Question about Microsoft Xbox 360 Console
Once my game is loaded into tray the screen comes up and tells me to open back up and close again. This occurs all the time not just with one game. Any suggestions???
  • 767 Answers
Yes. First when the tray is opened watch the green light . It should
blink then stay on steady.
When the tray is closesing you should see a blinking
green light in the center of the ring of lights .When the tray
is fully closed and engaged the light will stop blinking then you
should hear the drive spin-up. If not open the tray then close
it ,just as the tray is almost closed push it close hard then the
green flashing light should be steady on.
This is cause mostly by friction in the drive or a bent
leaf switch that the tray engages to tell the console
the state of the tray .
The remedy is either you or a shop
will need to open the drive and remove the frictions
points which very from drive to drive. and check the
leaf switches . cost 40.00 or so . or you could
simply buy a "new" drive on ebay and swap the
Drives P.C. board from the old drive to the new one
price 40.00 but you supply the labor.
I gave you more info than you need but this is
common problem and I hope it will help others also
If you have any questions please feel free to ask
Rob
Posted on Nov 14, 2010
DVD Tray will not stay closed
There is a leaf switch inside the loading mechanism, which detects the tray to fully closed state. If this switch has damaged, this kind of fault will occur. To repair it, you have to open the set, and take the loading mechanism out, and disassemble it. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 06, 2013 | Haier TDC1314S TV
Cd is loose inside sytem
yikes! ive had that happen to me once before because i was moving my xbox around a lot and had the disk inside. and when i opened it, the disk didnt come with it. i closed the tray and opened again and the game resetted back into the tray. never again will i move any console with a disk in it again!
Jan 21, 2012 | Microsoft Xbox 360 Console
My xbox 360 doesnt want to read the game. when i put in gears of war, it tells me to open tray. i open it then close it and again it tells me to open tray. ive done the clean cd and still the same thing....
Unfortunately this is a common issue with the xbox. If you have tried all the steps that are provided on the xbox support website, it may be time to call xbox support and get your xbox repaired. If it is out of warranty, I'd honestly just get a new one cause the repairs run about $120 out of warranty.
Aug 17, 2011 | Microsoft Xbox 360 Console
When turning on my xbox 360, it will not load any games automatically. it says open tray, i open and close tray several times for it to finally load the game so I can play. Also at times when gam does...
This is a problem occurring in all the xbox 360 consoles....... this is mainly because of the poor quality of the disc,.....as a result it leads to the damage of ur xbox lens..............use good original discs........the heating effect is due to the long usage of pirated discs ...
check your lens if its working good then better download this Repair Guide for further information .........
all the best.......
Dec 07, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
Open tray comes up when loading a game?
Try tapping above the disk drive or if that doesn't work open the tray take your disc out close the tray. open the tray put ur disk back in and close the tray again.
Mar 15, 2010 | Microsoft Xbox 360 Elite Console - Black
The xbox 360 elites keeps on saying open tray when trying to play
1, the disc may be dirty
2. the mian reason for this your xbox drive cannot read the disc , because the power of the lens is gone(not completely) ,
solution:
1. keep your disc inside the drive and switch off the console, again swith on try this 2 to 3 time
2. keep the console in vertical position or little slanding position(180 dg) make sure it does not fall
3. its better to buy hatddisc and load the game inside it , so that u lens life increased
4. change the entire drive
Feb 09, 2010 | Microsoft Xbox 360 Console
C-0991 error on screen
First problem is for some reason your KMC 3130 crosses over to a Konica Minolta CF3102 and there is no C-0991 code listed for those machines. However, that C-0991 code is a common paper tray lift failure code on Konica MInolta machines.
So I would recommend opening and checking all of your paper trays to make sure nothing is binding them and that the paper is loaded properly.
Then open and close the large front door to reset the code.
If the code comes back then open all of your paper trays and LEAVE them open. Next open and close the front door to reset the code. The copier should now come to "ready to copy"
Then close each paper tray 1 at a time waiting 30 seconds between each tray closing. Once the code pops back up after closing a particular tray then you will know for sure which tray is causing the problem.
You can use the copier by leaving this tray open if need be.
Good Luck.
Nov 24, 2009 | Kyocera Mita KYOCERA/MITA - KM-C3130...
MY GAMES WONT LOAD
you need to unplug ever cable you have and every accessory you have. Unplug adapters memory units hd inter coolers every thing. let it sit for 10-15 minutes. Plug everything back in then press the button to open the tray to turn it on then put in a different game keep it open . Then when the menu comes go into a program so you can't see play game or close tray. Then when you are in the right place close the tray and it should load. This worked for me 2 times.
Jun 23, 2009 | Microsoft Xbox 360 Console
Will not play any disc
try to clean the lens in ur x box by buying a can dust remover or you could buy a dvd eye cleaner the wierd sound in just ur x box stalling on the game cause it cant read it
Mar 23, 2009 | Microsoft Xbox 360 Console
Disk format
1) Turn on machine
2) Open Tray
3) With tray still open hold the reset until the tray closes.
4) Tap the reset once.
if there is a format disc error, it says "Please insert a Playstation or Playstation 2 format disc." It is accompanied by a sound similar to the browser, but with a more tense noise. This is caused by a disc being so badly scratched that it completely fails to recognise the format, or if there is a problem with the laser. Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point.NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
Dec 15, 2007 | Sony PlayStation 2 (PS2) Console
Microsoft Xbox 360 Console Logo
75 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
