Question about Cycling
How do i change it from kph to mph? - Cycling
    Problem Solver:
  • 7 Answers
You'll need the instruction manual. If there is no reset hole on the back of the unit, you'll have to remove the battery for a few seconds. The first option in reprogramming the unit is generally tire circumference, and the next is kph/mph. You can toggle between them before pressing the "accept" button.
Posted on Nov 22, 2010
Changing kph to mph
Doesn't make any difference to mot whether kph or mph
Sep 28, 2013 | 2009 Keeway FAct Racing 50
How i can change mph to kmh
Anon, Remove ground on battery with ign still on to drain all power...now turn ign off, attach ground press hold lap timer button the clocks will do a cycle all way round, then the bike will flash mph kph mph kph 10 times in this time when its on mph release the lap timer button, after this bike will now read mph.
Jun 18, 2013 | 2010 Derbi GPR 125 4T 4V
KPH to MPH speedo display
Hi, Dan for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
How to change from kph to mph raptor 700
http://www.motorcycle.loc8apart.co.uk/nav-mc/bike-part/Yamaha/BT-1100-Bulldog/Speedometers.php
Yamaha BT1100 2002 Service Manual
OEM parts for Yamaha
YAMAHA BT1100 Owner Manual
Jan 27, 2013 | 2006 Yamaha BT 1100 Bulldog
I have a 2007 Bonneville purchased in Switz but now registering in the UK. The speedometer is in KPH and must read MPH - can I just replace the KPH faceplate with an MPH faceplate or do I have to replace...
Hi. I have a 2006 Bonneville which needs changing to K.P.H. as I have just moved to France. I also have to change the headlight lense, how do you fancy doing a straight swop. My speedo has nearly 10,000 miles on the odometer
May 09, 2012 | 2007 Triumph Triumph Bonneville
I have recently charged the battery on my Triumph TT 600. The speedo has gone into kph. How can I change it to mph?
Try this....should switch it back and forth
At the odometer setting (the one that shows your total miles you have on the bike) press and hold the "select" button for about 8 seconds. MPH goes first to KPH. Press and hold again and your radiator setting goes from F to C. Press and hold again, C stays put and KPH changes back to MPH. Press and hold again and you're back to MPH and F.
Mar 24, 2011 | 2001 Triumph TT 600
How do i change my 1999 r1 clocks from kph to mph ????
if it has a mechanical cable you can buy an adapter that fits between cable and speedo which converts kph tp mph, try this site www.mandp.com
May 27, 2010 | 2000 Yamaha YZF-R1
Speedometer is on kph and how do i change it to mph
Press "A" buton for 5 seconds, read out ill flash. Then press button "B" this will now change to mph. Re-press button "A" agin for 5 seconds nd the diplay will return o your default screen.
May 11, 2009 | 2000 Aprilia RSV Mille SP
Speedometer reads in KPH, can this be changed?
Go into setup menu in the DIC til you see unit measure! Then select unit measure and everything will be back to normal. One is for kph and celcius, Liter/100km, fuel liter used etc and the other one is for mph, farhenheits, mpg, fuel gallon used etc.
Aug 11, 2008 | 2005 Cadillac CTS
Cycling Logo
130 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
