Question about Philips Magnavox 55P9271 55" Rear Projection Television
Philips Magnavox 55P8288A Color is bad orange and yellow, how do you fix that, the settings on the menu is not enough
Slinteriors
  • 8617 Answers
SOURCE: Bad Picture on a Projection TV Magnavox 55P8288A magnavox
Change the coolant inside the CRT this will restore the color and clarity to 100% on your set.
Posted on May 25, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Philips Magnavox 55P8288A Green tinge over entire picture
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Apr 11, 2009
johnnydiode
  • 647 Answers
SOURCE: Philips 55P8288A tv has a dull color and a red
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Posted on Nov 28, 2009
SOURCE: philips magnavox 9P6040C104
i just found out why, turn on ur tv and remove back look directly into 3 lenses, if the picture is not nice and clear or looks snowy in all 3 u will not get good color or brightness. I removed my blue tube assembly and took it apart WHILE OUT OF TV. there is cooling fluid between lense and tube, this fluid over time will build a film on the face of the tube and get thick enough to block the tube from projecting picture. (MARK EDGES IT GOES BACK TO GETHERE THE SAME WAY IT CAME APART).Find some new fluid then carefully dissasemble and clean interior of lense, housing and tube thouroughly. Reassemble and fill with new fluid. Do not use old fluid it will be cloudy and snow globe effect. Only do 1 tube at a time this will allow u to realign cross manually as close as possible before u perform convergence. Leave the green for last that is the center and the red and blue are moved to match green. Also be sure to clean mirror and back of screen. Pete
Posted on Mar 31, 2010
SOURCE: model number#55P8288A Phillips Magnavox(PVT910)We
http://www.tvrepairkits.com/download-guides/tv-kit-001-002.pdf
www.scribd.com/.../Philips-DPTV400-TV-Projection-Training-Manual
www.scribd.com/.../Philips-Training-Manual-TV-Plasma-Display-Panel-Chasis-FTV1-9 -
Service & Repair manuals for your unit.
Sounds like your set has developed a "Color Mixing" problem, Please use the troubleshooting procedures and you will soon be able to find out what to do.
Posted on Apr 29, 2010
Bad dull color on a magnavox 55p8288a... how do I change the coolant in this tv
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 31, 2011 | Philips Magnavox 51MP392H Rear Projection...
Model number#55P8288A Phillips Magnavox(PVT910)We have no owners manual.And the picture is too orange.where can we get a manual to set it right
Apr 29, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a 60" projection tv philips magnavox model #9P6040 C104 PTV843. The color looks bad, the picture looks orange and red. What do I need to fix it and how much will it be.
You have one of two problems based on your description.
1.) Go to a channel that is in black and white and turn the color on the set all the way off.
Examine the screen and picture from several feet back----if the picture is mostly red and looks somewhat yellow in the main part of the screen you have a GLYCOL problem.
These sets have on each picture tube a sealed unit full of Glycol to cool the face of each tube (set has a red, green, blue picture tube)
If you find the yellow/orange look with the color off you most likely have bad Glycol in the blue picture tube---it never happens to the red--bacteria gets into the glycol and eventually there is no picture coming from (in most cases) the blue tube.
Loss of blue will leave you with Red and Green--mix those two and you usually get a orange/red affect.
There is a way to also confirm this with your eyes--it involves getting the back cover off of the set and holding a small mirror (with the set turned on--you have to be careful not to touch anything)
If you look in each lens you should see a fine picture--one red, one green and one blue--if as I suspect the blue tube is contaminated it will not have a picture and will look like a blue floodlight.
IF THIS IS NOT YOUR PROBLEM--GO into the customer menu and select convergence--what you are looking for is will red and blue adjust or not--are they skewed and will not move.
If this is the case you have a convergence problem--I can tell you what is involved to fix in either case.
Let me know what you find--I am here to help people.
If this information has helped you, rate this solution as I do this here for free.
SD TECH
Nov 08, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox PTV910. The picture is good but color is bad
the coolant in the blue and green crts has congealed which is causing the red tube to become dominate. The coolant can be changed at home. You can get the phillips coolant replacement kit at the following link which contains the coolant and the CD with instructions.
http://www.tvrepairworld.com/
Jul 15, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 55P8288A Picture is cloudy
You can purchase a factory one from www.remotes.com. and for you manual you can download it here just click on get manual http://www.retrevo.com/s/Philips-50ML8105D-TVs-review-manual/id/277ag615/t/1-2/
I sure do hope this helps you and thanks for using fixya.com
May 24, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
  • Screen looks 3D
Apr 09, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
TV doesn't come on
Your SSB Module is Bad Part # PH3912725881.
Jan 02, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips projection tv
sounds like your cooling fluids in the tubes needs to be changed. Repairman told me it was common on the philips.
Sep 09, 2008 | Philips Magnavox 9P6034C 60" Rear...
Same Problem with carloscor Philips Magnavox 55P8288A
the following link has the cd with instructions, or the coolant change kit which has the coolant and cd with instructions on the proceedure. Its listed under the repair kit section.
http://servicemanuals.vstore.ca/
Jul 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
May 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Open Questions:
Philips Magnavox 55P9271 55" Rear Projection Television Logo
142 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
