Lion electrec boiler is running constantly,have checked all relays and they have power. We have even turned the breaker on and off to it. The thermostats on both the boiler and the wall are turned down to the lowest setting and the temp. in the building iis 23 degrees celcius where it should only be 4-6 degrees.
  • 9 Answers
SOURCE: Carrier XHD183D Through-the-Wall Heater/AC runs constantly
YOU COULD EITHER HAVE A THERMOSTAT PROBLEM OR FAN CONTROL PROBLEM.TURN THE POWER OFF AT THE FURNACE AND TAKE THE THERMOSTAT OFF THE WALL.MAKE SURE YOU MARK THE WIRES SO YOU KNOW HOW TO HOOK IT BACK UP AGAIN.RESTORE POWER TO THE FURNACE.TOUCH THE WIRES THAT WERE HOOKED TO THE R & G TERMINALS ON THE T-STAT TOGETHER AND HOLD THEM THERE.OBSERVE THE OPERATION. WHEN YOU TAKE THEM APART DOES THE BLOWER STOP?TRY IT A FEW TIMES. IF IT CONTINUES TO START AND STOP YOU GOT A BAD T-STAT.JEFF
Posted on Dec 15, 2007
SOURCE: Rinnai 1004 - Temp on thermostat reads 10 deg cooler than actual, keeps running
The location of the sensor needs to be higher but my yellow wire would only pull out a couple of inches.
Turn off power to unit and remove front panel. Two screws near top/sides. Top of panel pulls out (unplug wire connector to indicator lights) and lifts off bottom tangs. Now you will see a coil of yellow wire inside unit. Remove the wire tie and you'll have enough yellow wire to locate the sensor well above the heater.
Posted on Dec 31, 2007
SOURCE: Rinnai rce-606tra II -- temperature is wrong
move thermister probe higher on back of unit
Posted on Mar 10, 2008
hotuna
  • 288 Answers
SOURCE: thermostat does not stop heat pump unit
Most of these problems are the program settings on these way overcomplicated thermostats. You will need to re-read the instructions on setting the programs. Or bite the bullet and buy a cheaper and simpler one. If you installed it yourself, make sure the settings on the inside are correct, like gas/electric heat, and 24 volts, stuff like that.
Posted on Mar 14, 2008
Accurate Joe
  • 61 Answers
SOURCE: heat pump auxiliary heat does not turn on
Turn up your outside thermostat in the outside unit.
You should have about 3 degrees difference in one stage to the next. So I would change the thermosat with one that has three stages of heat.
Posted on Nov 30, 2008
Changed the batteries in timer/thermostat but the boiler is still not talking to the transmitter heating still on can you help??
Is this a wireless system, meaning no wires between the thermostat and the boiler? If so, check to see if the code buttons have been reset. If this is a hardwire system, the relay on your control board may be stuck. In any case, you can always shut off the boiler by turning off the gas and/or circuit breakers.
May 31, 2016 | Water Heaters
Got a new red lion shallow pump hooked it up but would only run 10 secs got another one did the same thing checked with electrican to make sure power good is there a problem in the pump itself ?
Pump should be connected or wired to its own circuit with no other outlets or equipment in the circuit line. Fuses and circuit breaker should be of ample capacity in the electrical circuit. THIS PUMP IS TO BE USED IN A CIRCUIT PROTECTED BY A GROUND CIRCUIT INTERRUPTER. If not properly wired it will throw the breaker. Here is a link to a troubleshooting guide. http://www.redlionproducts.com/media/31140/_the-red-lion-troubleshooting-guide.pdf
Apr 02, 2015 | Cars & Trucks
WHY DOES MY BOILER PUMP CONSTANTLY RUN
there is usually a pressure switch this may be an indication of the relay switch not opening and closing properly....shut off power then remove the protective cover (usually on top of motor) inspect the relay contacts they may have some burn marks take an emerey cloth or fine sand paper and slide between contacts hope that works
Aug 02, 2014 | Grundfos Pumps Grunfos UP15-42F 1/25 HP...
I have a hot water boiler with 3 zone valves and 2 circulation pumps. I see no relays wired to pumps. Pumps run constantly
Sounds like a lot of unknowns from your article. Here are some basic checks
- if they are the honeywell zone valves and you try to open them and get resistance than 9/10 times the t-stat is not calling for heat and the valve should be closed
-if stat is calling and wants heat zone valve lever should be free of resistance when moving it
- 15-20 psi is a little high but could be normal based on the size of your place and the temperature you are reading these pressures at
-with the pumps always running seems to me that the pumps are hard wired to a constant electrical source, if you want optimal control install a taco zone controller
May 21, 2017 | Water Heaters
Constantly runs
Zone valve stuck, or switch on zone valve faulty.
Jan 05, 2014 | Biasi B-6 Oil Boiler w/ Riello Burner -...
Stiebel eltron boiler has a clicking noise when not turned on, if you press the CHANGE button it's comes on and doesn't click. Please help!
The clicking is possibly the thermostat relay trying to call for heat. Try turning down the thermostat...if the clicking stops that indicates that the problem is in the control board's relay. You will have to change out the control board. Don't forget to turn off the breaker for the boiler before you start the work!
Dec 26, 2012 | Computers & Internet
Radiator hot even when system is not on;boiler very hot to touch.
Your boiler is on, re-check t-stat. Turn breaker off and rad and boiler will cool.
Sep 09, 2009 | Water Heaters
2 green blinking lights
This is a cold boiler problem.
There are several reasons for a cold boiler...boiler element is open, no power to the boiler element, thermostat is not functioning properly, or it could even be a board problem not delivering voltage to the boiler.
First start by opening the top and reseating all connectors on the board, if this does not help then you will have to extract the insides of the machine from the case to get at any of the boiler and thermostat hardware.
Start by removing the 1 screw holding the inside workings to the outer case. This is located on the right top side of the machine beside the grinder.
Use great caution while pulling the guts out of the case and watch the dredge drawer switch does not hang-up on the case. Snake the power cord through the bottom of the case while pulling the inner workings out of the case.
There are 2 elements in the boiler check them both for a resistance (they will not be the same resistance) if either are open then then replace the boiler. Check the thermostat on the back of the boiler for resistance, if open or shorted, then replace. Check thermal breaker on boiler, this should be shorted if not, reset it by pressing the button in the center of the breaker.
If none of this works then you will have to depress dredge drawer switch front door switch and insert the brew group to depress the brew group switch, plug in the unit and turn it on.
Check for voltage on the elements on the boiler.
If no voltage then check all connections.
If you have gotten this far there is a good chance it is the board fault and it will need to be replaced.
Be shure to label all connections to the mother board as there are several connectors that can be placed in the wrong position while reassembling.
NOTE: This depth of trouble shooting should only be attemted if you are completely comfortable with electrical/electronic repair.
Mar 06, 2009 | Saeco Vienna De Luxe Espresso Machine
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
