Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Starter Can not start. Was getting more difficult each time to start and keep going. Mower is 2 years old.
  • tenniswgc Jun 19, 2008
    Electric mower (19" Electric Lawnhog Mulching Mower with Rear Bag Section) not a gasoline engine. Please take this in consideration.
Well Tennis these electric mowers use brushes in their electric moters and they have a tendace to go bad after a few years of heavy use. I would guess you have a nice size yard. The origanal equiptment isn't always the highest quility. You nmay just need new motor brushes and clean the armature. Hope this helps. Farmer Randy From Guthrie
Posted on Jun 26, 2008
    Champion:
  • 313 Answers
Check out www.smallengineadvisor.com for trouble shooting & repair. think mower needs tune up etc.
Posted on Jun 19, 2008
  • mr aicnelav Jun 19, 2008
    will specify what model then.
    starter haa
Lawnmower very difficult to start
Hello. Get a can of starter fluid. A couple of good squirts into the air cleaner and it will take right off for you. J.
Jul 03, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
I have a 2 year old push mtd lawn mower , it wont ...
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
May 20, 2010 | Mtd 22" Yard Machine Push Mower
Electric Starting Difficulty on Toro mower with Tecumseh engine
it sounds like to me that the starter pully is getting caught up on the worm gear ,this could be because of dirt or grass getting in the way make sure that no grass or dirt is around the worm gear
Mar 03, 2010 | Garden
I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Sep 28, 2009 | Garden
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Continuously stalling and extreme difficulty restarting.
The brass "Bolt" that holds the "cup" on the bottom of your carburetor is also the main fuel metering jet for the engine. Get yourself a can of automotive carb cleaner, the aerosol type that comes with the small red plastic tube on the side of the can. Remove the "Bolt" and "cup". (Tip: tilt the carb side of the mower UP about 45 degrees and support it with whatever you have, wood, bricks etc. This will help stem the flow of gas from the tank while you have the "cup" removed.) Examine the "Bolt" and you will see one or two small holes in the side of the "Bolt" between the hex head and the threads. These are the metering orifices. Use the carb cleaner to throughly clean the "Bolt" orifices. (Tip: DO NOT attempt to 'drill' the orifices clean) Next, use the red plastic tube to spray carb cleaner up through the hole on the carburetor that the "Bolt" screws into. Be liberal with the cleaner. Finally, clean the "cup" with the spray one more time for good measure. Put everything back together. (Tip: easy does it on tightining the "Bolt") Level the mower, check for leaks and verify the oil level is OK. If the plug and air filter are up to snuff you should be good to go. (Tip: how old is your fuel? You should keep it around for only about 30 days unless you use fuel stabilizer. These little engines LOVE fresh fuel) Good Luck.
Jun 26, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Toro Electric Start Mower Barely Turns Over
this is easy to point out the problem. if it is still under warranty get warranty replacement of the starter is not you might be better off just buying a new mower might be easier and cheaper because if your not still under warranty with it it will cost you quite a bit of money if you can't replace it yourself it will cost you the amount of the new starter and it will cost you the amount that the shop's labor fee which can vary a lot depending on where you take it.
Jun 13, 2009 | Garden
Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Toyota Town Ace, 2-litre turbo. G reg. Diesel automatic (UK)
If it is clicking, the solenoid is activating as it should so there is either a wire loose on the solenoid, a wire loose on the starter motor or the starter motor needs new brushes.
An old trick if the starter motor needs brushes is to hit it with a lump of wood to jar it.
Mar 03, 2017 | 1985 Toyota Passenger
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
