Question about Vizio VW26L 26 in. LCD TV
MY Vizio vw26l won't turn on - Vizio VW26L 26 in. LCD TV
taran_2005
  • 10515 Answers
SOURCE: this a vizio vw26l the
As you mentioned that power light blinks for a half a second and does not come on, confirms that this is an internal hardware failure.However, in most of the cases it is due to a bad IC in the power supply unit.If you have experience in repairing electronics, could read schematics and would be able to keep precautions, you could open up the TV. Locate the power supply board and on that you could see some bulged / fused / swelled / leaked capacitors. De solder them and buy the same value caps from Radioshack or Fry's. Re solder them properly and you could fix the problem.
Other than this, it needs more advance troubleshooting which would need other testing equipments.You could revert once you check the power supply board and we could further continue.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 14, 2010
konabakers
  • 3 Answers
SOURCE: Vizio VW26L - Cable throws Breaker
Careful!!! Sounds like a serious electrical problem somewhere. Cable itself is by law bonded to earth ground. Might be the TV but most likely it's your electrical outlet has an open neutral circuit which means the current has no way to return back to the outlet and so it has to find another route. In this case its the cable system. Worst case scenario, its through your body. You probably have a 10 amp or 15 amp circuit breaker and if that is tripping you are getting a serious amount of current flow.Call an electrican or somebody who knows about this. Its a very serious situation which can lead to disaster of the worst kind. Sorry for doom and gloom but it wouldn't be the first time bad things happen for this very reason.
Posted on Aug 06, 2009
SD Tech
  • 14553 Answers
SOURCE: vizio vw26l
Follow the voltage with a meter into the power supply and out of it--check right at turn on and look for a voltage or voltages that come up and then go down instantly. Primary suspect here is power supply board and that needs to be examined in and out.
Posted on Apr 24, 2012
Slinteriors
  • 8617 Answers
SOURCE: vizio vw26l
replacing the power supply board should solve the issue you can get the replacement power supply board from www.tvrepairworld.com
Posted on Jun 02, 2012
SD Tech
  • 14553 Answers
SOURCE: vizio vw26l after about 20 minutes the picture flickers then blinks out, then back on
most common problems are in power supply or main board, a 26 inch set from a cost point of view just may not be worth fixing............?
Why does my Vizio VW26L say "No Signal". I have changed all capacitors.
input signal: HDMI, analog. are all the connectors back in?
May 12, 2014 | Vizio VW26L 26 in. LCD TV
Vizio VW26L won't turn on
Check and replace its main power regulator board.
Dec 18, 2012 | Televison & Video
Vizio vw26l
Jun 01, 2012 | Vizio VW26L 26 in. LCD TV
Vizio vw26l after about 20 minutes the picture flickers then blinks out, then back on
Vizio vw26l
Apr 21, 2012 | Vizio L32 32 in. LCD HDTV
Remote control code for vizio vw26L
BEADSRULE, IT WORKED! I HAVE A VERY OLD ALLFORONE REMOTE AND THE LG 0178 CODE WORKED ON MY VIZIO TV THANK YOU! ;)
Feb 25, 2012 | Vizio VP322 32 in. Plasma TV
VIZIO LCD 26 INCH model# VW26L HDTV10F NOT TURNING ON
unplug ur backlight inverter plug &power on to see ,if it doesnt on , change ur mainboard
Nov 10, 2008 | Vizio L6 20.1 in. HD-Ready LCD Television
Vizio VW26L 26 in. LCD TV Logo
693 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
