Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
My linksys w/2phone ports cannot hook up with the ethernet
  • Linksys Master
  • 7,733 Answers
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
my linksys w/2phone ports cannot hook up with the - kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click .
Step 4:
Click Save SettingsStep 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access tmy linksys w/2phone ports cannot hook up with the - kb17251-005_en.pngou're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Posted on Nov 15, 2010
Diagram to hook up wireless router
Are you trying to setup router?
You can do it manually without CD.
Connect the modem to the Internet port on Linksys router. The connect one computer to Ethernet port 1 on Linksys router.
Open the setup page of the router and change the settings manually.
See Linksys router setup
Jan 02, 2012 | Linksys Wireless-G Broadband Router
Do you have a diagram on how to hook up the router to the Desktop Computer. Computer is ready for the router but not sure how to hook it up. I presently have internet on my existing computer and am...
Hi, you can hook the router to your computer using a standard Ethernet cable (the one with connectors that look similar to phone jack connectors, but a little wider). You should have an Ethernet port on the back of your computer, and you can connect the cable from there to the Ethernet LAN port on the router.
Jan 19, 2011 | Linksys Wireless-G WRT54G Router
Is there an instruction layout showing me how to hook my router to my modem ? I need something with Pictures - we are not computer savy ..
What I have is not exactly a layout, but suggesting that pictures would help, click on this link here: Linksys Router Install Port Guide with Pictures
Same principle. Plug one end of the ethernet cable from your modem's ethernet port, then the other end goes to the port on your Linksys router with the yellow "Internet" sticker. The other ports are numberd 1-4. You may connect your computer directly from there.
Nov 17, 2010 | Linksys WRT54G2 Wireless Router
I have a cisco linksys wrt54g2 v1 that I have hooked up to my verizon dsl modem. My computer says I am connected but it wont let me get on the internet. If I plug the ethernet cable from the modem to my...
Connect the cable from the LAN port on the DSL modem to any of the 4- LAN ports on the Linksys Swicth (not the port Labelled Internet), then from any of the remaining 4 ports then connect your computer. Also try using a cross-over cable to modem from the DSL LAN port to the Linksys.
Oct 24, 2009 | Linksys Wireless-G WRT54G Router
WRT300N is no longer detected
Hook up your ether cable to a port other than the WAN port.
Type this into a browser...
http://192.168.1.1
Linksys WRT300N Wireless Router. ... Default IP address: 192.168.1.1
Oct 01, 2009 | Linksys WRT300N Wireless Router
How do i reconnect linksys
Oh man your going to have to help me out a little on this one. Do you mean you had to unhook it and connect directly to the modem and now you want to hook the router back up? If thats the case Unplug all the devices (Pc's modem and router) connect an Ethernet cable from the ethernet port on the back of the modem (not the linksys) to the internet ethernet port on the linksys (usually set a little apart from the rest) then connect all the computers to the routers ethernet ports (usually labeled 1-4) then turn on power to the devices starting with the modem, wait for it to completely boot up all the lights like they're supossed to look. Then turn on the router and wait for that to finish booting up then all of the computers. If you have wireless devices that will take a little more help.
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Linksys router
Connect modem to internet port of the router and computer to any numbered ethernet port.
Feb 19, 2009 | Linksys Computers & Internet
LINKYSYS HOOK UP
connect ethernet cable of your computer lan card to ports on linksys router ethernet port.
then acee in browser tis link
http://192.168.1.1
then username is admin pasword also admin.if not login then try username blank and pasword is admin
then set dynamic ip adreses enable .asl oset in your tcp /ip properties in lancard.set it to obtained dynamic ip aderss auto.aslo make sure in link sys that dns also automatic geting from isp.
thatys it.
u get INTERNET NOW FROM YOUR ISP.
Oct 25, 2008 | Linksys Wireless-G WRT54G Router
Hooking up wireless linksys
From ethernet of embarq plug it to the Internet port of Linksys. Your PC should be connected to port 1 of Linksys
Aug 17, 2008 | Linksys Wireless-G WRT54G Router
Trying to install second linksys wireless router and an error message is coming up
What is the error message?
Also please tell me exactly how you have everything physically setup.
for example
Modem- ethernet cable- router 1 's wan(internet) port- ethernet cable(which port 1-4?)- router 2's wan(internet) port
and if any othe computers are hooked up to it through ethernet cables, please include that.
Apr 17, 2008 | Computers & Internet
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
131 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
