Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Will not play dvd.- it says to check disk. On starting, the dvd chamber clicks multiple times, then it says to check disc, then it turns itself off. Thank you.
    Problem Solver:
Hi
Try using a DVD/CD laser cleaning disc.It sounds like it's having trouble reading it.
Saying that with a lot of combi units sometimes the DVD drive fails down to using cheaper components to keep the price low.I guess that's the price you pay for buying two units in one.
Try cleaning the lens first though.
Good luck....
Posted on Nov 17, 2010
DVD player automatically stops and turns itself off, how do I prevent this?
Warning: Laser inside! If you want to open it up and troubleshoot, make sure you don't point toward your eyes.
Check the nylon laser carriage to see if it slides laser from center to outside line. If it sticks, it's probably shutting down from not properly reading a disk.
Aug 03, 2014 | Pioneer DV-343 DVD Player
When i put in a dvd, it makes clicking noises, after that a notice
follow this steps and fix it. God bless you
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Nov 14, 2012 | Sony Televison & Video
RDR-VX560 have recorded about 250 programs, on DVD-R and DVD+RW discs. Recently I went back and made sure that all had been finalized. I then checked out their operation on both the recorder and my new...
I'm sorry that the discs are not being able to read using either Computer nor with the Recorder itself. Based on the information you have provided, it appears that the discs are corrupted. Please check whether other discs are playing fine with the Recorder and computer to make sure that the drives are fine. If Recorder and Computer playing fine other discs, we can confirm that the issue is with the discs itself.
Clean the discs using a soft cloth starting from center to straight toward edge.
Use any software recovery software to recover the data. I have provided a link where you can download one for free. Click here to download the data recovery software.
Clean the discs by following the below step.
Thus cleaning the disk should always be your first move. Run warm water over the damaged disk to remove dust. If there is stubborn dirt or grease on the disk, gently rub it with your finger while you are washing it, and use a gentle detergent or liquid soap (with the water) or rubbing alcohol (in place of water). Anytime you rub or wipe a CD or DVD, you should do so by starting at or near the center of the disk and rubbing straight outward toward the edge to prevent further scratching. Shake the water off and let the disk air-dry (do not dry it with a towel or cloth, and don't sun-dry it either).
Now play the discs directly on the computer and recorder. If the issue persists, try again using the recovery software.
I hope the information helpful, please let me know if you require any clarifications.
Thanks for understanding.
Jan 18, 2012 | Sony RDR-VX530 DVD Recorder/VCR
A Game I bought will not work.
Check the inside ring of the disc for a v shape deformation or cracks. also look for dimples. That is usually the problem with some older 360 games.
May 27, 2010 | Video Game Consoles & Games
Hello my DVD drive will not play and will not show
Can you check whether you Disc Drive is well connected ?
to check the device :
Right click on my Computer
Select Properties
Hardware devices
Device Manage :
Check your Dvd/cd drives.. whether everything is connected.
If not try re-installing the device or to update it.
or try this
go to start
right click on my computer
click on manage
then click on storage
then click on disk management
then right click on your device and select add letters and path
window will pop up then click on add
the select an alphabet and click on ok
Hope your problem got solved. Thanks
Apr 20, 2010 | Toshiba Satellite L305-S5911 Notebook PC
Disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Jan 10, 2009 | Coby DVD-211
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Panasonic DVD-S47
If you still have a warranty on the Dvd recorder send it in for Repair.It's either a Factory Defect or a sort in the control switch.
Dec 21, 2007 | Samsung DVDR120 DVD Recorder
Ps2 keeps saying disk read error everytime disk is put in no matter what disk is put in what can i do to fix
  • Confirm the disc is inserted correctly into the PlayStation 2 console (label side should be facing up when the PlayStation 2 console is in the horizontal position).
  • Confirm the disc is clean. To clean a disc, use lint-free cleaning cloths made specifically for cleaning CD/DVD discs, sold at computer software stores. When cleaning the disc, we recommend starting from the innermost circle, and wiping out to the edge in a straight line. We do not recommend wiping in a circular motion, as it may create more scratches on the disc. [Note: Other materials, such as a paper towel or a T-shirt, may also scratch the disc. If there are any scratches, smudges, or fingerprints on the disc, it may not function properly.]
  • Try playing different CDs, DVDs, and games on the PlayStation 2 console to see if the problem exists across multiple discs.
  • To determine if the problem is with the disc itself, try playing the disc on a different PlayStation 2 console (or a PS oneTM or a standalone CD/DVD player, if applicable).
  • Confirm that you are not using any game modification devices. Unlicensed devices such as game modification devices can interfere with the proper function of the software. We do not recommend the use of any game modification devices or unlicensed products[1].
Dec 17, 2007 | Sony PlayStation 2 (PS2) Console
DVD Won't Play
You can try to uninstall the hardware, turn off the PC, and then allow Windows to find it when it reboots. Or you can try to update the drivers for it by going to the manufacturer's website. (google is your friend :D) You can also try the restore function located at: start -> all programs -> accessories -> system tools -> system restore restore it to a earlier time when it was working with no problems.
Mar 22, 2007 | Samsung DVD-ROM 16X Internal IDE/EIDE...
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
95 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
