Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Where is the pump screen on a HE3 front load washer?
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
This is a guide to locating and cleaning the pump filter for most Whirlpool made front-load machines, such as Whirlpool, Kenmore, Maytag, Amana etc. Keep in mind some Kenmore are made by LG, Samsung, Frigidaire among others.
Here`s how to find it, check it and clean it...
A wet-dry shop vac is handy in this situation.
If it is in a position close to a floor drain, you wont need the wet-dry vacuum or towels...it's your call.
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
5) If all appears OK after your efforts, well your efforts paid off...refasten the lower panel. Now You should be good to go.
**I also recommend inspecting the "check ball" within the bellows from time to time as well. To access it is as follows...** It is inside the bellows which connects the tub to the pump as shown below. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.** b0ac102.jpg 02d1e9d.jpg
Hope that answers your question. Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
Posted on Nov 14, 2010
  • 347 Answers
If you remove the front lower panel.(three small screws at floor level) you will see the drain pump ,place a shallow pan under the front of pump and remove the cap on the front of the pump ..Its not actually a screen its more of a trap for debris and coins,clean then line up marks and reinstall
Kenmore elite h3 front load washer is not working error code f2 flashes
The F2 error code mean that the washer didn't drain the water within the normal time it takes to drain,usually the reson the washer hasn't drained properly is because the filter screen on the drain pump is clogged with debris. this tip i have written will show ya how to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 08, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a Kenmore Elite Quiet Pack 2, HE3, model number 110.45872 400 front loading washing machine. When I start a cycle it stops and letters H and F alternately show on the screen. What does this mean?
i just had this problem... i did the following (should only take 30 minutes) take the panel off, that is located below the front door,, there are 3 small srews located at the bottom that hold this... then you will see the water pump, the water pump has a access srew plug, when you unscrew this, its like a filter, you may see stuff, like coins, socks, etc, remove and clean it, then put everything back... this should fix the issue.
Oct 11, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My kenmore HE3 front load washer will not drain or open door
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 21, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 front loader shows an error message of F02. It doesn't complete the rinse cycle as a result.
There is a trap on washer pump I just found to be full of the same **** you find in sink trapp. That is probably why I had same problem. could also be kinked hose or pump issue. The experts at fixya just walked me through it. best ten bucks i ever spent.
Good luck Scott
Apr 05, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore front load He3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Feb 27, 2009 | Kenmore Elite 45986 Front Load Washer
HE3 washer not drying the cloths
I had this problem a few months ago and it turned out to be a bad water pump; I replaced it myself and it was incredibly easy. The hardest part was removing the front panel, below the door because the screws are under a lip, about half an inch off the ground. When you get it off, the pump mechanism will be right in front of you. The pump is on the right side of the mechanism and is screwed into the plastic part. When I removed it, the impeller (a small, ribbed plastic part that spins and moves the water) was broken off from the motor. You can buy the whole pump mechanism from Sears for about $100 and install it yourself. Just follow the directions that come with it!!! Hope this helps.
Jun 10, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 Code F032
I remove the pump and found out that the impellor was worn , I have replaced the pump and the machine is working , no more F02 Codes .
Nov 14, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
622 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
