Question about ITT Jabsco Jabsco 135 Sl Remote Control Searchlight Replacement Bulb
Where can i find a part number for the gear wheel that makes my spotlight move up and down...the plastic teeth are broken on mine...model 61040-3002
Ryobi problems
Sorry not to have better news. The plastic housing on that trimmer is not strong enough to support the drive gears. Ryobi has discontinued that model.
I have had mine apart several times. The housing for the gear cogs is plastic and flexes. I've tried to reinforce it and added spacers between the plastic housing and the bearings that support the drive shafts in attempt to force the teeth together. But the trick only lasts for a few minutes. As soon as I start to cut with it, it stops again. It's just not worth the time, effort and frustration to continue working on it just to have it stop working again.
I finally discarded the Ryobi unit and purchased one with a metal (aluminum) housing. I think it is a Poulan Pro model from Walmart. It has worked well.
Jul 07, 2014 | Homelite Expand-It Hedge Trimmer...
Poulan Pro riding mower won't turn right. I can
there is a plastic connector that holds the steering shaft down into the drive gear the plastic cracks and wears out then the gear jumps passed the teeth its about a $15 part
Jun 14, 2012 | Garden
Craftsman model 917377411 front propelled drive not engaging
On your model I beleive these wheels are driven with small gears inside the inside diameter of the wheels. If the shaft is turning, then you probably have a gear problem. Remove a wheel and inspect both the wheel, and the small gear. They are prone to wear.I'd suggest replacing all four parts if worn.
Jul 18, 2010 | Craftsman Garden
I have a mod # vec280pob the white plastic gear the works the air compressor has broken teeth on it do ya carry that cant find there web site...
Vector was bought by Black and Decker in 2006, you can get Info, order parts or find a Service Center at this link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Jun 26, 2010 | Vector 1 Million Power Series Spotlight &...
My CDX-636 has a mechanisim to lift and lower the
My Sony CDX-636 has a mechanisim to lift and lower the CD reading carriage. It consists of a small motor and two nylon gears. the smaller of the gears has stripped a number of teeth which makes the carriage move up and then slip back. I need a new gear wheel. where can I buy a new gear? I am living in Palmdale, california
Feb 06, 2010 | Sony CDX-636 CD Changer
RE; Durabrand Paper Shredder. Model Number WM6X. The motor works in reverse mode only, but the blades don't turn, Help
You have broken gears. Call customer service at 800-327-8508 and they will send you 2 gears for $10 including postage. I got mine in less than a week. Easy install.
Nov 05, 2009 | Office Equipment & Supplies
Broken plastic gear tooth - Fellowes P55-C Shredder
I suggest using Belzona (metal compound). Mix it with its hardner, paste it over the broken gear (dont worry if it gets over a couple of other gears. Let Belzona sink and dry (4-5hours). Get a Dremel drill with a fine blade on it and cut accurately where the teeth are meant to be. Voila, you have fixed your gear.
Sep 13, 2008 | Office Equipment & Supplies
Broken Plastic Gear Wheels
Check out this website if you have an outdated machine without a parts program still in place it may come in handy.
http://www.rushgears.com
Feb 20, 2008 | Intimus 385 se Shredder
Grinding Sound
Only solution - Don't buy a FELLOWES shredder.
It is ludicrous that they cannot (will not) supply a spare gear wheel when there are thousands of instances of them failing. Or even think outside the box - fit metal ones?
Jul 07, 2006 | Fellowes PS80C-2 Shredder
ITT Jabsco Jabsco 135 Sl Remote Control Searchlight Replacement Bulb Logo
87 people viewed this question
Top ITT Jabsco Boating Experts
Mike
Steve
Steve
Richard Marshall
Level 1 Expert
Are you an ITT Jabsco Boating Expert? Answer questions, earn points and help others
