Question about Samsung HP-P5091 50 in. Plasma Television
Samsung PS-50C96HD blue light is on but off sometimes no screen at all tried different power cord
2 Suggested Answers
  • 76 Answers
SOURCE: relay clicking on power board on my samsung
To have an idea what's going wrong with your set, watch the video below...
Posted on Nov 04, 2011
Samsung syncmaster 2220 blinking blue light and no image display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
My samsung Tablet's Screen keeps flickering continously
Good luck.
Jul 07, 2014 | Computers & Internet
TV clicking on and off with colored screens and noises, not power supply capacitors this time.
Sounds like a main board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 20, 2014 | Samsung LN46A630 46 in. LCD HDTV
Element flat screen tv screen appears off when power is on
At this stage, try replacing ps Caps. Old elements had cap problems in ps area.
Feb 11, 2014 | Element Electronics Televison & Video
Samsung ps 50c96hd
As the fault arises after two hours of working, it should be of some internal heat problem. It will be best to contact any service technician in this case. Check whether there is enough gap provided for proper ventilation; at the back side of the TV. Check whether the cooling fans at the top side [inside the TV] are working, or stops after some time of working. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 17, 2013 | Televison & Video
Relay clicking on power board on my samsung ps-50c96hd plasma tv
Nov 04, 2011 | Samsung LN-S4051D 40 in. LCD Television
My dell E196FPF 19'' lcd screen acting strange!
Are You using a extention cord or a ups that is not funtioning properly....?? if yes try connecting the power for the monitor seperately or directly to a plug base...
this mi8 solve ur problem
Apr 10, 2009 | Dell E177FP LCD Monitor
Blue blinking light
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jan 10, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Screen
remove the battery try pressing the FN key and F4, F5, F7 (which ever your lap uses to switch between external lcd and internal screen)
Aug 31, 2007 | Acer Aspire 5500 5570-2609 Laptop
Samsung HP-P5091 50 in. Plasma Television Logo
271 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
