Question about Zanussi WJD1257W Front Load Washer
"ZWF160070W1 Washing machine. Only 18 monthe old!
  • Zanussi Master
  • 3,463 Answers
I would start by checking the filter and cleaning it, this is usually located at the bottom right front of washer behind a flap or cover, unscrew an ti-clockwise to remove and clean.
Posted on Nov 14, 2010
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
Why cat I open door at end of wash cycle
http://www.whitegoodshelp.co.uk/washing-machine-door-will-not-open/
Mar 14, 2016 | Hotpoint Washing Machines
Supra washer/dryer combo leaking significantly
In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Mar 20, 2013 | Supra SW5L65D Front Load Washer / Dryer
Water leaks on spin cycle
Water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Feb 01, 2013 | Hotpoint Aquarius WD63 Front Load...
My hoover washer dryer wont start? No power
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
http://www.espares.co.uk/advice/washing-machines/a/7/1298/how-to-replace-washing-machine-controls-hotpo.html
Click for tips to repair
Jun 28, 2012 | Hoover Washing Machines
Door wont open on washing machine zwf16581w at the end of the cycle
The door is designed to stay shut at the end of a cycle usually for about 4 minutes, even if you switch the machine off at the mains. Other than that you probably need a repair.
Dec 17, 2011 | Zanussi Washing Machines
WASHING MACHINE DOOR WONT OPEN
Call the manufacture it will be under warranty if it's only 6 months old as the machine will have to be torn down to get to the defective switch, just the top will have to come off if your lucky.
Jun 17, 2009 | Haier Washing Machines
Bosch classixx6 1200 express
my classixx6 1200 express is flashing f21? what is wrong with it?
May 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Whirlpool duet washing machine ghw9100lw1
To turn off "Control lock" : press and hold the "End of cycle signal" button for three seconds.
Nov 17, 2007 | Washing Machines
Zanussi WJD1257W Front Load Washer Logo
220 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
