Question about Craftsman 22" Gas Hedge Trimmer
Craftsmen gas hedger starts then shuts off ,
If I haven't added Stabil to the gasoline for my Craftsmen 675, will that keep it from starting?
Ethanol gas can gum up the fuel system if left in unit for to long from now on use ethanol free gas in all small engines
Jun 22, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsmen 917289233 won't start
How is the quality of the fuel? Was the spark plug replaced? If so, was the gap set correctly? (0.30)
May 20, 2012 | Craftsman Garden
Hedger wont run unless it has choke on
Sounds like the carb is lean. Back out the adjustments 1 quarter turn and work from there. Also make sure air filter is clean.That should get ya going.
Dec 20, 2010 | kawasaki Kht600d Gas Hedge Clipper Trimmer
My hedger turns off when I turn it side-ways to
The problem with Ryobi trimmers is the siting of the fuel outlet pipe the trimmes has to be full of fuel at all times
Jul 11, 2010 | Ryobi 26CC, 22 In. Hedge Trimmer
Cant start model # 917.377590 a 6.75 hp eager 1 craftsmen mower
I want you to empty the fuel tank. ues a dowel rod to push a t-shirt type cloth in the gas tank and **** out all the gas and water from the tank. It worked for me hope it helps you also.
Aug 03, 2009 | Garden
Craftsmen air compressor will not start
Check the pressure switch, it turns it on and off. Possible reset on motor.
Jul 05, 2009 | Air Tools & Compressors
Is my engine seized?
SOME MOWERS HAVE A LOW OIL CUTOFF SENSOR,CHECK TO SE IF THE OIL IS LOW IF SO ADD CARFULLY
May 12, 2009 | Garden
Craftsman 22" Gas Hedge Trimmer Logo
63 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
