Question about Maytag Dryers
My model #MDE8400AYW electric dryer is getting hot but the clothes are not drying completely without running through two cycles.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Try cleaning out the vent. Lint buildup will cause this problem.
Posted on Nov 14, 2010
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
Shuts off during autodry cycle. stays on during timed cycle but clothes are wrinkled ans too hot at end of cycle.
if it works on auto but not on time you have a bad timer,it's not counting down,it's better to use auto anyway,when the clothes dry the dryer shuts off on it's own,this way your not using extra electricity,if your clothes dry in 30 minutes and it's on 60 minutes it will still run after the clothes are dry on auto it doesn't.if you open the door and look around the opening you'll see a tag with the model number,your missing a couple of letters on the model number.
Mar 05, 2011 | Whirlpool LER4634J Electric Dryer
Does not dry clothes, keeps turning off prior to
then it maybe the heat element.Is it getting hot and it may be the controll panel,there still could be sme lint stock some were,try using vacum hose and put in back of dryer it may free it up.
Jul 08, 2010 | LG DLE5977 Stainless Steel Electric Dryer
Whirlpool dryer does not get hot enough to dry clothes.
Clean/repair the dryer vent. If the airflow is restricted the result is the one you just described.
Good luck,
Vlad
First Choice Appliance
Apr 20, 2010 | Roper REX4634KQ Electric Dryer
Clothes do not dry completely on one cycle
Check your dryer vent (the entire length) for lint build-up. Check that the vent is opening properly (the flapper type can come loose and block air-flow).
Those are the most common reasons for an inefficient dryer.
I hope this helps.
(we have had the vent get blocked by the flapper)
Apr 03, 2010 | Whirlpool WED5300S Electric Dryer
Our dryer is a model # fer641fso. it is notgetting the clothes dry without running 2 or tree cycles. the dryer is very hot to the touch in the back and very warm on top. the vent is hooked up properly. any...
u have a clogged vent,,, undo vent to dryer run a load if heats faster then replace dryer vent, and clean out ur ducting with a leaf blower blow that ducting lint outside.
Feb 03, 2010 | Frigidaire FER641FS Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
66 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
