Question about HP Officejet 7210 All-In-One InkJet Printer
Lines are plugged into competer but printer will not turn on
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Try this...
Posted on Nov 14, 2010
Hello there please guys help me I bought ecs elitegroup motherboard but it doesn't detect my g210 invidia geforce after plug my graphic cart it shows strange lines
suspect you may need to disable the motherboard built in graphics card and tell it to use PCI graphics adapter otherwise an interrupt conflict in CPU and possible conflict as both devices compete for same computer resources.
Aug 14, 2015 | EliteGroup Computers & Internet
Intermittent starting. A curious problem. Car will start sometimes. Other times will crank and crank but will not start. Put new spark plug wires on, still the same problem.
It might well be the fuel pump if it cuts out on corners, there might also be crud in the fuel tank or lines. It is probably likely related to fuel supply issue of some kind. But it may need the services of a competent garage to diagnose properly
Good lUCK
May 31, 2015 | Cars & Trucks
My photodsmart 5520 has quit coping all I get is black lines
Are they horizontal lines or vertical lines??
however you can follow the below steps
1. unplug the power chord from the back of the printer without turning the printer off... then press and hold the power button for 30 sec... then release the button... then plug in the power chord chord back to the printer.. check if it is making a copy or not..
then clean the rollers with a lint free cloth.. however the lint free cloth should e moistened with water... then clean it properly...
then do a reset on the printer..
Press BL/TL/BL/BL Buttons, in sequence. (BL: Bottom Left , TL: Top Left)
Touch Support Menu.
Press Right arrow for Reset Menu and Touch OK.
Press Right arrow for Semi-Full Reset and Touch OK.
Wait for unit to Power Down/Turn Off.
Press Power button to turn the Printer On.
THEN CHECK IF IT WORKS OR NOT...
Then try making a blank copy and check... If its still the same then service the product..
Nov 28, 2012 | HP Photosmart 5520 e-All-in-One -...
Alignment off
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please try this approach:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Align to fix blurry edges. Your printer will then print a page and aligning your print cartridges. Try to print a document again to verify that the problem is fixed.
Dec 11, 2011 | Lexmark X7170 All-In-One InkJet Printer
I have a zebra zm400 prinetr givig me an error message (head element bad)
turn printer off, press PAUSE button, turn printer on and wait 5 seconds then release the button. The printer is going to print the test label, check if coming some withe lines across the print. try to clean the printhead and the rollar, if pressist, need to replace printhead.
Please check if the cable from the printhead is totaly plug-in
Oct 15, 2010 | Zebra 105SL Thermal Label Printer
I need to connect a 34oo series lexmark printer to a dell comp. xp
Not sure how much I can help you.
*Turn computer off.
*Plug printer into a port on the back of your computer. There are very few ports so you should be able to find one that makes your printer plug. Plug printer into power strip/outlet.
*Turn computer back on.
*Keep printer off for now. During installation it should tell you to turn the printer on.
*Put the CD that came with the printer into the cd/dvd drive. A menu should appear. You want to "Install" or "Setup" your printer. Something along those lines. Follow the instruction from there.
*After successful installation of the printer restart the computer.
That is as basic as I can make it. I hope this helps.
Thanks.
Jun 14, 2010 | Dell XPS 730 Desktop Computer
How to stop printing test page every time I turn on my printer
This is an aligment page.When printer print the page just follow the instruction on page put it on the scanner glass and finish the aligment.If your color or/and black cartridge is empty or clogged the aligment is not compete and printer will print this page every time when you turning it on.If your case is that just replace the cartridge and finish the aligment.
Nov 04, 2009 | HP PSC 1410v All-in-One Printer
Canon Pixma ip1500 is printing but very wierdly. random lines will not show up in black. If i change the color everything is fine but black will skip lines and such. Please help! Can't turn in job...
Your printhead is plugged and needs cleaning. If you remove the inks and then the printhead, you can wet and fold a paper towel and just dab the printhead gently on the wet towel. When you see a solid black line on the paper towel your printing should be improved.
Jun 23, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
MFC-440CN PRINTER fax error
Plug a phone into the line and listen for static. Too many phones on the line, bad lines,etc, can cause a poor line condition. Try the unit directly into the phone line, no answer machine or anything else on the line. Maybe the memory thing is it has a lot of faxes that it hasn't been able to send.
Apr 29, 2009 | Brother MultiFunction Center MFC-440CN...
HP Officejet 7210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
