Question about Refrigerators
Looking for the specifications on a GE TFX24R side by side Refrigerator...
  • 4 Answers
SOURCE: Side by side GE refrigerator freezing food in refrigerator.
The unit is having a damper control issue. In the back of the refrigerator there is an assembly that is in the center at the top. It connects to the freezer side. The damper is broken, cracked or has an obstruction. Check this and see if it is the problem.
Posted on Jan 09, 2009
  • 73 Answers
SOURCE: Owners Manual for GE Model# TFX24R
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003670882.PDF
Here is the info you requested.
hope i helped
please rate me
George
Posted on Apr 30, 2009
asnowman
  • 788 Answers
SOURCE: the light bulb burned out. I do not know what type
According to GE this uses a 40 Watt appliance bulb. You should be able to get one from any department or home improvement store.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
I try to give the best FixYa experience.
Posted on May 03, 2009
SOURCE: I have an older side by GE refrigerator model #
You may have ice formed in the passage between the freezer and the refrigerator. You have to remove the plastic panel in refrigerator side. (pull temp control knob straight off, then tilt plastic panel forward from bottom. Should come off with a little wiggling). Next remove one screw just above where the temp knob attached. this will allow the left half of the assembly to pull toward you. It will want to stick to the right side of the assembly (were the light buld is) so just gently encourage it to come out. Once out you will have a very simple device in you hand made of foam and plastic. rinse under warm water and get all the ice out of it. Dry it and put back in. replace parts in reverse order.
See if that helps!
Mike in Tucson, AZ
Posted on Jul 10, 2010
  • 2122 Answers
SOURCE: Re: GE Model TFX24R Side-by-Side
the cam must have broke and this is why the door fell,the cams are made of plastic,part number WR2X4901 and it's around 15 dollars,there's a couple of shims that are there too but they should still be good,
Posted on May 14, 2011
Overhead
Are you looking for a specific Cubic Feet?
Apr 18, 2014 | GE Refrigerators
Need a new drain pan for TFX24R for Ge side side by side 23.6 rrfregiator
I don't have a photo but you can find the drain pan=>
HERE WR2X7074
I will be here should you have questions, Thanks Sea Breeze
Dec 19, 2012 | GE Refrigerators
Re: GE Model TFX24R Side-by-Side 23.6 Cu Ft Refrigerator The refrigerator door needs to be raised to correct closure, it is visibly low and stands open. However, I have not been able to figure out how...
May 14, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Gr Side-by-side refrigerator freezer makes noise when door close
It is possible that the hinges of your freezer has moved and shifted the alignment. So first of all use a WD40 cleaner to spray into the hinges and the areas around it. Now move the hinges violently for some time and check if has lessened. If so repeat the spraying. See if here is dirt accumulated along the hinges if the door is not moving parallel just push the end up a little . You must be able to get the hinge to shut properly by this correction. Hope you try . Good day
Jul 31, 2010 | GE Refrigerators
I have an older side by GE refrigerator model # TFX24R. The freezer is fine, but the fridge isn't getting too cold. Any suggestions??
See if that helps!
Mike in Tucson, AZ
Jul 08, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
The light bulb burned out. I do not know what type and and wattage of the bulb to replace it.It is the refrigerator light bulb in GE TFX24R refrigerator. Thank you my email is endliamc@gmail.com
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I am looking for G.E Monogram parts.
here ya go you may be able to find it cheaper looking around on the internet as well the part number is WR55X10560
Jan 21, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
