Question about Gateway GT5220 PC Desktop
CD-ROM drive MSN messenger was downloaded onto my computer and was causing problems....I deleted some programs...don't know which ones and now my kids can't use CD-ROMs nor can they download music from iTunes...can I fix this or should I schedule a service call? The model no. listed below is not the one on my computer which is GATEWAY PERSONAL COMPUTER GMS5066E
  • Georganne Jun 19, 2008
    the prompt after the restore told me that the system could not restore and that nothing had changed. This is a good system for problems that can be fixed...I guess I just made a big mess. I will schedule a service call. Thank you
    Novelist:
  • 119 Answers
Try this
go to start>all programs>accessories>system tools>system restore. try to recall a date when your programs used to work well that is highlighted on the calendar and select that date. it will not erase or delete any of your files but will only remove any new program/software or updates that was installed in your computer
Posted on Jun 19, 2008
I recently had a problem relating to 'ANIOApi.dll'. What I did not know was that what caused that problem has also corrupted my LG GH22NS70 super multi DVD Rom. While the ANIOApi.dll issue has...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
if your computer came with a motherboard disk the drivers could be on it or you will need to download one
http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
if this driver package is not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)don
Sep 14, 2011 | LG GH22NS70 Super Multi 22X SATA DVD...
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
Jan 24, 2008 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Cannot remember my msn id and password
MSN Messenger (now called "Windows Live Messenger") uses an email address as a use ID and a password. You may be able to retrieve those from any computer you used to access MSN Messenger.
MessenPass by Nirsoft
http://www.nirsoft.net/utils/mspass.html
Download and install. The program will reveal the user name and password stored by common instant messaging programs on the computer, including MSN Messenger.
MSNLivePasswordDecryptor by SecurityXploded
http://www.securityxploded.com/msn-password-decryptor.php
Download a
nd install. The program will display the user name (email address) and password for any MSN/Windows Live account on the computer, and stored by any type of program (MSN Messenger, web browser)..
If you think you know your user ID for MSN/Windows Live, you can ask Microsoft to reset the password for the account:
http://explore.live.com/windows-live-sign-in-cant-faq
Feb 26, 2011 | Microsoft MSN Messenger Connect Service
Can't get webcam to work on messenger, it used to work, I must be doing something wrong do h I have to download a program
Reinstall you webcam drivers doing the following:
Unplug your webcam from your computer.
  1. Reboot your computer.
  2. Insert your webcam's manufacturer installation CD into the CD-ROM drive and follow the installation prompts.
Note: If the setup program doesn't start automatically within a few seconds, you need to manually start the installation process.
To manually start the installation process:
  1. Click Start from the taskbar in the lower-left corner of your computer screen.
  2. Open the Run window and type d:\setup in the text area.
    Note: The "d" indicates the path to your CD-ROM drive. If your CD-ROM drive is located in a different path, you need to replace the "d" with the correct path.
  3. If you've downloaded the most recent software driver from the webcam manufacturer's website, run that installation program now.
    Note: Most webcam manufacturers maintain the latest webcam software drivers on the download or support areas of their website. Just download it and save it to your computer.
  4. Follow the instructions provided by the webcam setup program.
    Note: Plug in your webcam USB cord only when prompted. (This is usually done after rebooting your computer.)
Sep 09, 2010 | Yahoo Messenger
Why cant i download msn onto my acer one laptop?
MSN Microsoft Network does not have a messenger per sey, Let me give you a download link to the "live essentials" witch does have messenger in it.
http://download.live.com/ click the download button to the right hand side of your screen.
*Note you have not told us WHY or what error message if ANY you are getting so we are giving you a download link that will have all the messenger stuff with it. Perhaps you did not have a certain program that went with it.
Thanks and please do be considerate while passing threw fixya to leave feedback and ratings for all expets involved, Thanks
May 26, 2010 | Acer Aspire One PC Notebook
I had msn messenger. I did an up grade and when it was done it threw me back to the very old msn messenger. I removed the msn messenger from hard drive and out of regedit. But I can not down load msn...
I think there maybe is something you are missing in your description. The hard drive itself has no bearing on a download. Particularly if it is your main drive. Did you do a manual uninstall, used the uninstall feature from the old MSN program or, did you use windows un-installer?. First, i would try restore to a date prior to your un-installation. After that, I would first try to un-installed again using teh Windows "Add /Remove programs" in Windows control panel. This is based on you having either vista or XP. You can use any of may freeware utilities to clean your register (not reg edit) but, if you are not very saavy in computers, I would let the registry as is. Then, download the msn upgrade and, install it from your computer (not from the web download window). If this does not help, oplease post again with more details on your system.
Nov 23, 2009 | ASUS Computers & Internet
I download the new msn messenger from the msn home page , so i know its a legit msn 9 , but after i downloaded it, and try'd installing it , it got 51 % done then stopped, it look like it's still...
lose MSN
than go to
start
control panel
add&remove programs
‘windows live essentials’(if using WLM 2009)
‘windows live messenger’(if using WLM 8.5)
click on 'remove'
and then on 'repair'
wait til the wizard finishes
sign in again
=?if it does not work uninstall from the control panel
Start
control panel
add&remove programs
'windows essentials' ( if using WLM 2009)
'windows live messenger(if you use a previous version)
remove
=?if it doesn't work
? You have to use this program created by microsoft to remove WLM 9.0 beta3/WLM 2009
Windows Installer CleanUp Utility 1.0
http://support.microsoft.com/kb/290301/e…
once started search in the programs list for "(All Users) Windows Live Messenger [14.0.5027.0908]"
mark it with a mouse click, then click on the 'remove' button'
=?Windows live Messenger 2009
http://download.live.com/?sku=messenger
?windows live messenger 8.5
http://www.microsoft.com/downloads/detai…
?PLUS live 4.80
http://www.msgpluslive.net/download/
(don't support the sponsor)
?NOTE: if you are trying to install WLM 8.5 and having problems, using Windows Installer CleanUp Utility search and remove "(all User) Windows Live Beta (all programs) [14.0.5025.904]"
=?if it doesn't work use "zapmessenger"
A regular issue faced is the dreaded “Another version of the product is already installed”, “Your computer has a newer version of MSN Messenger than the one you are trying to install”, ““Your computer has a newer version of Windows Live Messenger than the one you are trying to install”, “The feature you are trying to use is on a network resource that is unavailable” and similar messages.
http://messengergeek.spaces.live.com/blo…
http://www.softpedia.com/progDownload/Za…
Hope I helped MSN expert Dr Reed
Oct 12, 2009 | Microsoft Windows Live Messanger
Error code 8007007e
  1. Start > run > sfc /scannow
  2. Insert windows xp cd
  3. Restart computer
  4. You can skip step 1-3 but its strongly advised you do it.
  5. Uninstall msn messenger with ZapMessenger you can download it from:
http://www.softpedia.com/progDownload/ZapMessenger-Download-115115.html
6. Download and install Windows Installer Cleanup you can download it from:
http://support.microsoft.com/kb/290301/en-us
7. Run the utility, select all items concerning Windows Live, delete the following:
- Windows Live Call
- Windows Live Communication Platform
- Windows Live Essentials
- Windows Live Messenger
- Windows Live Sign-in Assistant
- Windows Live Upload Tool
8. Then restart computer
9. Download msn messenger again. You can download it from
10. Once installed Restart computer
11. Run msn messenger
12. Enjoy with J
Jul 29, 2009 | Microsoft Windows Live Messanger
Dell webcam manager working with msn messenger?
as ive told others, make sure u actually turn off the software program that came with the computer before using with msn! u should be able to have it on while using it but for some reason some computers wont allow it! it "tells itself" that there are 2 programs trying to run the web cam when really only one is.
but because the program is on, it sees it as being used in 2 places at 2 different times!
try turning off and exiting the software (dell webcam manager) and then go onto msn and try using ur web cam!! make sure the dell manager is exited, then when u have a msn window open, turn the cam on and see if ur friends can see u then..
good luck..
if this doesnt work ill check back and see what i can do for you!
Mar 21, 2009 | Dell Inspiron 530 Desktop Computer
Logitech quickcam E3500
Yes,
You can go to the camera's site and track down the proper drivers etc and download it that way (your camera's make and model}
or
Take the cd to a friends house and have them email you the entire install
or
have a friend upload it to a free storage internet sight.(like, http://www.yousendit.com/) where you can download it later directly to your computer.
Or
Have them do a file transfer to you using msn messenger or yahoo messenger.
Thank you and good luck *s*
Oct 26, 2008 | Logitech Webcam
Gateway GT5220 PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
