Question about Lakewood Oil-Filled Electric Radiator Heater
DeLonghi stretto TRS0815 T (1500 w) is oil leaking. what can i do and where can i go to fix it? i cant find the right place on internet.
  • Lakewood Master
  • 43,501 Answers
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman101
Posted on Jan 12, 2011
Hi Our Delonghi Rapido heater has just started leaking oil, maybe a mL or 2 a day. Can this be repaired?
When a compresser leaks oil it is dead. If this is an air/heat unit you are out of luck. If anything I said does not match the facts of your system disregard my comment.
Jul 18, 2011 | DeLonghi 6507L Oil Filled Radiator Heater
I'm looking for a manual for your oil filled heater 6707E
Hi and welcome to FixYa, I am Kelly.
FixYa is not an affiliate of Delonghi but you did come to the right place.
I found your manual.
You first need to go to this webpage:
http://web1.dlservice.org/dlservice/ext/delonghi/libretti.php?rec_a=6&rec_b=TRA
and then scroll down to 6707E and click on that.
It brings up a a line of numbers. (Product code)
0108678300 There are 4 language choices. Rt click the manual and save it to your computer. Thanks for choosing FixYa Kelly
Dec 09, 2010 | DeLonghi 6707E Oil Filled Radiator Heater
My Delonghi A120LE Drips water not sure why
OK. This fixed my A120LE from leaking. First unplug the machine for safety. If you are looking at the back of the unit you need to take off the right side panel. I took off the all the panels but you could just take off the right side.
There is a reservoir on the top that collects condensation from the top coil. (shown in the circle) The drain hole on mine was clogged. If you stick a small screwdriver or paperclip in the hole to push the debris through it should start working properly again. I did this to mine yesterday and it hasn't leaked since!! Drain hole is shown here in close up picture. Unclogging this will allow the condensation to flow down to the main reservoir on the bottom where it will be evaporated in the AC exhaust.
Jul 16, 2010 | DeLonghi A120E Air Conditioner
DeLonghi A120 12,000 btu ar conditioner Leaks
Jul 10, 2010 | DeLonghi A120E Air Conditioner
Problems with handle alignment
I had to use some olive oil around the outside of the filter cup holder to get it to move all the way to the right. After the first couple of times I was able to get it on straight without any oil...
Mar 15, 2008 | DeLonghi EC155 Espresso Machine
DeLonghi oil filled heater typ.061563
Hello I have a Delonghi KR031225 found that after turning it on and it heated up it began leaking on the bottom corner on the same panel that holds the controls? What could be wrong? Is it beyond repair?
Thanks
Mel
Jan 29, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Leaking Oil from the front
DONT BUY A NEW ONE THEY ARE EXPENSIVE ... THEY PUT OUT VERY LITTLE ACTUAL BTU'S OF HEAT ...IT WOULD BE DANGEROUS TO TRY AND BRAZE ANY LEAK POINTS AND THE OIL IS NOT CAR OIL AND NEEDS TO BE FILLED TO FACTORY SPECIFIED LEVELS. (THESE ARE NOT MEANT TO BE RE-FILLED OR DOES THE OIL USUALLY DIASAPATE). OIL HEATERS OF THIS TYPE USE PLENTY OF ELECTRICITY. I SUGGEST A "HIGH QUALITY, THICK CASED, WITH TILT SAFTY, ELECTRIC SPACE HETER WITH A FAN. THEY HEAT PROBLEM AREAS SAFE AND EFFECTIVELY.
Apr 26, 2007 | DeLonghi 9707 Oil Filled Radiator Heater
Lakewood Oil-Filled Electric Radiator Heater Logo
622 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
