Question about Maytag Washing Machines
Washer filled with water-then wouldnt agitate and smells like something burning
  • 413 Answers
All Maytags (greater than 2 yrs old) have belts that are prone to wear and slippage. (thus the odor) In all but one model is the belt is visible and replaceable beneath the machine. Simply lift and tip the machine back to gain access. In one model, the front panel will have to be removed in order to replace the belt. This is a good place to start, inexpensive and simple to replace..
Other causes for belts burning are:
1. Failed transmission
2. Failed water pump or debris stuck in water pump....
If I can be of any further assistance, let me know
reg501 the Fixya Team
Posted on Jun 19, 2008
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
Washer fills with water, loud thump sound, no agitation occurs.
The thump is probably the motor trying to start followed by the burning smell of the belt slipping. See if something is jammed, but the most likely thing there is a bad transmission.
Dec 31, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
My whirlpool washer fills up with water, and then when it's suppose to agitate it does nothin and smells like something is burning. Is it fixable?
ya it is fixable as you feel some smell it may be some fuse burn out . check fot those things first. if fuses are fine some coils would have burned that would be the problem
Aug 06, 2009 | Washing Machines
Will not agitate
Bad pump Pump bearing locked up something up in pump brazzierre underwire shoulder suppet thing IN pump. Check pump
Feb 13, 2009 | Kenmore 63942 Dryer
Washer
THE SMELL IS THE BELT BURNING,YOU CAN REMOVE THE FRONT PANEL TO CHECK THE WATER PUMP,CLUTCH,BELT, AND TRANS,SOMETIMES THE BELT WEARS AND JUST STARTS SLIPPING.,LET MW KNOW-MIKE
Oct 19, 2008 | Maytag Performa PAV3200
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Overflowing and smell
needs a new pressure switch located in control panel are the small rubber hose going from the switch to the tub has a pin hole in it
Nov 29, 2007 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
52 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
