Question about Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
Im trying to change the primer bulb on a ppb200e
    President:
  • Poulan Master
  • 1,545 Answers
They usually just snap in place if they are a remote type bulb (on the side of the intake housing) and if it is a carburetor mounted bulb, removal of a couple of screws usually does the trick. I would try and press the old bulb assembly out of its housing (from back (where nipples are)pushing towards the front (where the bulb itself is). Careful, not to crack the housing around where the bulb assembly is snapped in.
Posted on Nov 16, 2010
Why won't primer bulb fill on homelite 26cs weadeater?
a primer bulb should not actually fill, that said, if it is not priming your carb then there might be a tiny crack or pin hole that is letting air in as you try to prime, order and change the primer bulb.
Oct 16, 2016 | Homelite Garden
Changing a primer bulb on a poulan pro chainsaw?
If it is one those that is extrenal to the carburetor you change the whole primer assembly and not just the bulb.
Feb 26, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Bulb primer replace
You need to make sure you have connected the fuel lines up correctly to the bulb, they pull fuel from the carb and push it back to the tank not the other way round
May 18, 2013 | Garden
How to change primer bulb on Husqvarna 125 b leaf blower
Remove air filter cover,remove air filter, remove two nuts holding the assembly,pull primer bulb assembly out,remove primer tube. Reinstall in reverse order. http://www.ebay.com/itm/530047721-POULAN-WEEDEATER-RED-SNAP-PRIMER-BULB-/190568099240?pt=LH_DefaultDomain_0&hash=item2c5ebe6da8#ht_1848wt_718
Aug 31, 2011 | Husqvarna Hand Held Blower 125 B Grass...
Otmail.com Buble thing at carburator has stuck in and will not come back out any advice
I believe that your question is in reference to the primer button on your carburator. If this is so and your button is pushed in then you will have to change the button. Take a pair of needlenose pliers and pull out the damaged primer bulb. Then go in with a pick tool and pull out the ring that is seated in the carburator at the bottom of the primer bulb. With the old primer bulb out of the carburator you can now install the new primer bulb. Put new primer bulb into place and with a dull punch slowly and very carefully seat the new primer bulb. This should put you back in business again. GOOD LUCK.
Jul 05, 2011 | Briggs & Stratton Garden
Homelite chainsaw gas line diagram witch one goes where have the primer bulb
Take the primer bulb off.Look on the back side of it.Most will say tank and carb.If not try putting them on if the bulb doesen't get gas in it.Change them around.
Feb 27, 2011 | Homelite ZR10926 16" Chain Saw
Primer bulb will not remain full. Blower will start but dies when throttle is used. Appears to be leaking air around the grommet to the fuel tank.
you should maybe change grommets/pipes to the fuel tank,also the primer bulb maybe is not working properly,consider changing the primer bulb,rgds
Sep 25, 2010 | Echo Garden
What direction does the fuel flow into a weedeater primer bulb?
The fuel will flow from the fuel tank to the carb, after going thru the primer bulb, it will fill the carb with fuel and then be shut off after the float in the carb shuts off the fuel flow from the primer bulb.
Hope this helps,
Good Luck,
Please rate me....
Thanks
Mar 03, 2010 | Garden
Need diagram/instructions on how to replace primer bulb on briggs and stratton push lawn mower My primer bulb has busted so I'm trying to replace. Don't know how to get the old one out and replace.
Unless they have changed, all you have to do is unscrew the old primer bulb and screw the new one on in it's place. The primer is composed of the rubber bulb with a metal or plastic ring with threads on it where it connects in the fuel system.
Jul 17, 2009 | Garden
Primer bulb for troy bilt trimmmer gets stuck while trying to prime engine
Primer bulbs can soften and the bulb will stay in or spring back very slowly. If that's the case the solution is to get the bulb replaced.
Jul 07, 2009 | Garden
Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer Logo
119 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
