Question about Navigon 2110 Series Satellie GPS Receiver
When I power on my navigon 2100, it shows the a picture of navigon connected to a laptop; and does not do anything else. How can I fix this?
johnny5846
  • 379 Answers
SOURCE: need a navigon 2100 user manual
http://www.navigonusa.com/_pdf/manual/Manual_2100_2120_English.pdf
this is your manual .
Posted on Dec 27, 2008
SOURCE: NAVIGON 2100 won't move as I go down the road.
garyboop1 Try just rubbing you finger accross the screen, it should give you some result. Rusty1
Posted on Dec 31, 2008
SOURCE: plug in car charger and it shows navigon connected to computer
some chargers will not work i think somwthing to do with a micro chip in it.
Posted on Jan 05, 2009
PCTechOnline
  • 532 Answers
SOURCE: Navigon 2100 screen problem
When you changed your charger, did you get the right one?
I bought an iGo and thought I could use the standard min usb tip. However, tip number A53 does charge and show the map.
I hope this answers your question.
Posted on Mar 23, 2010
iadame
  • 676 Answers
SOURCE: looking for a motorcycle mount for my navigon 2100
The following web site will be able to help you out. They have several kinds. It depends which one you want. Being a Harley you probably want the chrome. Good Luck and please rate.http://www.gpscity.com/search/q=motorcycle
Posted on Jun 14, 2010
Testimonial: "Extremely helpful and much appreciated ! Thank you !!"
Fs201
I would suggest going here and reading about your unit.
http://reviews.cnet.com/car-gps-navigation/navigon-2100/4505-3430_7-32744602.html#reviewPage1
Go through the 2 pages.
Good luck
Apr 10, 2012 | Navigon 2100 Portable GPS Receiver
Navigon 2100 car charger unscrewed. Found a few
[PDF] NAVIGON 2100/2120 User's Guide Your NAVIGON 2100/2120 comes with the following accessories. .... With the NAVIGON 2100/2120, you can also use an external GPS antenna (not pro- ...
support.navigonusa THEIRS A SITE FOR YOU YOUR FUSE IS A 6V 1 A RADIO SHACK SHOULD HAVE ONE OR PACK OF 5 6 BUCK OR SO
May 08, 2010 | Navigon 2100 Portable GPS Receiver
Mar 23, 2010 | Navigon 2100 Max Portable GPS System
Navigon 2100 freezes when plugged in
sounds like you have the wrong charger did you buy a non gen one? you can charge it from the pc with mini usb lead, but will show the same screen
Dec 06, 2009 | GPS
Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Sep 13, 2009 | Navigon 2100 Portable GPS Receiver
Dec 31, 2008 | Navigon 2100 Portable GPS Receiver
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
Navigon 2100 problem
2 things that might help...use a paperclip and press the reset button (small hole on side, you'll feel a click) hold it for 5 seconds. THEN hold down the power on button for over 10 secs (keep holding while it shows version number) and it will perform a factory reset. You will possibly lose any settings and addresses, but better that than a locked GPS unit.
Oct 10, 2008 | Navigon 2110 Series Satellie GPS Receiver
Open Questions:
See all Navigon 2110 Series Satellie GPS Receiver Questions
Navigon 2110 Series Satellie GPS Receiver Logo
Top Navigon GPS Experts
perdue40
Are you a Navigon GPS Expert? Answer questions, earn points and help others
