Question about Samsung SyncMaster 932GW LCD Monitor
Flicker - Samsung SyncMaster 932GW LCD Monitor
  • 11,361 Answers
Check the power supply voltages and the caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 14, 2010
All lights flicker on my 1998 mystic
I wonder if all the lights flicker?
Some headlight bulbs aren't held into the reflectors as securely as others and can appear to flicker due to vibration, bumps and so forth. In this case the other lights will not flicker. A similar effect can happen when the bulb connections aren't positive.
If all the lights flicker it must be the voltage that is fluctuating due to poor wiring connections or a fluctuating charge rate/alternator performance.
May 06, 2017 | Cars & Trucks
Bought a new alternator due my old one FAILED the test. But, I still have the problem with my head lights flickering & stereo going off then on when I accelerate to go.
Diagnosing Common Automotive Charging System Problems
www.onallcylinders.com/.../diagnosing-some-common-charging-system-...
Sep 18, 2013 - Flickering gauges. ... Problem: The charge indicator light flickers while driving. .... My alternator has been replaced for the third time in 5 months. ... I bought a new regulator but it is still doing the same thing... .... my headlights wont turn on, car runs fine when jumped, battery last for maybe 3 hours, any ideas ...
All lights Flickering/Pulsating only when motor is running ...
www.cadillacforums.com/forums/cadillac-forum/t-221843.html
Feb 11, 2011 - So i have noticed for a while now that all my interior lighting (radio, tach, even ... Installed the battery and have not had issues starting since then. ... So now ipurchased a new alternator "just in case" figuring i would eliminate the .... Interior lights and headlights still seem to pulse/flicker while idling the most, ...
Lights Flickered. Replaced Alternator. Now more flicker? - Camaro ...
www.camarozone.com/.../lights-flickered-replaced-alternator-now-more-...
Apr 22, 2013 - 20 posts - ‎4 authors
Jan 19, 2016 | Cars & Trucks
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
How do you fix flickering on a Toshiba Satellite Synoptics Keypad
The on-off key probably reset the interface, try downloading a new driver software for it. If this fails then the mouse pad hardware needs replacing.
Aug 17, 2014 | Toshiba Satellite Computers & Internet
Sir my lg Laptop R410,Display flickering problem.How can I solve it?
- boot first in BIOS and check if it is still flickering
- if it flickers in BIOS, you need a replacement LCD or LCD cable
- if it doesn't flicker, then update your graphics or display driver
Jul 02, 2011 | LG Computers & Internet
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
Flickering lights alond with the engine!
it sounds like the voltage regulator is faulty.........it is integrated into your altenator so you will want to have your charging system checked
hope this helps!
Dec 30, 2008 | 1991 Lincoln Town Car
Flickering
When you say flickers?? does the sound stay on or does the whole set go on then off or is it just the picture that flickers on and off and sound does flicker too? need more info please.
May 06, 2006 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Samsung SyncMaster 932GW LCD Monitor Logo
193 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
