Question about Sport & Outdoor - Others
We found that we had a broken Shear Pin in our Thrust Nut. When we tried to replace it, we find that there is about a 1 inch difference between the hole on the whiffletree and the hole on the Thrust Nut. What would have caused this and how do we adjust the whiffletree so the holes match?
  • mj2181 Nov 15, 2010
    I have read over the instructions, but I don't see where it gives me direction in lining the whiffletree hole with the thrust pin hole.
    It appears that the whiffle tree has been shifted to the rear of the casing by about an inch. When you put the thrust pin through the bearing plate, you can see the hole in the whiffletree. Can you adjust the whiffletree toward the thrust pin without pulling it loose? I don't want a bigger problem that we already have.
    Shelley
  • mj2181 Nov 17, 2010
    My husband had tried everything to move the whiffletree forward. He has broken down and taken it to a RV repairman. I just hope it will be finished before I need to leave to go camping next week.
    Thanks
  • Sport & Outd... Master
  • 5,501 Answers
Why don't you put something in the hole to substitute for the shear pin and try to pull the shaft in the direction you need to line it up? It sounds like it could use the thrust nut to maintain the spacing to some degree.
Depending on the size of the shearpin hole you may be able to use rope or wire to form a loop and pull on the loop.
Posted on Nov 16, 2010
  • 10,865 Answers
Hello. I believe the step-by-step instructions at this link will answer your questions about what caused your problem and how to adjust the whiffletree so that it's hole lines up with the thrust nut to receive a new shear pin. http://www.fft-inc.com/korkwerks/instruction_sheets/1968B602.pdf
Joe
Posted on Nov 15, 2010
Shear pin broken on my mower how do I change it
take the tins of. take the nut that holds the flywheel on off and you will see the sheer key. if it is ok leave it alone. if it looks like the flywheel is not perfect with the crankshaft replace the key. it is some times hard to pop off but you can do it. go to you tube and watch a couple of videos on this process.
May 02, 2017 | Garden
Loss of thrust
Hi Diego:
Not a lot of information to go on here, so, I'll take a wild guess.
If it is an outboard motor, the chances are really good that the propeller has contacted something (rock or chunk of wood?) and the shear pin has done its job and sheared off.
So, I'd pull the propeller and replace the shear pin, assuming of course that I have guessed correctly.
Cheers
If I'm totally wrong, give some more information and maybe I can help.
Jul 24, 2016 | Boating
How to replace shear pin horizontal blades spin free motor won't drive them
Look close to the middle of the auger. you should see small ( 1/4") holes where the shear pins were. Just line up the holes from shaft to Auger and put new Shear pins in there. Sometimes they look like Clevis pins and sometimes they look like a simple 1/4" bolt and nut
Jan 04, 2016 | Garden
Minnkota endura c-50 shear pin size
You can get the appropriate pins in the prop not kits sold by minn Kota or thru major retailers.
Trolling Motor Replacement Props Minn Kota Motors
You will find prop nut kits here just follow the link.
Sep 28, 2014 | Minn Kota MinnKota MK110P Marine Portable...
How to change shear pin
With the motor OFF, the shaft shouldn't rotate, so you should be able to rotate the auger by hand until the holes line up.
Mar 01, 2014 | Craftsman Sears Snow Thrower Manual Model...
Toro 828 oxe blower shear pin
knock the broken one out with a punch and hammer put a new sheer pin you can make on with a bolt just grind down the middle of the bolt so it is thinner than the rest , I do this all the time
Dec 12, 2013 | Toro Power Max 828 OXE Snow Blower - 28...
I have a snapper m1529e snow blower and need shear bolts for the auger, I was told by a local mechanic that it used a 1/4 inch machine bolt. I am worried that this might not protect the machine. Thanks...
Yes, 1/4" bolts should work fine. Just make sure they are grade 1 or 2, if you use say a grade 5 or 8 bolt, the bolt will not shear thus defeating the purpose of a shear pin. For what it's worth I have the same snowblower as you. When I found no one locally carried them, I resorted to to using regular bolts. I have had them shear just like they should when you hit something by accident. No damage to the machine after 3 years...and yes, someone in the family tried a grade 8 bolt on their ls and it basically destroyed the auger...
Feb 28, 2013 | Garden
Broken shear pin in kitchenaid A9 Coffee Grinder
I was able to find 3/32 x 1/2 inch spring pins at a local hardware for 13 cents each. They may not last as long, but at the price I can replace as needed.
I also had to disassemble twice; I didn't notice that a portion of the old pin was wedged in the underside of the burr. When I put it back together the first time, the new pin rested on the old fragment and pressed the burrs too close together. On the coarsest possible setting, I got coffee powder!
Final note: The nut for the cap over the burrs is reverse-threaded...use a wrench on top, and a flat-blade screw driver in the slot at the bottom of the motor shaft.
Jan 01, 2009 | KitchenAid A-9 Electric Burr Grinder
Sport & Outdoor - Others Logo
63 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
