Question about Hotpoint Ultima WF860 Front Load Washer
Mould on door seal - Hotpoint Ultima WF860 Front Load Washer
  • 520 Answers
They sell tablets to put in the washer to treat this. also you gan wipe it down with a bleach and water mix. bleach kills the mold
Posted on Nov 14, 2010
Smelly washing machine
Hi Haydn.
One of the main reasons for smelly machines is because the door is left closed and mould is growing in the drum and door seal.
Using some chlorine bleach will help. Put some in the drum and do a 'Rinse & spin'.
Leaving the door slightly ajar will allow the drum to dry and it will also allow the rubber seal to relax, thus maintaining a good contact with the glass when in use.
Once it's established mould can be difficult to get rid of entirely.
Good luck.
Nomess
Jan 11, 2015 | Bosch Washing Machines
Mold door seal
If you want the door seal replaced any local domestic engineer will be able to do this. The mould is caused by excess detergent, constant washing at low temperatures, keeping the door closed when the machine is not in use. If you want to stop the mould reappearing once the seal has been replaced you need to carry out regular service washes (boil wash with a descaler/sanitiser). Use the correct amount of detergent for the amount of washing to be done and the hardness of the water in your area. Give the door seal a quick wipe after you use it and try and keep the door slighlty ajar when not in use.
Oct 18, 2013 | Siemens WFXD5200UC Front Load Washer
Water seals
doors or windows doors the seals go under trim that must be removed most just snap in place some use screws remove and replace weather strip . door seals they seat around the top in a grove on either side and inserts along the sides and bottom. door window seals out side remove door panel remove mirror pull up remove moulding inside just pull up strip and replace.
Jul 29, 2012 | 1996 Chevrolet Suburban
Mould/gunk on the rubber seal of a Maytag MAF1300 AAW - help!
Once mold is present the only way to get rid of it is with peroxide. Any residue left will grow again.
May 13, 2010 | Washing Machines
We have a Fridgedaire front load clothes washer and we would like to know how to get rid of the mildew on the front seal?
be carefull what chemicals you use on the door seal,get in touch the manufacturer or call the appliance guy that sold it to you
Jan 31, 2010 | Frigidaire Affinity ATF7000E Front Load...
How do you clean the mould build up off the flexible door seal of a front loading machine. Can I take out the door seal safely to do it. Westinghouse front loading washing machine model LF711C
Bleach:Water solution 1:2 should kill the mould effectively.
What they should have told you when you bought this machine and what it almost certainly says in the owners manual is that front-loading washing machines, all brands, are prone to this problem. You must wipe the rubber gasket/door seal off when done using. Every time.
Dumb, I know, but necessary.
Sep 08, 2009 | Washing Machines
Mouldy door seal on hotpoint ultima 14 months old
hi, has the seal been replaced?if not use an old tooth brush and clean it with tooth paste it will clean off the mould, if the seal has been replaced check around the rim for a drain holle it may have been fitted wrong, some dont have drain holes hope this helps
Feb 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Black mould round door seal
There are several reasons for this to happen.
the primary one is the fact that you are doing a lot of low temp washes, and this causes a build up of grease and dirt around the door seal, the mould you refer to is actually bacteria.
You must do a high temp wash at least once every 6 to 8 weeks, put powder and or detergent in as usual, but no washing, and let it do a full cycle.
This is called a maintenance wash and helps prevent what has happened to your m/c.
Thoroughly clean the door seal with a scouring pad or stainless steel wool, you will not harm the seal,
You will probably find the seal will be stained, but as long as you get all the mould etc off, it will be o/k.
Plz rate my solution.
Thanks
Dec 29, 2008 | Indesit Washing Machines
Zanussi front load washer door seal
Keeping the door open after your wash would help in keeping the interior dry. Do not push the door shut, just leave slightly open. Only before you begin your wash, check to see your cat is not inside.
Oct 13, 2007 | Zanussi FJS1225W Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
75 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
