Question about 7701V Responder 2way Transmitter LCD Paging Remote Transmitter
Ok my alarm is not working because a little piece of wire is off and my brother got it from circuit city but it is no longer in business I just need to know where to go to get it fixed or if you can help me fix it.
  • 139 Answers
Since you have a Viper system, you can go to any dealer to have it repaired.
You can find an authorized dealer via this link.
http://www.viper.com/Stores/
Depending on the problem, a local alarm shop may be able to repair it.
Posted on Nov 16, 2010
What Kind Of Roof Is Ideal For My Property At Kansas City?
A.metal [higher cost, longer lasting] if surrounded by trees that encourages mold growth on shaded roofs. one common material is steel pieces about 2x4 foot having a shingle design.
B.individual fiberglass shingles if roof is in clear sunny area.common size is about 1x3 foot having shingle design. ensure adequate, screened in venting, under eves and out venting high on all roofs.
obtain multiple quotations from reliable roofing installers as they have experience, insurance and proper equipment.
ask neighbours with newer roofs for opinions.
Mar 03, 2018 | Miscellaneous
The front wheeels on my citi mini double stroller keep locking by them selves making it really impossible to go around corners. any ideas what ican do?
If you do not care if it will not lock again (We did not) you can take the wheel off, and then you will see a little post that moves up and down with the lock mechanism. You just need to remove that. It is a piece of metal inside of plastic. I used a grinding wheel to shave it down, but you could use wire cutters to cut the plastic, and then regular pliers to pull out the metal stud. Mine no longer locks, and it's much easier to maneuver.
Sep 08, 2011 | Baby Jogger Citi Mini Stroller
BUSY SIGNAL UNABLE TO RECIEVE FAX
You should unplug your fax machine from the phone wire and call your fax number to see if it is still busy. If it is then you have some other device sharing the line that is holding the line busy or a short in a wire. Remove all other devices (computer modem, credit card machine, cable/satellite box, alarm system etc) and check again. If it is still busy you may have to call your phone company to have them diagnose the problem. If the line is cleared start adding each device back to the line and check between each to see if the line busy's up. If it does it may be the device or the wire (the wire may be damaged and shorting the line).
Jun 15, 2010 | Brother IntelliFax-4100e Fax
I have a RCA Proscan PS35653 that won't power on. I have had this happen before & took it back to Circuit City where I purchased it. They repaired it but are no longer in business. It didn't cost much...
These units are famous for high voltage/horizontal problems which could have affected the power supply. Parts are beggining to be no longer available for these sets. Have a shop give you an estimate before putting a lot of money in it. Thanks for using fixya.
Jan 02, 2010 | RCA Televison & Video
Brothet HL-1870N gives Error E50
For the Brother HL-1850/1870N printers, clearing the "Service Call Error E50" in the LED display simply requires depressing the "Go" and "Set" buttons simultaneously while turning on the power. Continue to depress the "Go" and "Set" buttons until the LED display shows "Go Test Mode". Release the "Go" and "Set" buttons, the depress the only "Go" button again and the printer will start normally.
If problem persists, let me know.
Thanks for using ' Fixya ' and have a nice day!!
Aug 30, 2009 | Brother HL 1870N Laser Printer
An e50 error has appeared on the menu of our Brother HL8050N
The Service Error #50 is basically a Fusing Unit problem and you may actually find out that you may have to replace that assembly, to correct that error condition.
E50 means fuser malfunction. Try to print a configuration sheet (press 3 x set). If that doesn't work, you've to change the fuser.
There is probably caked ink and dust on a wire connection that touches the grey roller of the fuser (that has two rollers). It seems this will happen to a lot of the brothers. You just clean the connection. It's simple, but you have to get to it by removing a lot of screws, pieces, and wire jacks.
To summarize:
Remove top cover, and various plastic pieces in the back to get to the fuser. Then take out the fuser and find the 2 black wires that lead to the problem piece that needs to be cleaned.
When you have gotten to the fuser, remove the two wire jack connections. Remove the two screws holding fuser in. One of those screws is big with a spring - don't worry, the spring stays in place. The other screw looks normal, but it is a little longer than the other screws so remember where you lay it. Find the 2 black wires on the fuser leading to the problem piece. Remove the single screw holding it in. Pull it out and clean the wire connections. Now put things back together!
This is really specialist work (the taking apart and putting back together) for a simple cleaning end. Not for the faint-hearted!
It will either be a complete nightmare or a fun project for you..
I would personally take it to a specialist and get an estimate, and measure that against the price of a new printer. But, if you feel brave and have nothing to lose, have a go..
So you know what the problem is, but can you fix it yourself? Well that's down to you, I can't answer that ;)
Chris (ziraffa)
Dec 29, 2008 | Brother HL 8050N Laser Printer
Flashing red light
On the alarm and data light blinking, it is saying the toner cartridge is empty. You will need to replace it. Once in a while you can remove the toner cartridge and shake it and have it work for a little while longer. This does not work all the time however.
If you can't get it to work by shaking it, you will need to purchase a new toner cartridge.
When you have the new cartridge, you will need to slide the blue corona wire cleaner back and forth. This is just in front of the toner cartridge in the drum unit on the top of the drum unit. There is a small light blue colored piece of plastic with an arrow in it that you will just push back and forth. This will help the drum unit do its job better.
May 06, 2008 | Brother HL 1440 Laser Printer
Brother EM530 Knobs
Brother is a problem. There aren’t many “Brother Authorized” service centers (in fact the one I worked for is now out of business) and only “Brother Authorized” repair centers can buy the parts from Brother. If you can’t find an ”Authorized repair center” in your area, I might be able to help, if you send me you city/state I might be able to locate a service center but they might not want to sell you just the part, The policy when I was working at a Brother Authorized service center, was we could not sell parts and could only sell parts that we install (during a repair).
Mar 04, 2008 | Brother EM-530 Typewriter
Alarm light stays on
i had a similar problem, but my alarm light was "only" blinking. here is what i did (and might work with your printer too): open the front and take out the drum&toner unit. take out the toner cartridge und put a little piece of paper in the hole (the one you can look right through to the other side) either at the right or left side of the cartridge. put the toner in the drum unit and then everything back in the printer. after that my printer worked and still works fine.
Feb 13, 2007 | Brother HL 1440 Laser Printer
7701V  Responder 2way Transmitter LCD Paging Remote Transmitter Logo
82 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
