you see the Front Panel wires, connected to the Front Panel header; on the motherboard.
(Below round CMOS battery)
Note that the contact pin on the Bottom row, and all the way to the Right; is NOT being used.
(I'm using a 26 inch HDTV as my primary monitor, so it may be easier for me to see)
Now look at this Front Panel header pinout, for another Winfast motherboard,
http://www.techsupportforum.com/forums/f15/winfast-mobo-front-panel-connection-558456.html
(Scroll down a little)
PWRLED is for the Power On LED (Light)
PWRSW stands for Power On switch
HD-LED stands for the HarDDrive activity LED (Light)
RESET stands for a Reset switch, IF USED.
Note where it has a Positive ( + ) sign, next to the pin for the PWRLED.
This is the pin the + wire from the Power On LED connects to.
It is the SAME for every LED that connects to the Front Panel header.
Let's number the contact pins, to make the explanation easier;
Starting at the Left side, Top row; going towards the Right;
Pins 2, 4, 6 and 8. There is NO Pin 10.
Starting on the Left side, Bottom row; going towards the Right;
Pins 1, 3, 5, 7, and 9.
Pin 2 is for the Positive wire.
Pin 1 is for the Positive wire
If the LED's are dim, (PWRLED, and HDD LED), OR; the LED's do not light up, switch the wires around.
(Pin 9 is N/C.........Not Connected. This is probably a 5 Volt test point, that was used by the factory)
There is a method you can use though, and find out what the individual contact pins are, in the Front Panel header;
Use an LED with two wires
Computer (Power Supply) plugged into power, go along the top row, and touch two pins at a time, with the two wires of the LED.
Example; Pins 2 and 4, as shown in the pinout.
Did the Power Supply come on?
No?
Go to the next two pins. Try again.
When the Power Supply comes on, you naturally know that is the two contact pins; for the Power On switch.
DO NOT touch them again. In fact connect the Power On switch wires.
Power Supply on, computer running;
Now go back along again;
1) LED light blinks?
You have the HarDDrive activity LED, contact pins.
2) LED light stays on?
You have the Power On LED, contact pins.
3) Computer restarts?
Those are the Reset switch, contact pins.
4) Nothing happens?
May be contact pins for a speaker, or contact pins that are not used.
(Speaker is for hearing BIOS Beep Codes.
You have a Piezo buzzer, to the Left of the CMOS battery; for that)
Post back in a Comment, as to the results.
If possible, I would like to ask upon you; to post the Front Panel header pinout; when you find what it is.
That way when a person in the future also has this same problem; the solution will be posted on the internet, for them to find.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 30, 2013 | Leadtek Winfast 760m02-gx-6lrs Socket 754...
Tip
How to find the power button inside the motherboard...
inside the motherboard there are groups of pins that are in 2 pairs...
they are in 2 column...
you can noticed to them that the other one has a excess pin..
it means that is the group of pw button reset button pw led hdd led..
the other groups are for usb and internal speaker...
use a philips or screw driver, or even a long nose try to short the pins in pair if you already find the pins of the power button..the sequence of the next buttons are:
pw button
reset button
pw led
hdd led
that's all hope its a help..
on Feb 06, 2010 | Computers & Internet
Front panel 10 pair motherboard plug in configuration
this will do
2 8
. . . . this will be 2,4,6 and 8 pins (from left to right)
. . . . . this will be 1,3,5,7 and 9 pins
1 9
Power Led + in pin 2
Power Led - in pin 4
Power Button # or + in pin 6 (It's no critic the orientation, it have no polarity, is a push buttom)
Power Button GND or - in pin 8
HDD Led + in pin 1
HDD Led - in pin 3
GND from Reset Buttom in pin 5
# from Reset Buttom in pin 7
THE PIN 9 has no connection
Jan 15, 2011 | AOpen AX45-4D Max Motherboard
Where can i get pyramid-9 PCB No BA41-00167A manual book for setting up power switch,hdd led,reset etc connection setting ???????????
Hello, i was made a search in google, i guess you must look it too, and a don't get nothing, but, I think i've a solution for you, according my own experience, i've installed 2 kinds of different MB, and, althoug there are different brands, the connection pins are the same, ie, the front panel connector that connect HDD Led, Power Led, Reset and Power, is a 9 pin conectors (really have 10, but 1 pin is cut for reference) and commonly is called PANEL 1
Then, i guide you
2 8
1 9
HDD Led + in pin 1
HDD Led - in pin 3
Source: My own experience, and check this instalation manual, at 21st Page
http://download.asrock.com/manual/Wolfdale1333-D667%20R2.0.pdf
Jan 07, 2011 | EPoX EP-3PTA Motherboard
Re-reset botton pw- power botton hdd led- hard disk led pw LED- power led idenfification problem help me
from the 1 pin that is single without pair..disregard that then put the pw button.. to make sure short it using a philips or long nose.. if you find the power on button...or just find first the power button by shorting the pins...
the sequnce are pw button reset button pw led hdd led..you just nid to align them to the power button..
hope i've help you..
rate...
Feb 06, 2010 | Zerus Intel Desktop Board D815EEA...
Pin placement for ms 6741 mb
the manual for your motherboard can be downloaded here:
http://www.msi.com/index.php?func=downloadfile&dno=3812&type=manual
On page 2-17, the pin-outs for those connectors are specified in detail. They are part of the JFP2 header:
PIN SIGNAL DESCRIPTION
1 HD_LED_P Hard disk LED pull-up
2 FP PWR/SLP MSG LED pull-up
3 HD_LED_N Hard disk active LED
4 FP PWR/SLP MSG LED pull-up
5 RST_SW_N Reset Switch low reference pull-down to GND
6 PWR_SW_P Power Switch high reference pull-up
7 RST_SW_P Reset Switch high reference pull-up
8 PWR_SW_N Power Switch low reference pull-down to GND
9 RSVD_DNU Reserved. Do not use.
-Jon
Sep 01, 2009 | MSI K8MM-ILSR (MS6741030) Motherboard
Wiring front panel
if you go to this website
http://www.foxconnchannel.com/support/downloads.aspx
You can select motherboards --> socket 754 --> your make of motherboard and then download the manual which will tell you what the pins are for and where abouts they are on the motherboard.
Apr 13, 2009 | Foxconn 760GXK8MB-RS Motherboard
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
Help me on how to connect my samsung motherboard!
Power>Red & white
Reset>Purple & white
HDD Led>Green+
HDD Led>White-
HDD Tx>Yellow & white
Select each pin & correspond with block on FSB M/B panel
Jan 17, 2008 | Computers & Internet
Computers & Internet Logo
513 people viewed this question
David Payne
David Payne
