The icemaker fills up with too much water, making the ice too big for the pusher to push it out. It just started doing this after working fine for many years. It is a whirlpool model ed25twxdw01 type 25ssa96.
Thanks
There are a couple reasons your icemaker will not fill with water. First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube. Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
Had Numerous similar problems for about a year, No ice in either the top or the bottom trays and the bottom leaked into the bottom of the freeze.
First thing I did was install a pump onto the water line supplying water to the ice maker inlet, thinking the water pressure was low. The pump hasn't run since I installed it six months ago so the water pressure is fine. Second I replaced the solenoid assembly thinking I had a bad unit. Still same issues.
Finally as a last resort I decided to bypass the water filter. Now both the top and the bottom ice makes more ice than I know what to do with.
It's easy to do my just using the hose couplers that are mounted on the water lines.
Second thing I did was install a 1" piece of 3/4 clear hose (available from any big box hardware store), cut the bottom end at a 40 degree angle an slid it over the fill tube going into the ice maker tray on the bottom unit. In my case the tube was just a tad too short. Be careful forcing in onto the existing fill tube as I think you can actually push it up further into the freezer housing. I don't think it's mounted very well on the inside. The tube should just be long enough to make it past the lip of the fill tray.
Last thing I did was reset the refrigerator to factory settings. I found that if I made the freezer too cold the fill water would freeze eventually coming out of the fill tube.
pull off cover in front of icemaker, there should be 2 hole under big gear labeled t and the other labeled h, jump those 2 with an insulated jumper wire, icemaker should run through complete cycle, pull out jumper wire at about 11 oclock on big gear, if goes through complete cycle and fills with water, ice maker is good, if not replace ice maker
sounds like you have a bad water valve solenoid. check the ½" diameter fill tube that feeds the water into the fillcup of the icemaker, you may have to remove the icemaker to see inside. is this tube frozen with ice? if it is, you have a bad solenoid.
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out. look for an adjustment behind the plastic
endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
switch the wires on the water valve (it has two plugs) and depress the water lever and see if the icemaker fills with water, if it does, change the icemaker, if it doesn't change the water valve. make sure there is no ice obstruction in the fill tube in the freezer
take out your ice bucket and clear all frozen water out of it only cubes should be in there if you have had a drip for several weeks you may have a big chunk in there possibly wrapped around the screew
Make sure the fill tube going directly into the icemaker is not touching the part that receives the water, if it is touching the water will spray all over and not go into the cavity
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
